25
Everything posted by nipper
There are several style of CVT's, subarus is the first to use a chain. As an engineer i find it fascinating, but I also wonder about wear, since chains, well, do wear out. I also noticed in the cut-aways there is a cansiter type filter in the transmission. If I had the money I would go make a deal on a 2009, but they can be had for a song right now. nipper
I am not sure if i am reading this correctly, but if your using a sooby LSD, it is not a clutch type, it is a viscous coupling. nipper
Get your car the hell out of there. General rule of thumb, If you were not complaing about a leak, it wasnt affecting performance, there is no rush or need to do anything. That wet spot could have been there for many many miles. I would just monitor the leak as it may be such a slow leak there is no reason to touch it. The tranny pans whenever they are removed, if not done right, can leak far worse then the original leak ever was. Try tightening the valve covers first, as they can work loose over time and cause leaks. Do the valve covers yourself. You may want to do plugs at the same time. For the vavle covers use subaru parts and bucket gromits. nipper
Join this group http://groups.yahoo.com/group/subaruvanagon In the files section they have many many work arounds for the VSS. nipper
Is it possible that your gastank is getting pressurized, and the only place for the gas to go is out the canister? If this is so (and I think it is) this is a dangerous thing. Check your vacume line routing. I dont know this year well enough to know the vac diagram off hand. nipper
1stsubaruparts.com/Mike Scarff Subaru of Auburn
nipper replied to Snowman's topic in Products for your Subaru
It's where I get all my parts that arent needed ASAP. nipper -
Ford 500 AWD Mercury Montego AWD Saturn View AWD Toyota HIghlander Ford Escape Hybrid Audi A6 Audi A4 Many AWD and many much heavier then the sooby. Though the one on thier I would least trust would be the saturn. My only question is can it hold up to 300,000 miles of driving. 100,000 is acceptable for the avg car (though 160 is expected). But for a sooby it has to be 300,000 miles. nipper
Justy CVT was a completly different animal. Usually the issue was the brushes failing on the wierd powdered metal clutch they used, the trannys themselves would keep working. The CVTs in the Prius are reaching 100K in the US. http://wikicars.org/en/CVT There are quite a few out there, though i will say subarus being the first to use a chain will be interesting to watch. nipper
