25
Everything posted by nipper
PCV what is does And axle boot replacment.
nipper replied to faithless88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Everyone should do it at least once ....... Then they will never do it again nipper -
You need a analog meter to read the voltage. Digital volt meter take a sample every X milliseconds, since it has to process the data. The more expensive the meter, the faster the sampling rate. Also every time a digital gets an input, it triggers the processor, so it removes the previous datapoint. It is possible that you can get data faster then it can process. Digital is not the end all of meters and never will be. There are times that you need a needle, or a scope. I always have a cheap analog and a expensive digital. Also the injector timing is affected by the cam position sensor. nipper Edit : slow typist
Yes it can happen with an LSD. Essentially the center diff is a LSD. It happens when the viscous coupling gets over heated (on a manual tranny). The VC is a set of altenating discs FRFRFRFRFR F- front R- rear The plates have holes in them. When they spin at differnt speeds, the silicon fluid heats up, and mechanically hooks up the plates. When everything equilizes the liquid cools. Now if this condition lasts for too long (and in a manual it doesnt take long), the fluid cooks and becomes a glue. Front and rear axles spin at different speeds ( no road is complete straight). They need to have a diff in the center to alow this (manuals only we are talking about). When this ability is lost, you get torque bind. It is usually caused (on a manual) by mismatched tires, driving on a falt, or an underinflated tire. Hope that helped. You can also search Viscous coupling and spend days reading. nipper
reciever drier may have fell apart due to age. That will clog the system. You will need to have the system flushed evacuated and recharged. nipper
It really depends. The power brake booster can hold it for weeks. The no-brake-pedal-in-cold is a stuck check valve. You can have a lazy vaccum isolater/delay/amplifier valve. They are little round things with a hose coming out of either end. Can be a minor vacum leak (get out the carb cleaner and spray around the noise). The leak may not be anywhere near the noise. If it drives fine, you may have to wait untill its a little more noticable. Have you driven it in the rain with the replacement engine? nipper
There are a few sesnors that will stall the car. The crank sensor, the engine temp sensor. Yo need to check and make sure whatever generates the signal for the crank sensor is not damaged. My first wild guess would be the engine temp sensor. If thecar doesnt run long enough, it may not store the code. The ecu is always a possability. nipper
