25
Everything posted by nipper
Rarely fuel pump. You need a pressure gauge on the fuel line to see whats going on there, i bet its one of the sensors. Fuel pumps seem to run forever. Knock sensor? This is where my expertise gets a little thin. Have you cleared the puter and reset it? Just because the CEL isnt triggered doesnt mean there arent any stored codes. nipper
Fantastic mpg!
nipper replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
in my 98 leagcy if i drove like a sane man i would sy 30-38 mpg. Too bad im crazy:banana: nipper -
How many miles on this thing, and i dont recall the puter reading the oil pressure switch? How is your charging circuit voltage? Im suspecting a supply voltage probelm as there are some really odd ball codes on there. Didnt know the system read the ac pressure either Somethig doesnt sound right, i cant even find where those things intersect with the ECU on the wiring diagram I know the ecu could care less about the air conditionining. It never reads that. I know it reads the AC relay and the AC diodes. nipper
Ive installed the tweeters, it makes a big difference in sound. odd how my car had the premium sound system but no tweeters, its an easy install. Spark plug wires are OE, Plugs are OE (but not from subaru). Oil filters OE can be competativly priced with aftermarket, just dont go cheap. Use a brand name. Oil can be anyones, same with antifreeze tranny oil etc. Pads and rotors, unless your upgrading the rotors, use OE. Pads can be either, but never by the cheap ones, and go with name brand. DOnt turn the rotors as they dont always like it. Dums can be turned (but it rarely is needed) Anitfreeze every 2 years, tranny fluid every three (your tranny will love you). Do not use tap water in the cooling system, use deminerilized water, or pre mix. Timing belt, pcv and thermostat OE. Never use chemical flushes. General rule of thumb when replacing a part, if the original part lasted over 100,000 miles, replace it with OE (as they must be doing something right) Timing belt, for your car every other one replace cam seals, main seal, water pump tensioner and oil pump seals. At 200K (or near it) by your car a gift of a new oil pump. Watch your temp gauge, dont let the car over heat, and it will run forever. If it does overheat, change the oil when you repair it. if you see your temo gauge go 3/4 up, the ac cut out, then go down, you have a clogged raditor or the fins have fell off. All 4 tires should match and be within 1/4 inch of wear around the circumfrence. Keep them inflated the same. Thats all i can think of. Im sure somone will chime in and say im wrong (that never happens hehehehe). nipper
Wind Noise
nipper replied to excal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
a lot of convertables do that now nipper -
That is the FWD Fuse. When you put a spare fuse in that holder the FWD light will come on on the dash. You use this fuse when you have the spare tire on thr car, or the car is going to be towed by the rear wheels (which is no longer revomended, a flat bed is). The fuse energizes the Duty C solenoid, which in turn kills the AWD completly. nipper
1- chewed up start teeth means the drive is rubbing against the flywheel. It can be a tired or worn drive or tired solenoid not allowing the drive to come all the way back in. Fuel pump is in the tank, but it is SO easy to get at. I would look at the fuel pump relay first (hrmmmmm). The pumps are fairly bullit proof, and you cant tell anything without a pressure gauge. nipper
@@@ !!!Subaru Justy!!! need recruits @@@
nipper replied to Dukie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In the US they stoped making the justy as we know it in the early 90's (94?). it was a unique US spec. The justy is alive and well in europe but its a suzuki metro rebadged. http://en.wikipedia.org/wiki/Subaru_Justy nipper -
Alas i think i have to the blue to the sooby doctor. This just started todaym, and doesnt do it all the time. Start the car, the tranny light flashes 16 times then goes out. Duty C Solenoid? I have no torque bind at all and still under doctors orders not to do anything (and the 1 year mark is coming up oh joy). So do i have to take out the plastic or what? nipper
sounds liike a modern marvelous mystery oil nipper
