mudrat79
Everything posted by mudrat79
  1. Hello, A member fitting this Similar name e-mailed me, but the e-mail was messed all up......If the person will call or e-mail me again I'l try to answer or Help out however you were trying to have me do..... Later, John
  2. If you have never had the HEad gaskets done, I would Say yes for sure, you are having the typical headgasket Issue.... You can try limping it, but I would Not suggest it that far from Home... How many miles can you put in before it blows all water, and needs more...? Is the Dealer not wanting to do Heads....? Good Luck, John in Oregon.....
  3. IF, Key Word IF.....I have my New Improved BEAST Done, I might try to drive it Up to Give them a Taste of Roo......Group looks Very Cool, I will keep you folks posted if I get to go..... Later, John
  4. Sorry, Guys......My Bad.... Didn't realize there were the electronic issues....as well as tunnel issues..... I step back on this one....... Later, John
  5. Should Be a Direct swap in... Only thing you will need to do is re-adjust the shift rod underneath at the tranny......Not sure if you can swap the Pistol style XT shifter or not, But I do know the Tranny will swap in.....Make sure to keep converter with tranny.... Later, John.....
  6. Hey Krissy, Not saying its in the same spot, But you said Pasenger side, So I am assuming something similar......cause there is nothing on that side accept return line and Holding tank....... I have the Overflow bottle here, Austin was going to bring it up there for you.... Let me know what you find........John
  7. Hey Krissy, Look at the front edge of radiator on passenger side just over the edge from the top....That is where the other one developed its crack in the tank..... Keep the overflow bottle at least half full all the time till you figure it out.... Call me if you need me to explain it in more detail...... Later, John 541-729-8490
  8. Hey Subafly.... I sent you a Check for the amount we discussed 3 days after we last chatted on the phone.....?????? Verify you got or didn't get it, and Call me...... My # is now in my Sig...... Later, John.......
  9. Here is My experience With what your Looking for..... I am currently playing with an 85 RX sedan.....You can get this Sedan From 85 thru 93 as a GL or GL-10 Turbo Model.....Main difference between the years were GL's had Carbed Engine with 5 sp Hi only or Auto 4x4 or 2WD.... GL-10 Models Almost exclusively had turbo, Auto 4x4 or 2wd Auto with 3:70 gears.... The Other Big Difference is GL had Manual Door locks/cranks and GL-10 had Power everything.....In 88-93 sedans You can also Find SPFI models Running 5 sp.Hi only 4x4 RX Sedan Was only ran in 85-86 I think......??? And Was Manual 5 Speed HI-Lo With 3:70 gears..... Power everything and Was Turbo Charged Motor...... I am Currently playing with my 85 RX For rally And Auto Cross.... If I were you , Look for any Turbo Sedan.....Auto or Stick 4x4.....It can be converted easily with right parts.....This Board Is full of them.....I have all things needed as well......Then First thing to change if Motor Runs, Is to get a 5 Speed Hi-Lo 3:90 Ratio tranny and rear diff and Stuff it .....this Trans. Makes Turbo spool faster, Giving you better HP in the Bottom end of Motor.....Stay with your 13 inch tires ......Open the Exhaust up to 2 1/2 inch pipe off the turbo and Then 3inch under the car.......Get rid of the stock air can And Go with a Cone type, you can also Install an Intercooler..... You can also Install a Bost control Valve and Guage....I run My boost right now around 10psi...... I work on these Cars, And Am into mine for very Little Right now.....First trip Out with it to a Rally I managed To place 1st in Open class with it...... If your interested in a Ready to Go runner, I have a Nice one right now I am trying to sell for a Customer.....It is an 87 Gl-10 Sedan It was an auto 4x4.... It is now a 5 speed Hi-Lo 3:90 runner with Turbo.....Not much elso done to it....Motor has a Complete re-seal done with no Miles on it as yet....Also Has almost new 2 row Radiator To help keep turbo Motor Cooler..... car has about 215,000 on odometer I think...., motor has 135,000 and tranny has about the same......It will drive anywhere you want it to..... If this Interests you call Me......# is in My Sig.... Later, John
  10. Hi-Jacking this Thread for a sec..... Garner.....Call me ASAP......About Auto-Cross this Weekend......At Valley River Also, I may be able to steer you in your Quest.... Or Come by...I have a Running Turbo Car in the driveway.... Later, John Hi-Jacking ENDED...................
  11. Hey Ed.... Any idea on how long it will be before they Post times...? I wanted to see how many seconds were between me and 2nd....and 3rd........ Later, John......
  12. Hey Kurt...... You and your Crew Are Welcome to crash here if you need or Like while in the Area....???? Let me Know, John......
  13. I Still can't believe I won Open....... My car had Many little Issues First I had No power Steering, as The Rack has a Bad leak, So I ran with it Dry... Second I Had stuck my Recaro Seat in the day Before, And Forgot to Weld in the Bracketry on the driver side, So right off the start gate I was sitting sideways... Third.....When I got to the Meet, I went to stick My Mud tires on, and Discovered the Bolt Holding the Pivot point for driverside Rear swing arm was Wrong and Ghetto from the Previous Owner, Decided to run it as is, and on my final Run a 1/3 of the way into the Coarse, I lost that Bolt completely, so The swing arm was flopping madly around all out of Whack.....Causing my Steering wheel adjustment bar to loosen, and allow steeering wheel to float up and Down in full travel mode..... All this on the last Lap made me think, I had lost all chances of even placing, Cause the steering floating, caused me to hit 2 cones..... Times for the 3 runs were a 1.42.?? for first run with 4 cones hit 1.32.16 No cones on second 1.32.00 on last with issues and 2 cones...... My car is Nowhere Near being Dialed in yet....... Wait till I get it All fixed up propper, and Right....... Later, All..........John
  14. If You must change, I know from personal Swapping , that all Were Basically the same from 90-00 ....Only diff was in Speed-O Cable Hook-up...... On 90-92 it has a Mechanical Speed-O, on 92 and Newer they went to Electronic Pick-up.....Both Units Bolted into the same spot on the tranny.... All electrical conections were the same.....A few wires changed color, but perform same function...... I Stuck a 70,000 mile 97 trans into a 90 Sedan, with no issues Hope this helps, John in Oregon.....
  15. Hey RugbyBen..... When You get done trashing your Bumpers, and Want some Lift in the OBS, Let me Know.....I build them.... Look At what I do for your Cars Front Bumper here..... this is my main gallery //usmb.net/gallery/albuo13 Here is Your Cars New Bumper on A Baja..... //usmb.net/gallery/album115 I am building similar Bumpers For the rear as well......Both Give a much better Aproach/Departure Angle...... Let me know if these interest you, John in Oregon.....
  16. Just couldn't Hold Out Could You......... Man My wheels Make that thing look almost Sexy...... Even for a Monster..... See you Sunday.......John
  17. Hey Jarod.....Stay safe Bud..... We'll yack when you get back.......Got to send me an E-mail of things to come for Lil'Roo...... Thought you'd Like Kens.... Chin High, Head Low...... Later, John and Crew in Oregon
  18. I must Gloat here.... The Rims and Tires belong to me for My project..... Ken Barrowed them so his Ride wouldn't Look sissy-fied Going home on 27 inch rubber........ Remember Ken if you get them Muddy, you got to clean them....... Later, John
  19. Hello, From Oregon... I am another Fabricator Here in Oregon.....I am in Eugene Look at this Bumper and Tell me what you think...... http://usmb.net/gallery/album115 I can custom Build Anything......I've done several Big Custom jobs already..... This is My Last Ride http://usmb.net/gallery/albup25/100_0024_IMG This Pic was taken at the Rubicon trail last August..... Call me if your interested..... I build Subaru's For a Living.... My website is http://www.oregonoffroadsubaruclub.org Later, John in Eugene...... Mudrat Design & Fabrication 541-729-8490
  20. Ok, Here is My List.... First was a 79 Brat.I had it from 1991 to 1996 R.I.P. it had 2 inch suspension Lift 14inch tires Duel Exhaust Ea-81 and 4 sp.Hi-Lo Transplant 26 gal. Auxillary Gas Tank in Bed Custom Bumpers Front and Rear Many others From then to the BEAST The BEAST was an 86 Hatchback 3 inch Mudrat Design Lift, Custom 2" Exhaust Built Ea-81 Motor 5 sp. Hi-Lo 3:90 LSD Rear Disc Brake Conversion Custom Mudrat Design Bumpers And Roof-Rack Weber Carb many little goodies 29x8.5x15 Wildcat EXT tires http://usmb.net/gallery/albuo13/BustedLakeJohn The BEAST BECAME BEAST-A-CON BEAST-A-CON Had 12 inch Lift 2.2 Motor and AWD automatic Conversion Nissan T-case 4:11 Diffs with Licoln Locker in the rear, and LSD up front Recaro Seats Custom non-cat 2" exhaust Rear Disc Brakes Custom Bumpers Custom Roof-Rack 32x9.50x16" Wildcat EXT tires All Mods Done by Mudrat Design & Fabrication with the Help of Lumpcam (Rob) R.I.P. BEAST-A-CON........ http://usmb.net/gallery/Zapar-Rubicon/weeble12 NEW PROJECT.........TOP SECRET............SEE AT WCSS 6........ Member and Founder Of The Oregon Off-Road Subaru Club Member of The Hatch Patrol later All.....John and Crew in Oregon....
  21. You will not be able to swap the Hi-lo Diff part of the tranny... you can However swap in a Complete Hi-Lo tranny in its Place.....Drive line Length is the same, and All shift points are the same..... You will want the Shifting hardware off the Duel range, as It doesn't have the Push button, and It will have the Hi-Lo stick as well..... Pull your Shift Boot up, and you will find a Tin plate screwed down to the Shifter Hole in the Tunnel.....Pull it out, and You are ready to install the Hi-Lo..... E-mail me or call if you have ??? or run into issues, I've done this conversion several times.... Later, John...... 541-729-8490
  22. Hey Brad, I'll Make it if I get a Motor in the RX... Talk Soon, John......
  23. Hey Adam..... Is this the Park over out of Florence...?????? If so, I may See about going....? let me know, John.....
  24. Any EA-81 Radiator will work...... If you hapen to get one out of an Automatic car , it will have 2 small lines off the driver side tank.....Ignore them...they are for the transmission... Later, John
  25. I know As well........ I wonder who's Shop it was in........???? Wish I could Tell, But I too am under a gag order..... Later, John
