25
Everything posted by nipper
Age. 237000 thousand miles at 80K change intervals asuuming he changed them regulary, which i suspect he did not.. Its age pure and simple. nipper
all i can think of is that there is lag when the awd engages. Put in the fuse and see if there is a differnce. SSee if you have lazy awd. I would do a tranny flush first, then wonder if one of the speed sensors is bad (or how ever the car says it needs awd). But really sometimes that is not a fair test. nipper
If you want a car that wil operate and look as good in 200,000 miles as it did brand new, get a subaru. The bodies seem to last for ever, and as long as you have a good body, the car is always worth fixing. COmpare a 200,000 sooby with a 200,000 mile toyota, and alot fo things on the toypta will not have faired as well, or would have been replaced. where as all the subaruparts will be where the factory put them. You rarely read about broken switches, turn signals, door latches or trim peices falling off the car. Soony knows people drive thier cars for 250-300, 000 miles and they are built for that where they can. Other car manufactursers want you out by 100-150K and really dont care what happens to the car after 80K except for emisions. Thats why i buy subarus. Each one had over 250K when it died, and once by cancer, the others by crashes. Thats another thing, i am qute comfortable that the crash worthyness of a 300K mile subarru is as good as the day it left the factory. I can still get parts from subaru for a 20 year old car. I have never been told that part is no longer available. Not only can they run for ever, i can always get parts. SUbaru has one of the best resale prices on the market, where as othercars tend to tank with age. nipper
The synchro people will fight you to the death for parts .... better watch your back nipper
How hot should an alternator get?
nipper replied to markjs's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Altenators get hot. Its a by product of producing electricity. NOw in my opnion, with winter coming.... if its an old alt, and you think the bearings are going, ild just go ahead an replace it. An alt will get over 200 degrees, so not to worry. nipper -
I would replace them asap. All it takes is one overheating to strand you somepleace, or one really good overheating to bake the engine. It's always better to do repairs on your time schedual, as opposed to when the car demands it. Its only a matter of time before youdo real damage. As it is now, the more you drive it with oil in the antifreeze, the more likely you will clog the radiator and or heater core. nipper
CLutch pedal check under the hood and look at the adjustment. If it is adjuste and shifts fine, go get another cable (you can always return it) and see if it is the proper cable. The cable should be replaced when the clutch is replaced. nipper
Another thought ... tires. Generally Tires guarnteed for high miles are of a harder rubber. They offer less rolling reistance, but the trade off is in handling. this may not be an issue if you dont drive aggressivly. more sticky tires have softer rubber and less gas milage. Not alking a big number here but who knows. nipper
EWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW ok i got that out of mey system. DId that paint come from a speed shop and is it a high perfromance engine paint Actually this seems to be coming up alot. If your looking for performance bolt ons for an outback, it doesnt happpen, unless youconsider a complete turbocharged engine a bolt on nipper
'92 Justy AWD Automatic... Should I buy?
nipper replied to fluffy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Drive it? usually will tell you if it goes or not. The problem is with the electormagnetic clutch from what i understand, not the tranny itself. nipper -
sensor help
nipper replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
its a thingy ... can you post a pic? nipper
