Everything posted by TheSubaruJunkie
WCSS10 Location and Date Set!
TheSubaruJunkie replied to WCSS's topic in Meet n' Greet. Your USMB Welcome Center
The biggest party of the year. Some people drive through 2 states to attend this party. -Brian -
PRICE GOUGING MO-FO's
TheSubaruJunkie replied to cobcob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yup. Search here for the part number and order it online from SubaruParts.com -Brian -
EA82T theoretical power?
A wise man once told me: "There is no replacement for displacement" At the end of the day, no matter what you do to it, the EA82 is still 1800cc. -
He is right. The limits are endless. If you could solve ALL the problems the EA82T had, or would have, you could make 1000hp out of it. However that would cost ALOT of money. Lets try to get alittle more realistic though. 190, maybe 200hp would be the limits. But if you wanted a reliable EA82T then maybe around 150ish. -Brian -
One more nice custom brat
TheSubaruJunkie replied to HATCHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I remember seeing a website with the build on this thing. Had much bigger pictures too. Not a bad machine. -
Better you than me man I can't feel a thing down here.
I cant plan that far ahead. Maybe at the end of june we can start planning things for July.
I would stick with the smaller 13" alloys. You can find them for sale in our marketplace, or in the junkyard. Dont worry about backspacing, anything with a 4x140mm bolt pattern will work. -Brian
I think this would be better suited as an announcement instead of just a sticky. Something like this relates to EVERY subaru owner, not just those who chose to off-road em. We all own 4 wheel drive subarus (except the few with FWD only) See my reply in the OT thread.
One other thing to consider... if your car has the stock 13" steel wheels, maybe look for a set of lighter alluminum rims. You'd be surprised how much sportier a car can feel with less rotating mass on each corner.
Do you know if it has a single barrel carburator or a 2bbl carb? The suggestion these guys listed are not practical. There are a few things you can do. If you have a 2bbl carb, you can modify it to manually open the 2nd throat. see: http://www.ultimatesubaru.org/forum/showthread.php?t=49976 Advance your timing a few degree's. I think the stock EA81 is supposed to be 8 degree's, I found that running at 12 degree's gives you alittle more gettyup off the line. However, Im thinking your car, being a 1981 DL, is a 1600cc. If that is the case, no matter what you do to it, its still gonna be slow
1984 subaru GL Wagon
TheSubaruJunkie replied to cacustom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it was an option in 1983. I found that alot of California cars got them. -Brian -
Mountain Biking Reno
TheSubaruJunkie replied to TheSubaruJunkie's topic in Meet n' Greet. Your USMB Welcome Center
Bring a bike and lets go! Not much wheelin for me this year... the legacy doesnt have the clearance or the tires for it. -
whats up folks
TheSubaruJunkie replied to hotboxhatchback's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your right, my bad. so what disease does your mechanic got that allows him to trade services for marijuana? Im sure your prescription doesnt authorize you to use your medicine like food stamps either. back on topic, your tranny is fuct. I'd suggest taking it to a shop if you want to have it fixed. Or if you want to bandaid it, refill the fluids and drive it. Chances are it will last another 20 to 75,000 miles. I would also recommend checking the oil in the engine to make sure theres some there as well. -
whats up folks
Just the type of person I want working on my car. Some half witted stoner who works on farm equipment. -
EJ Engine and Transmission into a RX
TheSubaruJunkie replied to [HTi]Johnson's topic in Subaru Retrofitting
I say you weld the center diff, run only rear axles in a stock EA82 Diff, and have a 2.2 liter RWD RX -
whats up folks
Charter member means Ive been here since Day one. Actually, the USMB is 10 years old this year, but thats another subject for another day. If you ask me, I say you need to find a new mechanic. -
whats up folks
Yup. Sounds like the dude did a SPFI conversion on your EA81. Thats pretty cool, not many have accomplished that here. This is the cone filter & adapter I was using on my Turbo EA82. Someone will have to verify wether the MPFI and SPFI MAF's have the same bolt pattern. http://cgi.ebay.com/ebaymotors/91-99-Nissan-Sentra-200SX-SE-MAF-Adapter-Red-Filter_W0QQcmdZViewItemQQcategoryZ33659QQihZ009QQitemZ190215856133QQrdZ1QQsspagenameZWDVW Should work better than a sock anyhow. -
whats up folks
Okay i stand corrected, it is the original motor, but it should be carburated. I suggest removing the section that sais "Subaru F.I" and seeing if there isnt a carburator under there after all. It maybe that someone removed the stock air box and replaced it with the Subaru F.I. plentum instead. Here is a picture of a EA81 with a carburator on it: a SPFI intake will look completely different. -Brian -
whats up folks
MAF adapters for a Nissan will work. I think i used a nissan sentra adapter for my EA82 that was MPFI. if the SPFI MAF is the same, then the adapter will work. The engine is not original and was put into that car. in 1983 there were no subarus offered as fuel injected unless it was turbocharged. And they never turbocharged a hatchback from the factory. If you live in CA, best of luck getting it smogged. -Brian p.s. might want to do something about your avatar as this is a family friendly forum. -
http://www.ultimatesubaru.org/forum/showthread.php?t=73676
Pics from the RX meet yesterday.
TheSubaruJunkie replied to audio_file's topic in Meet n' Greet. Your USMB Welcome Center
looks like the RXs were out numbered.
