Everything posted by TheSubaruJunkie
Building a hot pre 1976
TheSubaruJunkie replied to 300td4x4's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The PnP in carson city is off of 50 headed away from Tahoe. There are maps at http://www.pickandpull.com That 90 Loyale will have almost nothing that you need, other than the engine. I wish you woulda been on the board about 2 months ago, i had a 1989 GL10 Turbo Wagon that was rotting here. Had the FT4WD 5spd with center diff lock (AWD with locking center pretty much), EA82T, plush interior... everything but the LSD. Woulda let it go cheap, but the state towed it. -Brian -
Family 1st buddy. We know your not gonna disapear on us. Good luck with everything -Brian
Sway / stabilizer bar failures -Outback-
TheSubaruJunkie replied to vtphoto's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Actually, you kinda really need the sway bar. It helps the car perform better, and reduces understeer. -Brian -
ECS Light VS. Temp Sensor
TheSubaruJunkie replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its not the sensor thats bad, my guage is bad. If i put the stock sensor back in, i have no idea how hot my engine is running. -Brian -
I installed an aftermarket coolant temp guage, and it came with its own manual temp sensor. I had to remove the stock sensor and unplug it of course. Now when i drive the car for more than 10 or 15min, my ECS light comes on. Ive plugged the plug back into the stock temp sensor, and that solved the problem for a while, but now its back. Is there anyway to bypass this? -Brian
YEah, with the EA82T you gotta keep it near 3000-4000 to make power. Not sure what will happen if you run past redline, but as long as you dont do it every day for a prolonged amount of time i dont think much damage can come of it. Dont quote me on that tho. -Brian
Is it a carbbed EA82? Or MPFI/SPFI? If its carbbed, put a weber on there. -Brian
Well... the frikken Wagon died again last night on my way home from work. Definatly a fuel problem. Not sure if its the Carb or the Fuel pump.... so im replacing both. Ive already decided to get a Weber, so that will be on order very soon. But, i need to get a fuel pump ASAP, so i'd like to get one that will keep my weber happy. What is the standard PSI for EA81 fuel pumps?? Anyone know? And what would be a good PSI to keep the weber running at peak performance? -Brian
Brian. Head to the Pick-n-pull in Carson city. They have alot of Gen1 cars from time to time, even seen some Gen1 Coupes and sedans that might be better suited as a racer than a Wagon. I refuse to sell the '78 as parts. The car is too straight and clean to part it out. But i wouldnt mind seeing it being turned into a racer. I myself was thinking of doing the same thing to it. I had a Fulltime 4WD 5spd with center diff lock, but it was towed by the state for not being regg'd. So now i dont have the tranny. I also had plans on building a EA81T but cant find one. Anyhow... i'll let you know if any leads develope. -Brian -
lil' Roo's Old Age slowly creeps up...
TheSubaruJunkie replied to Rooinater's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not to mention the car has been rolled! I dont think there's anything jared HASNT done to the car. -Brian -
I believe to be smog exempt, the car has to be 30yrs old. So it would have to be pre-'74 at this point. 2006 you could do pre-'76 Good luck finding a chassi tho. There's a dude in Grass Valley that has an automotive shop. He has two 360's sitting out front. Ive stopped and talked to him, and he mentioned he used to have a FF1 and a few GLF's etc... Also, there's a guy who lived in Northern Nevada/California (cant remember where right now) who had a '76 4WD Wagon that needed a new engine. Body was 100%. He wanted $200 for it, but i couldnt find a way to get it back to sacramento. That was about a year ago. Not sure what he ended up doing with the car. Maybe i'll contact him and let you know what happens. I get funny looks in my lifted wagon as well... but its not as big as your MB, and only has 75hp. Talk about slow. -Brian -
How would you know anything about having a 8" lift John? You've never seen anything like it in your life. I however had a brief chance to wheel with jared and his rig, and i'm sure that car will last a very long time. You going to limp it to LV Jared? -Brian -
Oh yeah... and is this your rig? I saw this parked next to Pick N Pull a few months ago. Cant be very many like it. Looks like its a Mercedes on a Toyo Frame. If so, very nice work. -Brian -
I live in sacramento, not too far from P.Pines at all. As a matter of fact, i just came into a cherry '78 Wagon. Same body style, has a 1600cc 4WD 4spd. Contact me and we can talk -Brian -
Shouldnt have to. -Brian
new pics of the wagon!!!!
TheSubaruJunkie replied to ru4x4ever's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That post looks REAL close to the tire. Looks like you need a lift Car's looking great tho. -Brian -
Are you a Driver or just luggage?
TheSubaruJunkie replied to QuickRX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
everything i know about racing, i've learned from Gran Turismo. Now that im closer to Laguna Seca and Sears Point (or whatever its called now) I'll have to look into some racing classes and courses -Brian -
I would do some experimenting with the headlight assembly and the grill setup. See if you can bolt the entire headlight assembly from the donar car onto your Hatch. Not sure what the metal on the Hatch looks like, you might need to make 2 openings to fit the high beams. You'll also need to get the wiring figured out as well. -Brian
I've been suckered....maybe a bit winded
TheSubaruJunkie replied to kecksnext's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just swap for coil overs. Might be a cop out, but will fix the problem perminatly. If you replace or repair them, there's always a chance they'll go out again. -Brian -
It begins today...
TheSubaruJunkie replied to JParuBob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
get a set of 8mm wires... i got a custom fit set for a V8, and cut mine to size. They work great with my coil... both are made by Accel. Also, get NGK plugs, the best for our sube's. -Brian
