nipper
Everything posted by nipper
  1. you have fuel pressure, but do you have fuel injectors firing. There are three things that keep a sooby from running (sounds like a broken record) cam position sensor, crank sensor, and temp sensor. The crank sensor determines spark. Do you have spark at the plugs? i bet you dont. nipper
  2. You actually sound like your in the begnining stages of torque bind. IMMEDIATLY check your tires and make sure they are properly inflated and they all match. You have a viscous coupling. The way it works is it has two sets of alternating plates inside it. These plates have holes in them and sheer the the fluid. As the fluid sheers it heats up and you get 50/50 awd. For some reason this is what is happening to you. This is why when the car is cold its not a problem. nipper
  3. torque bind on a 5 speed is bad news. All you can do is check tire sizes and inflation, but if you have gotten to the point where bind is showing up in a manual, it usually means the damage is done. The Viscous coupling is shot. Dmani hate delivering 800.00 bad news. Unlike the automtics, at some point the car wil become very tough to drive except for on route 80 in nebraska (road is dead straight). When you do get it done make sure all the tires match, otherwise youll just burn it out again. Sounds like the original problem was a bad wheel; bearing, but this is defanitly torque bind. nipper
  4. Do you have an LED test light? LED is important because some ignitors do reverse polarity (im not an electronics wiz so i dont know why)If you do remove the connnnector from the coil pack. Touch the test life to each of the outside terminals as somone cranks the car. If the light blinks, the ignitor is working. if the light is not flashing you have a bad ignitor, crankshaft sensor or an ecm issue. Rule out the other two first, since if you replace the ecm and it still doesnt start, its one of the other two. It sounds like the ignitor is getting a signal, but the ignitor is bad. Crank sensors usually work or they dont. If you can get an affordable ecu and want to try it go ahead. nipper
  5. what do you mean by non functional? Do you mean the air system is totally dead, or that the shocks are dead and wont bounce at all. nipper
  6. ah i never knew thats what it was called. i just called it the abs signal generator aka thingy (since its not really a normally servicable part). It used to be so much fun when i got to the name the parts in my old job. nipper
  7. dont use pure synthetic, use some sort of hybrid. Synthetics lower friction. Automatics need friction to operate. a hybrid is a mix of both worlds. a cooler never hurt nipper
  8. thats what it does when you connect the diagnostic connector. you are supposed to dount the flashes of the cel. Get yourself a haynes manual so we can get a better idea on how that procedure works. Sounds like your ecu is doing just what its supposed to do. nipper
  9. i agree. change the fluid change the filter, seems very odd. nipper
  10. ive had them fail that way a few times, thats the "just park the car and call a tow truck" sensation (seized cv joints go poof). After that the axles are just purely decorative. nipper
  11. From what i can tell, nothing. Check the lines with soapy water and see if there is a gross leak someplace. Also check to see if air is getting to the struts. nipper
  12. dont go hunting down the computer. If it was computer it wouldnt run at all or it would run for ever. One of two things is happening. Either you have a massive air leak, or your comprssor is shot. Is your compressor putting out any air at all? is the suspension system reacitng at all? I would check the airlines between compressor , control unit, and tank to see if there are any leaks. Also check all the lines. nipper
  13. Look underneath your car and inspect the boots. If the boots are torn plan on replacing the axles. If they arent torn you can probably got till fall (dont wait till winter, this is something you should do on your schedual and not the cars). If you start to feel the the click in the steering wheel or the brake pedal, your getting close to totaly failure and should replace them. nipper
  14. whats a tone wheel, thats new to me. Basically if your going to go through all that labor, you should replace the bearing. Its likes replacing a timing belt and not replacing the water pump. Murphies law will bite you in the but and the wheel bearing will go not long after doing all that work. Laos since your car is a 95, it really wouldnt be a bad idea to change them anyway, as ten years ona wheel bearing is a respectable life. nipper
  15. Have you soaked the entire system with soapy water to see if there any leaks other then the suspected strut? nipper
  16. thats what i was wondering. That was not a cheap thing from an engineering point of veiw to add to a perfectly fine transmission. Maybe they got nervous from the svx failures , who knows. There is still a screen. nipper
  17. Which leads to the question, if it was not meant to be changed, why did they go through the expense and bother and making it an easily replaceable filter. i would change it once every 3 years. 40.00 is cheaper then 1500.00 dollars nipper
  18. You wont find them on line or used because everyone replaces them with standard struts on all four corners. nipper
  19. a steel ruler is the standard straight edge. Just dont by a cheap one. nipper
  20. sounds like the starter developed an internal short, rare but it happens. Its one of the few (if not the only) curcuit not protected by a fuse or fuseable link. nipper
  21. sounds like you have a dead coil pack. Go to a scrapyard and get one or two and see if that fixes it. nipper
  22. 1- filter screen is just that its just a screen, its not a filter. It jas very large holes that dont get pluged, Its just for material. 2- You remove the pan the wrong way you can make a leak and never get it right again 3- subaru says it needs no serviciing. Jou dont change the pickup screen in the oil pump, and that is exaclty what it is, the same thing. Torque bund you change the fluid. No where does it say change the screen, and i have never said that. TB is a rear clutchpack issue of gum buildup (90%) of the time.
  23. change the spin on filter. There is a screen insdie the tranny dont touch or change that. nipper
  24. refrigerant oil only. otherwise you will poisin the desecant. nipper
