176
Everything posted by lmdew
Larry Dew
1057 Dancing Horse Drive
Colorado Springs, CO 80919
my PayPal is my email - Lmdew@hotmail.com
Thanks, Larry
Does it do it when it's up on jacks as well? Can you push the piston back into the caliper, take a screw driver and get it between the pad steel lip and the caliper bracket. It should push back in with steady pressure. If it's blocked, I'd crack the line up at the top of the wheel well and see if it goes easy now. If it does, the flex line is the problem. Otherwise work you way back to the MC. Lot's of brake bleeding will be needed if you open the system this way.
Go under the hood and check the battery terminals. If they are loose or have corrosion all over them, clean them. Follow the red wire back to the starter, make sure the terminal is tight there. Give the starter a good wack with a rubber mallet or wood handle. Some times the contacts stick. Have someone try to start it and listen for the starter to click. If you have a meter, you can check voltage at the battery and then the starter. If there is no voltage getting to the starter nothing will happen.
Brakes will swap over with some work on the rears. Inter front seats will bolt in the backs are larger You'll want to pull the ECU and all the wiring, this will not be plug and play. Front Struts should bolt up, you may need to change the top mounts over. The exhaust will have to be modified to fit the Impreza.
Yes, I"ll have to get the wiring diagrams out and the meter. This car was not running when I got it, so this problem may have been there for a long time. I've never had any problems with the 2.5 to 2.2 swaps. As the code comes back on right away, won't clear if the car is running, I'm pretty sure its wiring.
Dropped a 95 2.2 into a 98 Outback. The PO325 Knock Sensor Code won't go away, the sensor is reading 550 ohms of resistance, same as the spare one I installed. I'll get out the wiring diagrams when I have time. Just thought I'd post here to see if anyone has had wiring issues with the 98 Outback knock sensor. Thanks, Larry
I almost bought a nice 2003 Outback off Ebay for $5300. Not a steal, but a one owner according to the Carfax. It was in NJ and now in FL. I flew to FL to pick it up and didn't drive it 10 feet when I felt the drive line vibrate when I took off in 1st. U-joints I suspect, but with a 2000 mile drive ahead of me I said no thanks and walked away. I had it up on a rack and saw the East Coast rust and knew I'd never like working on the car. Cost, 1 day off and a hotel room. Repeat stay in CO, Stay in CO. Larry
