Everything posted by TheSubaruJunkie
Reno Area Wrenchfest??
TheSubaruJunkie replied to Jibs's topic in Meet n' Greet. Your USMB Welcome Center
Are you home now JB? -Brian -
Have you ever looked at the back of your car?? Would say SUBARU GL or SUBARU DL on the plate. -Brian
If you wanna meet up with me in sacramento, that'd be cool. Not sure if Im gonna head up with the nevada crew, or fly solo. Last year, it was me and Jibs from Reno... we left a couple days early. This year, im hoping to have a few more from California... but so far, nobody in Sacramento is interested in going. -Brian
He's right Miles... 84 DL's and STD hatchbacks still had 4spd S/R. -Brian
Subaru RX Type RA?
TheSubaruJunkie replied to eddygordouk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
He said fastest EA82T RX out there. -Brian -
Turbo motor with NA pistons
TheSubaruJunkie replied to Subarian's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Even with 7.7 pistons you need premium gas. Im in the middle of building my EA82T using a N/A block. Hopefully, if all goes well, i will be dropping the motor back into my RX and i can let you know what kinda difference its made. -Brian -
Yeah, your dash has a 4WD light and a Low light as well... lift it up and it should illuminate the 4WD light... lift it farther and the lo light will light up. Buuuuut... since its '84 chances are your car has Dual Range. Expecially if its a GL, there's a 99.9999999% chance it's high & low. -Brian
what makes a ea82t engine die?
TheSubaruJunkie replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine was the lack of oil. Probably the high boost that blew a ring... then after the ring went the bearings then rod. -Brian -
Nevada/Cali Guys ---> Moonrocks Round 2
Last time i tried to make it, my engine blew up... we'll see if I attempt to make it this time around -Brian -
What wheels will fit my 89 DL
TheSubaruJunkie replied to Suzrub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yup, probably different. Nothing other than Peugeot share the same lug pattern as our subies. -Brian -
I wouldnt worry too much about points or anything, just get a new distributor cap and rotor. Take the old ones with you so you can match them to the new. There were 2 types of distributors for EA81's... Nippodenson and HItachi. Use NGK plugs, nothing else. Get new wires too... even if your old ones still look good. -Brian
I think a steel front bumper for a set of airbags is a good trade Just think of how much safer he is now that he's not being protected by styrafoam and plastic. Lookin good Austin! -Brian
Racer - or - Off Road
TheSubaruJunkie replied to Tyler_Seattle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Money?? Contact me. I have some springs you could put in your car that would drop the front end about an inch. Might also be able to find a rx kit. they show up in yards all around -Brian -
Since your car is SPFI and not turbo, i would suggest upgrading to a 2" exhaust. If you dont have emissions, dump the catalytic converter if you can. -Brian -
Here's your help. XT struts bolt into standard EA82 bodies. Same thing... but 2WD XT struts are 2" shorter than standard EA82. More info, if your car is 4WD... it has the tallest struts subaru offered for your model year. THats a start. Also, body kits are out there. RX coupes have them (my car). Pretty bolt on and mild look. -Brian -
ljohnston ????wheeless????
TheSubaruJunkie replied to ljohnston's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry bud, cant really help you. I had no idea where henderson is. Call up some auto recyclers and ask for rims from a Peugeot model 505 or 504. If you get alloy wheels, you need to make sure you get the peugeot lug nuts as well. -Brian -
Oh yeah... and the performance part: I still got blown away by everything out there from Dodge Caravans to Toyota Hybrids. My EA82T didnt have any low end grunt. The new motor im putting together should change all that. -Brian -
Brads car has no performance. In that shot, it was N/A SPFI and right now... well, i dont even think it moves Here's my car lowered. I cant talk tho... mine hasnt moved in 3 months either. -Brian -
How far from Reno is that? Is that southern Nevada or Northern? -Brian -
Stubborn oil pan gaskets!!
TheSubaruJunkie replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, i have some brake cleaner... maybe i'll go spray it and leave it overnight. The gasket is super thick... i dont really feel like grinding all of it away. Maybe i'll take it to work and use the wire wheel we have there... make real quick work of the job -Brian -
Im preparing the engine to go back together. I got a couple oil pans in the garage and im trying to get the old gasket off of them. The old gasket is hard, brittle and stuck to the oil pan. ANyone have any tricks up their sleeve to loosen the gasket material? -Brian
How far from Reno are you? 14" alloys and 14" steels are alot easier to find than you might think. I may know where a couple sets are. -Brian
