Everything posted by Scott in Bellingham
1988 subaru turbo GL, EJ22 and 4" lift, plus 6lug swap build!
I run 2" at the front or rear diff and 3" at the rear
Lifted Rigs 2012 roll call
87 DL FWD chrome gearshift knob EJ with a carb CB radio thats all http://s444.photobucket.com/albums/q...11-5-11154.mp4
Spokane EA81 Lift Help. 84 Wagon Possible trade?
you got a EA81 I do 14-15 degrees on the towers
ea 81 lift questions
the EA81 axles have shorter and weaker cups , compared to a EA82 axle, the center shaft moves out farther if you just lift the strut making it work towards the end instead of towards the middle or bottom of cup, also bad moter mounts will cause axle issues,
Shout outs too ....
internests? never heard that one
EA81 front leveling options.
I just got this 2" lift done for a board member, thought Id post a pic
on the EA81 I wouldnt recomend just lifting the struts, those axle dont last long like that , I would suggest lifting the struts and the engine crossmember, if your just going for a inch the tranny mount/radius rods can stay stock
We took a group up to Walker Valley. pics
is that woodys jeep on its side?
Shout outs too ....
it was good to meet you guys good luck with the cars see ya on the trail soon Scott
need a comparison please
D/R front and rear axles seperate so you need 2 wheels to spin to get stuck, AWD has a center diff so Just one wheel spin to get stuck D/R has the lowest gear Ive had both with 5 speed , no knowlege with auto
Wagonstien taking fully independent suspension to the next level
looks good, by chance do you know what stock rear axles are the strongest? I would like to build a offroader but need to know whats the strongest ones, I think I found the weakest ones :lol:
Garage sale SJR
3" blocks with 4" struts thats what my 4" kit comes with its only 1" over stock
Garage sale SJR
yes could be done, if you want set of 3" towers I can do a set for $110
rear ea82 diff drop alternative?
$25 shipped with no bolts
Garage sale SJR
still have sorry wont bend they are as is
both ways are done, with the plate the bar stsys up high less prone to bending on obsticles
Check this out if you wanna Go Wheeling are Stock and are in the PNW!!! Free 2" lift
Driving technique helps, but when you take parts that are 20+ years old and use them to there extreme things give out faster then normal , keep the tires small and go gentle and things last longer,
EA82 lift
theres 1 bolt that mounts the shifter to the body, drop that down and forward with a piece of flatbar, not 4" more like 2"
6-Lug Redrill Questions
even with 215/75-15s you will need to trim on a 4" lift, both lifts from me SJR give 1" stress over stock on the axles , I would recomend 26" tires on a 2" lift Scott
I usea 14MM for the hub holes thats for stock subaru studs
Merry Christmas all.
my Daughter woke me up at 2:30 am , she went back to bed, and we got up at 6:30, opened a bunch O stuff, went to church and now we will just stay home and enjoy the family and our gifts anf oh we will be makin homemade pizza later , this has been a good year for me , thanks all for your Friendship and Patronage Scott the "S" in SJR Merry Christmas !!!! and a Suubbie NEW YEAR !!!!
31 inch tires
heres one 87 GL 31" swampers
31 inch tires
axles are a little weak, its been done but will lack low gears, a built engine with low torque would help , will no low gaers you will need more lowend power , I run a EJ22 with delta Low Torque cams on my stock subbie witha 6" lift run 30" tire ( wore out 31s) works well just breaks stubs with a welded rear diff, what are your plans?
Rear Crossmember Bolts
I have a good PNW crossmember if you need one
ea81 lift questions
get some tubing say 2x4 -1/4" thick cut all the blocks and drill the hols the only hard part is the front struts they need to be at a 14 degree angle and the 2x4 blocks wont work there some 4" pipe and some plates or heres a set Ill sell ya at www.sjrlift.com
