25
Everything posted by nipper
Antenna Mast
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
hehehe you dont know me very well. i have made peace with the fact after 200,000 miles the drivers seat back heater died. The power antenna on the other hand, it needs to work. It has to work. It will work ..... cause , well, gee, i like it nipper -
I agree with cookie. But also i am not convinced you need HGs. Have you been complaing of fluid loss? Also if you have, and its not a huge amount of fluid (ocassionally topping off) i would live with it. I get very suspicous when a car goes in with no real complaints and they find something major. Missfire can be wires, plugs, injectors or coil towers. First try moving the ignition wires around and see if the problem moves. If it doesnt spray the engine with a water bottle while its running and look for arcing. Cat effeciency at almost 200K would be the front o2 sensor. It can even be the rear one at that mileage. nipper
Maybe years of expieirence with subaru AWD units? I did not say ANYWHERE for him to spend money. My Post: "You have torque bind. DO a search here. Take it back to the dealer, show him the dragging, and tell him the duty C solenoid and the clutch pack are shot. It's an 800.00 repair. If you didnt have a warrenty we would suggest some things to try, but since you do, let him deal with it. You can try putting the fuse in the FWD fuse holder under the hood, but with an electrical failure that doesnt usually work." I said since he has a warrenty there is no reason for us to go through all the alternatives. I spoke the truth. Re read his second post. He is blessed with a 6 month warrenty on a older used car. He should take full advantage of it. "96 Impreza OBW with 113k (almost) seems like brakes dragging in really tight turns... dealer used cheap brake pads, etc... I've been thinking it was that... Good thing I got the warranty (6mo/7500mi) with it, if it's tranny issues..." WHy dont you critisize other people when they come on here with a problem, and our first response is "its under warrenty, take it to the dealer" This is the same thing. And as far as scaring people, i have often gone down the list with people on things to rule out, starting with tires. It's interesting to see that you didnt even list that. I left it out since he already said he has new tires. That also made me suspicous that maybe the first set didnt match. nipper PS someplace on the site someone has posted the tranny codes, i'll see if i can find them. I had a hard drive crash and used to have that stuff stored, now i have to try to find it again.
Antenna Mast
Synthetic power antenna lubricant, right next to the blinker fluid. WD40 would work. I think its more of an issue of cleaning the dirt off the mast as well as lubricating it. I would avoid any lubricant with any body too it, as it would capture dirt and can stain clothes. nipper -
You have torque bind. DO a search here. Take it back to the dealer, show him the dragging, and tell him the duty C solenoid and the clutch pack are shot. It's an 800.00 repair. If you didnt have a warrenty we would suggest some things to try, but since you do, let him deal with it. You can try putting the fuse in the FWD fuse holder under the hood, but with an electrical failure that doesnt usually work. nipper
Year and mileage please. It should blink 16 times if there is a problem, not 5 times. Are you sure your counting it right? A blinking ATF light is telling you the last time the car was operated there was an electrical issue. It could mean a failed solenoid or bad fluid temp sensor. What happens in tight turns? nipper
Your forgetting one other thing. You will need to either have the radiator professionally cleaned or replace it. Oil + antifreeze + water + air (from sitting empty once you yank the engine) = Glue. Since you have owned the car since new, i vote for the HG replacement with the head rebuild. The 2.2 is unbeatable, and even if god forbid the engine went poof. you would still have to get the heads rebuilt anyway with a new shortblock. nipper
reseal the oil pump cam seals main (crank) seal water pump thermostat tensioner idlers timing belt drive belts (you already have them off) Radiator cap The list may seem long, but you wont have to touch anything on that end of the engine for another 108K. By then the engine should be just broken in nipper
