41
Everything posted by brus brother
Kept hearing the sound from front left, not central to transmission/gearbox. Took to Indie transmission shop for a quick look see. He drove it alone (Covid protocol) came back and said, good news... wheel bearing. Had it replaced today and that sound is gone, although now I can hear every other creak and groan from ye old clunker. Spinning the old bearing by hand off the car it feels real crunchy. Common things happen commonly. Occam's razor.
Are you talking about diagnosis of the grumbly old transmission? Two trusted Subaru mechanics gave it the thumbs down. Stethoscope on the gearbox produced grumbling. No sounds coming from the wheel bearing that I had originally suspected. I found a USDM trany with 91K for $550 delivered to my address. 6 month warranty. Thanks all for elbowing me past the JDMs.
near me 06880 high mileage (90k miles +) and either 6 month or 90 day part warranty only found this seller on ebay but spoke with them directly in Washington State. Foreign Engines average 50K miles with 1 year unlimited mileage warranty. $325 + 300 shipping. https://ebay.to/30v9nAJ Anyone local have experience? Their ebay rating is 100%
Subie Tech says I have some time as he's heard much worse. Will keep hunting for a lower mileage one around 50K. I found ads for partsrequest.com that lists some used JDM transmissions with around 50K miles. Just need to ship from west to east coast. I'll be researching them later today. Wouldn't mind trading up but the car sales market is ridiculous right now. Gave our daughter the 2019 so we are trying to nurse the 08 for a while longer.
2008 Outback AT 132K miles. On a 6 hour road trip last month, I heard a whining noise I had hoped was my new tires/pavement. Put car in neutral while cruising down the road at 60 mph but the whine remained the same. After a few miles it stopped. A few days later, travelling home, the same whine recurred but again, stopped after a short while. Before I reached home, a new sound arose. Now the car developed what I had hoped was the sound of a failing wheel bearing. Sound doesn't change while loading/unloading the bearing by turning the steering wheel side to side. Subaru tech put it up on a lift and while all set to replace the front driver bearing, instead diagnosed a failing gear box. He placed a long screwdriver against the gearbox with the tires spinning and let me listen to some grumbling from the gearbox. Took it to a reputable Indie transmission shop yesterday who took it for a test drive but didn't have a lift to fully diagnose. He acknowledged the sound and swerved side to side thinking as I had that it could be a wheel bearing but no change in sound. Wants me to leave the car for final diagnosis but lacking a second car, I am trying to figure out the what ifs. Trusted Subie tech quotes a 90K mile used transmission installed for $1500 complete. Indie was closer to $2400 including $1300 labor, based on him finding a used transmission with not as yet determined mileage. He did say it isn't cost effective to rebuild as there are many of these used transmissions around. I am in Fairfield, CT. As it's our only car, I am concerned about driving it on any long trips as I can't predict if catastrophic failure is in my future. The gear and transmission fluids are topped off and clean as a whistle. I guess my concern is that a 90K mile transmission of unknown history isn't that far (?) from my current 132K mile failing transmission. Terrible time to be looking into buying another car. The TB and HGs were done at 95K miles, front suspension bushings etc have been worked over recently and with the exception of some exhaust noise the car is in good shape. Any thoughts appreciated or suggestions to source transmissions. Any crystal ball thoughts on final failure?
Not intending to hijack this thread in anyway BUT last month on a 6 hour road trip from CT to Maine in my 2008 OB AT with 132K miles, I heard a whining noise from what i at first thought was new road/pavement noise. It stopped. Sound came and went again on the return trip but then developed a new sound, a growling that I thought might be a front wheel bearing BUT today a Subie tech put it on a lift and heard the growling coming from the gearbox. Pulled the gearbox dipstick and the fluid was full and clean as a whistle (at 132K miles??) even though I don't ever recall changing it. Tech squirted some snake oil in (no charge) and suggested he would be looking into a used tranny in my future. spoob happens but at your mileage, unless the car was abused (I guess my never changing the fluid might qualify for abuse) it is certainly disheartening. I am hoping the model year 2008 OBs aren't imploding on cue! Keep us posted. Fingers crossed. Edit: Tech who did HGs at 95K seems to recall he drained and filled gearbox at the time
OK drove from CT to Maine to see daughter and had everything ready to change oil and filter on the 19 OB. Due to the additional underbody cladding, the oil drain plug is tucked WAY up inside a 5x5 opening and makes a friggin' mess as it spurts out. Seriously considering a Fumoto valve as it is protected in the recess and a hose can be attached to direct the oil. I can confirm that it is a 14mm bolt and can ALSO confirm that it uses a smaller crush washer than the ones I've used for years on Subie oil and tranny plugs and that if you use the older larger washers, oil WILL leak. Don't ask me how I know.
Found out that certain models and years (my 2019 OB being one) came with a 14 mm drain plug that is made of soft metal that can easily be rounded over. Warned to proceed with caution and best to use a 6 point socket and not find an SAE "equivalent". Some dealers have learned to replace them at the first oil change but apparently not mine? The car is with daughter in Maine and I'm heading there next week with both 14 and 17 mm 6 point sockets in hand. Hold my ankles, I'm going in!
