mudrat79
Everything posted by mudrat79
Hey Honda, and Junkie..... If either of you are capable of getting your Pics and or Video to me before wed it would be great....I am compiling a video of all Jason times...for the Friday Party..... Andrew can you call me Tomorrow, Monday......I lost your Number.....I'll drive up and get yours if need be....???? Later, John in Eugene......
To all of you That Attended WCSS III My Good Friend and 4x4 Bud Jason M. Roe.... ( had the Silver Wagon That Came with me to the Show ) Was Shot and Killed Accidentally Saturday Morning while Deer Hunting on his Property down In Cottage Grove, OR. :banghead: He was to be a First time Dad in January, He was a Major part of My 4x4 Club, and was Our Guru for Custom Exhaust.... We will be having a Celabration Of Life Get together for him this Coming Friday October 10th at 4 pm. in Cottage Grove. All who knew him are welcome to come. If you need I have plenty of overnite space at my House for any of you Northern Guys Wishing to attend.... There is Also Going to be a Help Fund account set up tomorrow At the Bank of America In Cottage Grove,OR..... ( I'll post an address and Phone for them as I get them) Any of you who knew him and are able to contribute to that fund will be greatly Appreciated, as It is going to be a rough time For Christy His Honey the Next few Months Being Pregnant and all...... There is Much to say about him, He was A Super Good Guy, all who Knew him know that...... I could Go on and, on, but Enough said for now..... If any of you From here wish to come on Friday the 10th. it will be a Bring your Own Meat and Drinks BBQ, All are welcome, If you happen to have any pics from trips or the Show, Please let me know or bring them with you...... Call me for Directions for the 10th..... 541-729-8490 Later for now, John in Eugene.....:cornfuzz:
93leg...... After reading all your driving and Diagnosis, I feel very strongly that your Coil Pack is going out...... Reason you get O2 code is that under load if one or 2 holes are missfiring, you get raw fuel into exhaust, a knock due to the stumble associated with missfire, and computer trying to compinsate for all the above...... I have had 4 cars Locally all have these same symtoms, all came to me from the Dealer Locally, cause they couldn't figure it out.....????? All of these were Auto's.....????? Is your car stick....? With your car parked, can you get it to missfire or hesitate bad once warmed up....? or in gear ( if Auto ) with brake set and someone stepping on brakes, Do the timing light trick on each plug wire at the plug end.....put the car in drive and put a load to it lightly, see if you get a stumbling light.....??? I will wager that either 1-2 or 3-4 is misfiring/stumbling.......meaning that that part of the coil is breaking down under load...... Several folks on the Board right now seem to be experiencing the same issue....... Check it out that way, and let us know...... Later, John in Oregon......
EA 81 Carter 1 bbl to Weber swap
mudrat79 replied to pierman2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
AS you thought, It's not available, and you will need a Complete 4 bolt Hitachi intake manifold...... Do you have to worry about passing emissions.....? If Not, you can Delete alot of unecessary smog crap.....This makes The weber conversion very Easy...... If you have ok mechanical skills, the Conversion isn't Too bad..... Read a repair manual on how to remove the Intake as a Unit, then with it off, you can do the swap.... I would suggest buying the Redline Kit, as it Comes As a COMPLETE KIT...... Ask them to make sure to include a throttle cable mount for base of Carb.....it makes the conversion a breeze..... Hope this helps you some, John in Oregon..... -
Hello, Form Oregon.... I have had 2 cars with exactly your condition come to me from the dealership here locally.... try this...... Get a timing light....stick it on # 1 Plug wire.....With someone holding the brakes for you, put the car in gear and Romp the throttle short and Quickly..... The last Car I had do this was bad enough I could do it with it in park.... Run throttle up hard like under acceleration.....and it will cut out really bad but very gentle, and it runs ok.... My Money says if you Do this on all 4 plug wires, you'll find 1-2 or 3-4 missfiring under Load....... Coil Pack is on its Way out.... Here is whats happening..... At idle, there is Little Load on the Coil....it sparks just fine... on hard Accelleration, it has to work harder to get the Bang happening....So if it is breaking down, your electrical system can't produce enough amperage to do the job proper... above about 1800-2000rpm's, the Alternator kicks in and gives it the juice it needs, therefore smoothing out the missfire....and fixing al shifting issues..... I haven't run into this with a stick shifted car, but both Auto's I did had 1-2 Coil missfireing at Low end..... Coil Pack runs about $100.00 at the Dealer, and I would Suggest Buying it there...Takes all of about 12 mins to install...... Let me know if this ends up being your Issue, And Let me know if I was wrong..... Hope it works, John in Oregon.....
Dinner in Eugene Oregon, Sept 22nd
mudrat79 replied to TheSubaruJunkie's topic in Meet n' Greet. Your USMB Welcome Center
Cool, Call Me Andrew..... Talk then...... Later, John...... -
Hey All.....I am around, just Super Busy...... I've only recently started sandbagging this Part of the USMB... As Forester Ranger said..I am in the Process of Opening a Shop, and What I am going to Specialize in is the Bulding of New Gen Subaru Off-Road Equipment.... Bumpers, A-Bars, Skid Paltes, Rear Swingaway tire carriers, Roof-Racks and Such..... Part of the Problem I will Run into is Test Beds for building the First few of Each New Design..... F.R. has a 98 Forester, I built a Custom 2 inch lift for his car, and Can Build another set anytime for the Newer Subi's Now..... this Lift not only gives ground Lift Clearance, but also gives more room at the Strut For Larger than Stock tires......So ou get the best of 2 Worlds.....Driving his Forester, I feel it has a better ride and Off road Feel now......He can Vouche for that if he Wants...... I wil be Building him Bumpers and Other stuff, and With his Car as A test Bed, I can Build some Nice Forester Accessories... As I build, I will take pics and Post...... I am Also just moving into a New Home, and Shop Will soon be relocated to same Location as Home.... So if you can, Be patient....I will Hopefully before the End of October have Some Cool Pics for you al to drool Over...... If any of you would Like to Chat Directly , you can call me at 541-729-8490 Later for now, Sorry for the Long Post........John in Eugene, Oregon.....
Good Wheelin Weekend!!
mudrat79 replied to Adam N.D.J.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
HEy Adam......I need to know if You and Junkie Are still planing on Coming up tomorrow......? And If So when you plan to be in town.....? Call me in the Morning......John in Eugene... -
I bought mine through CCR as a Short Block for 500.00 or 550.00 that gave me New BAerings, seals, and Such, New Water and Oil Pump..... I did the head Work Local, and Stuffed all other externals on Myself...... I think for a Complete Long Block, CCR Charges 1200.00 to 1500.00 for turn Key Motors.....my numbers May be a bit off, So its Best to call Emily Direct and Tell her you want one Like Mine.... Later, John in Oregon......
Ned an Idea...... I will be working till noon or so, Some one needs to bring a BBQ......Mine is in-opperable.... Se you al tomorrow around 12-1pm..... Later, John in Eugene -
No Biggy.......Just trying to schedule my next few weeks of Big Jobs.... Call me when you have a 1/2 hr or so to chat on the Phone......? I figures you were probably en-route when no immediate response happened...... Talk to you soon......John in Oregon......
The 2x2x6 Blocks that SubaruBrat Used for his Lift were Cut, Drilled ,and Shipped from Me... Call me On the Cell, And I'll explain things to you better...... 541-729-8490 Later, Your Roll ya Back over Bud In Oregon....... John...
What a great old car ... highway run hint.
mudrat79 replied to mtsmiths's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Morning Smitty..... Never got the Call......????? Still going to do A project......??? Call Me Soon Please..... 541-729-8490 Later, John in Oregon........ -
Get everyone at my Shop by 1pm or so, and We can Do a BBQ there and watch my Copy of the Rubicon trip.......?? I'd be into 4x4'ing, but I've not had a chance to even look at fixing the BEAST-A-CON since I got back from the trip... only real fix is building a New rear Diff Bar........ Later, John in Eugene....... -
This is 2 pics from the Rubicon Trip , I'll start with these , and as Time allows I will try to post more in my Album, so look there .......:wave: Later, John in Oregon...... http://usmb.net/gallery/albuo13/WEEBLEWOBBLE http://usmb.net/gallery/albuo13/Weldingourworldisflat
Pul the Vacuum off the Disty, and Using a long piece of vacuum line test it ( the Disty Vacuum advance) at the Disty... Do this with engine running at idleand Manually pull air off the vacuum advance, it should idle higher and stay there till you back off the vacuum... If it pulls then drops on its own, or dosn't pull at all, vacuum advance is bad , which will cause bad hesitation at bottom end.... Very common on stock disty's Old stock Hitachi carb doesn't pull near as hard as Weber, so it becomes more pronounced....:cornfuzz: Hope this Helps, John in Oregon.....
These Duel CArb intakes generally came on 30, 000 mile Jap motors......If you get one with all the linkage your good to go .....Hard to find though...... I have personally driven 2 Gen One Brats with this set up, and both of them had Gobbs of Get up and Go...... One of them I could Burn tires off in 2WD all the way into 4th gear.... The other was a bit more tired in the drive train, and would only light them up into 3rd......:brolleye: I know they are available for 1800 motors also, And one guy at WCSSIII had one set up in his Hatch, But I've never driven one of them , so Can't say how they do.....? I will say that if you get one Use it with stock carbs though...... We tried to stuff webers on one of the Brats, And it got entirely too much fuel... Later, John in Oregon.....
Tranny options for an EA81 T
mudrat79 replied to harpua's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank You Shawn...... Now I can proceed without Worries.... Later for now, P.S. I still can't get logged in to the Gallery......? John in Oregon...... -
all you experienced modders....
mudrat79 replied to heartless's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Depending on how bad the rust already is, as you cut the bad out, you will find that it goes way deeper than you would expect....... I've seen 3 wagons from the rust belt, and all 3 ended as scrap cars......Sucks, but your better off trying to find a decent Body, and transplanting all your mechanicals.... If You proceed with this project, Look at all rust and probe it for depth of Uglyness,then get as much gone as Possible ....After you have it prepped, paint on a good rust inhibitor before welding in good Metal.....Once past the welding point, undercoat it with something good to get some life out of the car again...... Hope it helped, John in Oregon.... -
What We are trying to figure out is this....? EA-81T is Running an Auto Trany and 3:70 final gears, We are looking to stuff a 3:90 tranny in behind the Turbo, and the problem I am thinking of is that if the EA-81T has as much or more bottom end Torque as the Normally carbed EA-81 then we are going to run out of Motor around 60 or 70 mph.....? So what I want to know is if anyone has ACTUALLY in REAL LIFE Installed and Ran a 3:90 tranny behind the EA-81T.....??????? I already know From Experience that An EA-82T with 3:90 gears Behind it runs AWESOME right up to about 100 mph then flattens out real fast......? So I don't want to stuff one behind a Lower Reving motor to find out it won't work well for HWY driving......? Let me Know, Later , John in Oregon.... -
Any of you extreme builders want a contract?
Thanks For the Cudo's everyone.... Smitty, if you would, Call me on the Number Harpua Gave you..its my cell #.... It will be better to chat person to person about what your Looking to do, and What we can come up with.... Cell is on all day every day, and if you're Serious about mid October as a time line, time is at a Premium already for this Project....... Hope to hear from you soon...... John in Eugene, Oregon....... -
He is the one interested in your Drivetrain for his Project... Jared, Chat with Lumpy about prices for his gear....... Later, John in Oregon... P.S. Drove the WEEBLE WOBBLE home today......Everything else was tore apart.....Sure get lots of Looks driving that on the street..... Owner of BEAST-A-CON.... AKA : WEEBLE WOBBLE...... If you've seen it Operate, you'd understand
