25
Everything posted by nipper
Can you drink in the back of a brat?
nipper replied to milkman111083's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Some states just require that all passengers wear seatbelts. The jump seats have seat belts. nipper -
A/C Problem
nipper replied to fixitguy50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Sounds like the AC compressor is siezed or in the process of seizing up. What happens when you remove the AC belt and drive the car with the AC on. nipper -
A/C Problem
Do you mean the car wont accelerate or the engine RPM wont go increase? nipper -
Thats a little early for inner tie rods, but check ball joints, inner and outer tie rods, as well as the universal joints in the driveshaft. If it makes you feel better Blu has the same thing right now. Some roads make it worse then others, and sometimes its not there at all, so i am going to replace the tie rod ends and go from there. He got new balljoints 2 weeks ago. He needed them. nipper
Does this have a ignition module by the firewall (i think it does)? the next time it dies check for spark. If you have no spark it can be that module. Things like the crank sensor can be tested with a analog multimeter while the engine turns. Ignition module/amplifier can drive you nuts trying to diagnose it. If you can get a used one throw it in and see what happens. nipper
