5
Everything posted by Scott in Bellingham
Why dont you guys take I.S. to the next level?
Scott in Bellingham replied to MorganM's topic in Off Road
Im in the process of putting Legacy running gear under my 8" lifted t-case Turbo short wagon , anyone have any problems with legacy axles and such? -
Offroad Videos Walker Valley Soobies plus Toys
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
22 PSI gives me more clearance and I dont worry about air down / up and popping a tire off the rim, also , traction isnt a problem, lack of a low enuff gear is, this allows more spin wich helps my RPMs -
Shop/Club night Bellingham Offroaders
in a few weeks were headin back to Walker Valley if you want to go along -
how much for a good weber
Ive wondered that, the only EA82 axles Ive seen broke offroad is from over extending the angle ,
thanks Morgan good stuff :cool: -
:banana: your welcome:-\ :banana: -
true they are diagonal, front left and right rear are on one circuit etc.
I have a 87 2wd justy will the 4 wheeel drive setup bolt in
heres a link to some offfroad videos from some of our Walker Valley adventures:banana: http://www.loghomefamily.org/subaru/ hope you enjoy them , this year we have made it to walker 3 times and each time its been different, we will go again once the guys get on the Ball and finish up their car mods, thanks Rollie for shooting most of it
every week on Wednesday night we meet in Bellingham at Scotts place at 7:00 , if your interested stop by , at present Dylan and Mosiah still have their cars in the shop being worked on, Im still workin on my Shortened EA82 wagon , with the jeep transfercase , each week is different, come on out bring a project , looks like Rollie will be starting up a new build soon, so we need to clear out the shop:eek: SJR -
I run 27" tires wouldnt go bigger for hill climbing does your car have a dual range
EA82 engine crossmember into EA81 car.
Scott in Bellingham replied to s'ko's topic in Subaru Retrofitting
on those blocks I could produce a hybred block with a ea81 Top with the EA82 bottom, that way the stock EA82 strut and strut tops could be used , be 5" or 3-1/2" tall with the tooling I presently have , or tool up for a 4" SJR -
The end of my lifted wagon (56k warning)
Scott in Bellingham replied to bushbasher's topic in Off Road
how do you like having the front diff welded ? whats it handle like with both front and rear locked up? -
details and pictures of damage would be nice
thats great Rollie keep up the good work, hey Noah check out this autobody technique http://www.loghomefamily.org/subaru/videos/WalkerApr06NoahDirt1_Low.wmv :brow:
13" Justy wheels ?
Scott in Bellingham replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I tried a honda and a toyota rim both have the right pattern but the center hole is to small hits on the front but not the back hub -
had this other thought maybe run a cable from say the bumper mount back to the front radius rod bolt , then the force might transfer threw the cable and prevent the bar from bending
even stock angle bends
13" Justy wheels ?
sounds like it should be easy to find a set, I have a set of 13" snow tires I wanted to run this winter thanks everyone, -
stiff Yes ,it would only want to give just befor the point of were the radius rod would bend
