25
Everything posted by nipper
Dont forget your gravity boots, we dont want you falling off the planet nipper
Physically inspect the radiator, and check the electrical charging system. The Radiator is probably clogged, or decrepid. If you look between the ac evaparotor and the radiator, the cooling fins may be all gone. You are due for a radiator. nipper
p0446
nipper replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Well that would be the evap system. The evap control valve is malfunctioining. nipper -
Change the water pump with the timing belt at 105K. Your pump has a lot of life left in it. For a 60K interval, thats every other timing belt you replace the pump. The pump may be done at 105K, but it wont make it to 210K (yes someone out there alwyas has one with a gazillion miles on it). Even subaru suggests it. nipper
We are beyond codes here, its time for tried and true 1930's technlogy. Put a fuel pressure gauge on the car and lets rule that out. Get a vacum gauge and tell us what it is reading. My feeling is that the ignition is breaking up at high load. The ignition system is under a higher load in 5th gear, then in fourth, even though the engine rpm may be the same. I cant scroll back as i'm typing, but lets make sure some things are ruled out that can affect igintion. Knock sensor (though that will affect performance not make a miss) OE ignition wires OE recomended spark plugs. I am getting the feeling it may be the coil pack, but i can't tell without an oscilliscope. It sounds like a classic coil failure to me. It can drive you batty. nipper
