25
Everything posted by nipper
Really? It happens more or less in Multi link rear suspensions. On the right road surface on the right conditions the back of the car will wander all over the road. It can be anywhere from mildly annoying to extremely exciting. Usually on rough roads or or cross winds. The back of the car starts to steer the front of the car.
What happens to the noise if you depress the clutch? Can you feel the noise in the clutch pedal?
- 6 replies
- cold
- transmission
(and 2 more)
Tagged with:
Manuals do all sorts of fun things when it is extreemly cold out, as you said, they don't warm up idling. Does the noise seem to match road speed or engine speed?
- 6 replies
- cold
- transmission
(and 2 more)
Tagged with:
I'm confused.
- 19 replies
- 4 wheel drive
- 1984
(and 2 more)
Tagged with:
Also replace the PCV valve too. Your new seals will thank you.
May be time to replace all the seals then.
How long ago were the seals last done. I am betting it is the Oil Pump Seal if it has never been done.
Heater Fuses Pop Immediately
nipper replied to rdweninger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you checked to see if the blower motor is shorted? -
http://www.edmunds.com/subaru/forester/2014/consumer-reviews/review-286803830262366208/ http://www.subaruoutback.org/forums/104-gen-4-2010-2014/177690-use-5w-30-instead-0w-20-a.html http://www.subaruxvforum.com/forum/engine-drivetrain/20153-alternative-0w-20-engine-oil.html Oil viscosity doesn't really have that much to do with using it as a non compressible medium to do work for the valve train. It is all emission and MPG driven. http://blogs.cars.com/kickingtires/2013/08/expensive-oil-changes-are-here-to-stay.html and finally https://autos.yahoo.com/news/consumer-reports-sees-oil-vanish-test-cars-140000066.html
They all are using more oil now for several reasons. They are asking more power out of small engines so they use more oil. I think we are just all spoiled as oil consumption isnt necessarily related to a mechanical issue. Oil does evaporate as it is used not only for lubricating but cooling of pistons. The feeling of the thinner oil is to help raise the MPG. Thinner oil easyier to move, faster to warm up. What the avg owner wouldnt care about (1 mpg) is big over a fleet of many engines. It is possible that a little thicker oil would solve the problem, but unless you have clouds of blue smoke coming out the exhaust, or engines dropping valves it is a non issue.
A couple of NICE Ebay finds
nipper replied to Wolfman01's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The brat yes, the wagon no. Just because something was owned by a little old man, back in 1987 he wasn't a little old man. It does have some signs of honest wear on it, but 2K too much
