Everything posted by subie94
sweet lookin impreza hope when i finally get the outback struts swapped into my legacy,it looks that good.also gonna have to see about ob tires an wheels. by the way,those that have legacys,imprezas,etc would you do the strut swap or lift kit(when an if available)
which brand,an where'd you get em? did a quick search an couldn't find anything decent as far as aggresive tread.
gonna have to visit home depot an give it a try
it's amazing what the brats can handle.hope to own one someday
even though i don't own a 2.5 with the hg prob,a friend of mine that works at the local dealership told me that the prob was being caused by bad gaskets.apparently they used some new type of gasket that had a coating on it.an during warm up an cool down,the slight shifting between the heads an block would wear down or scrape off the coating causing it to leak through.hence the overheating prob.
trans fluid an filter might need changing.it doesn't feel like trans is slipping does it.you know-give it gas,hesitates,then kicks in an then it gos.that's what my 86 gl auto 4wd did.needed fluid an filter changed,also used to lose fluid so it was usually low on fluid.
My reader's ride article is up!
subie94 replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks good.well writen out -
holy crap check out ebay.
subie94 replied to tailgatewagon's topic in Historic Subaru Forum: 50's thru 70's
dang bad credit got the room to start small collection too...just not the money -
looks good,to bad it's small to put in a lift or is it:brow:
1600cc is egual to 1.6 liters i take.1.8 liter engines are the smallest ones i've seen in subies.most of the imprezas i come across are either 1.8 or 2.2 alot of the times when i've searched for parts on-line.most of the time i needed to supply model an trim package.occasionally i had to give engine size.
Looky... Looky...My new Exhaust (with pics)
subie94 replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i take it that's $140.00? (or $14,000. ) strict about emissions over there? or something -
Alternator
subie94 replied to mudduck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
i'm gonna take a stab at it.if they haven't really changed since 94 then 70amps.but i'm guessing they did change so it might be up to 90amps now like i said before i'm basiclly guessing at it,so don't hold me to it.the 70amp rating is from my owners manual from 94 -
ok so i'm ten days late,happy b-day zap hmmm so 5 yrs you say hmmm
my 94 legacy gt holds 15.9 the other week i tried figureing out my mpg.i really hope i did it wrong cuz i came up with like 11mpg :-\ now hows it go-you fill up the tank,reset trip meter,next time you fill up again divide how many miles you've traveled since first fill by how many gallons it takes to fill up again. right??? if so then i screwed it up by misunderstanding how to do it.
