Everything posted by nipper
VW + Subaru = Veedubaroo
Something like this.... http://jalopnik.com/5225023/garage-mechanic-ghetto+rigs-subaru-impreza-with-eaton-supercharger nipper
Can't Change Climate Control Settings
nipper replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is an electrical unit. This is a good time to replace the bulbs as the unit is going to have to come out. Its possible that this is as simple as a loose electrical connector on the back of the control panel. It happens. nipper
Why Subaru 4 you?
nipper replied to wannasubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSO does that mean we may have our very first tribecca off roading?
Why Subaru 4 you?
nipper replied to wannasubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLeaves more 97-98's for me nipper
Fun project or headache?
nipper replied to alaskanjer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere is the fun in that?
Not a happy camper...new motor blues
nipper replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt almost sounds like the engine may be overfilled with oil. nipper
Why Subaru 4 you?
nipper replied to wannasubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAWD Tank just OK gas mileage (great for AWD) Its pretty. And a giant lego on wheels. nipper
Want to buy an Outback.
nipper replied to wannasubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEnd of quarter.... 4 quarters X 3 months = 12 months. Just like any other calander quarter. But thats in a normal economy, right now they dont care they just want to sell cars. nipper
Higher Compression increases Thermal Effieciency... But Why?
But i read Wiki and wont pass it on if it is wrong. i just didnt feel like typing all that out today. Its only compression ratios. if you want a deep meaning thermodynamics explanation on a molecular basis you have to wait till i feel better.
because i feel lazy today http://en.wikipedia.org/wiki/Compression_ratio http://auto.howstuffworks.com/question90.htm
nipper replied to wannasubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru is selling everything it makes, so they are not cutting off thier noses in spite of thier faces to make a sale. However an entirely new OB si coming out in 2010, so you may be able to get a deal on a 2009, but i am not sure. Sooby delaeers seem to be fairly fair in thier pricing, but hey, i cant negotiate either. good luck. nipper
Transmission noise- part deux ('98 OBW 5 speed)
nipper replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTransmission mount, carrier bearing, heat shield, exhaust hanger? nipper
nipper replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it possible that your dipstick is wrong? nipper
nipper replied to alaskanjer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi dont see anything here that is a no-go. Maybe consider upgrading to 4 wheel discs?
ipod adapter installation
nipper replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBacause he can, and dealers need the money.
Procedure For Replacing Fuel Filter
nipper replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell there are many hybrid cam drive engines out there. Some use belts to drive a cam, then the cams will be synched to each other with a small chain. This does make them freewheeling, but they are still basically interference. It is splitting hairs, but something you need to be aware of you ever rebuild one of these heads. I dont know if the toyota did this. I have heard "freewheeling" applied to these engines. nipper
Can you drink in the back of a brat?
http://www.youtube.com/watch?v=iHWbdRVWbTY&feature=related hehehe it just reminded me of this thread.
Engine Not Starting After Engine Swap: 00 Forrester into 00 OBW
nipper replied to dpoynt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes cam sprockets. Outbacks are made in the US, Foresters in Japan. Same with the engines. As bad as this sounds it should be a simple fix to change the sprockets. nipper
Hissing sound from the vents and weak A/C
nipper replied to IdiotSavant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have a refrigerant leak under the dash. nipper
2.5 With Oil Cooler?
This is factory, and it isnt as much a cooler as a tempp stabalizer. It also helps the oil warm up in winter, as the water heats up faster then the oil does. Damaged water pump?
99 Outback Engine Replacement... help please?!
nipper replied to Legacide's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell you ned a thermometer there to make sure its openeing at the right temp too. nipper
uh oh, overheating and now oil leak
nipper replied to codytotheh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy guess would be the main or oil pump seal went and it was all down hill from there. How much oil is in the crankase? When was the last time the seals were replaced. I think you are quite boned.
Caution new atf
nipper replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExactly. Fluid is cheap compared to the unit itself. There are many reasons why a MFG tries to extend the service interval, some good, some bad. I dont know the logic behind this move, but longer fluid change intervals usually shorten the life of whatever it is protecting. nipper
Acronym Definitions
nipper replied to doc526's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe best way to get around it really is to spell out what the acronym means in a post along with the acronym (like this). this way it also shows up in a search. http://www.aa1car.com/library/acronyms.htm see if that helps. nipper
nipper replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe fuel is under static pressure. As soon as a drop or two of fuel escapes the pressure drops dramtically. I have yet to ever have an issue except for a stubborn line. nipper
