25
Everything posted by nipper
First thing i would do is pull off the timing blet covers, and like said, inspect all the seals and see what they look like. i would suspect if a head gasket was done, the valve cover gaskets would be new, the exhaust gasket, not to sure what else would be easily seen. i imagine eht e cylinder heads would look cleaner then the rest of the engine under the covers. Replace timing belts, if the other seals look ok, replace the crank seal, waterpump, oil pump seals,and any belt idlers. There is no tranny filter to replace, but a tranny flush will avoid torque bind. USe suabru coolant and deminerilized water, and you should be good to go. ALso check the vin with a dealer to see if any recalls were fixed. You may even luck out and find out a dealer did the headgasket. nipper
nice try but .... when the defroster is on it pulls in fresh air no matter what you have the climate control set at. The ac alwyas comes on with defroster, unless its really cold outside. Keep looking, as the failure mode for the ac clutch is it wiether seizes or stops working. i still say you have a fluid leak. nipper
Check all your fluids, including the power steering fluid (which is overlooked ... but can leak on the pipes). If you think its a fluid leak, next time you park the car, slide a clean peice of cardboard under the car, and let it sit overnight, then check it out. To keep the gasses from leaking into the cabin, put the heater on recirculate, which will work for heat, but not for the defrosters as it will override your selection. You can see the CV boots from under the hood. nipper
1992 legacy clutch
nipper replied to JEL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Tranny .. far less wires and hoses nipper -
Cars do suffer from brake fade today, just not that many thank goodness. Drilled rotors can be done right or can be done very wrong, they must be cross drilled and then properly annealed to reduce the stresses of the drilling. Therws is alot more to it then just driling holes int disc, as alot of cheap rotors do do. SLoted rotors are good, but i dont know if they are available for the roo. http://www.mr2.com/TEXT/rotors.txt http://www.enjoythedrive.com/content/?id=6955 corvete uses crossdrilled rotors http://www.corvettemuseum.com/specs/2006/index.shtml http://www.valvoline.com/carcare/articleviewer.asp?pg=pht20000717tp&cccid=4&scccid=5 but i will conced that slotted may be better then drilled, as it seems the only place to get good drilled discs is brambo ild still put brambos on my car anyday. A brake sysytem is a trade off many tyhintgs, like anything else in the car, and you need to look at your driving style. It should be looked at as asystem and not individual parts, and the most forgotten peice of the system is usually the flex brake lines. nipper
a brake light is something that you NEVER ignore, out off all the lights on the dash this one comes on you investigate it immediatly. It sonds like the resivoir is low, and thats from a leak or the pads are worn down really low. Im going to suspect its the pads since your not complainging about brake performance. ABS may or may not come on with low pads, on some brands it does (like GM), and some it comes on when the third brake light is blown. Just and FYI. nipper
Actually when does it make this noise, all the time or just first thing in the morning? On inspections, they only pull one wheel to inspect the brakes if the dont do it electonically, and fro some reason its always the left front, murphies law i guess... so its possible you have a sticky caliper and a bad pad ... nipper
im thinking its a partially clogged catalytic converter. Here is a test if it is. Next time the problem occurs, note what engine rpm it is happening at. Next shifting the car manually, in D3 see if it happens at the same engine rpm, and at d2. It should happen but at a lesser extent due to the rpm/hp curve ... just an idea. A cloged cat doesnt always throw a code, but it will get worse with time. Other possabilities are a collapsed exhaust system, or as stated before a blocked air box. nipper
