Everything posted by lmdew
computer ground
lmdew replied to subpoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCar Details? Year and Model? Most of the ECU have a ground wire in the connector but it's always a good idea to have the case ground as well, by bolting it up.
Reinstall Torque Converter
lmdew replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX3 steps as it goes in. When you mount the trans, if the TC is all the way back, the flex plate bolts will pull the TC about a 1/8" forward.
p0325 knock sensor?
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLearn something new each day!
98 Legacy L 2.2 stuck in FWD. Fuse not in use.
lmdew replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck and see if the rear drive shaft is spinning when the front wheels are but the rears are not. I've seen where one of the rear axles had popped out about a 1/2" and the rear drive shaft power was not going anywhere. Installed the rear half shaft into the rear differential properly and problem solved. Pretty quick check at the rear diff, just make sure both half shafts are fully inserted.
How to remove torque converter
lmdew replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might pull the timing belt and allow the valves to close by turning the cam. The piston/rod should move out of the way. Have you tried counter clockwise?
p0325 knock sensor?
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they will do that. Just make sure you get the bolt started by hand so it's not cross threaded and the sensor points back into the lower section of the block. It retards your timing so low power and poor gas mileage.
lmdew replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1/2" breaker bar, try rotating it in both directions. If that does not work, pull the oil pan and push the broken rod out of the way.
Used parts standards
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith the hubs you can not verify the bearing is good or not until it's installed and you take it for a drive. Really bad ones are easy to spot, but other than that it's a roll of the dice.
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat side do you need? I may have one. If you get one from Car-part.com go for a rust free state.
Side mirror replacement 98 Subaru Outback Limited
lmdew replied to Phoenixilva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes and I'm sure there are plenty of them in the self serve yards in Denver. Pull the door triangle trim - forward on the door. It pops off, gently pry it off close to the pins. A painters 3 in 1 tool works great. Remove the Door panel Remove the electrical connector Remove the 3 screws holding the mirror.
97--98 lagacy wagon manual transmission
W What's wrong? Lots of good Subaru help in OR.
93 Legacy Problem
lmdew replied to legacyguy93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the starter clicking? Do the headlights work when the starter does Not? Along with what the others have said the starter main contacts are prone to wear. When the main contacts within the starter are not good, no power is getting to the starter motor. When it is NOT working, Read voltage under load - key in the start position at: Battery + to ground Starter + to ground Starter Motor + to ground Make sure all the grounds are clean and tight. One fellow had a pitted ground at the rear engine negative ground wire and his car would not charge. Fixed the ground and it was good as new. He had put in 3 alternators.
98 impreza obs, no luck finding ej22
lmdew replied to nvu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com I've had engine shipped for $200 or so half way across the US.
2006 Forester Headlight - Water inside?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks
We live in CO so it more of a leak I would think. Beside replacing the assembly, anyone have luck with a good fix?
coolant not returning to readiator
lmdew replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, HG can do that. What's the Temp gauge doing? You can also check for Exhaust Gases in the coolant with a test Kit. Many time the HG will not leak until the engine is up to temp and under load.
Outback Control Arm Rear Bushing Leaking
lmdew replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave 4 spare driver side A-arms. Shipped from CO.
1998 forester cooling issues
lmdew replied to lichen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPM you
98 Impreza Wagon heat cuts out
lmdew replied to drumkendrum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, I missed he was on High Speed. I have some spare fans. $20 shipped
lmdew replied to drumkendrum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe resistor pack is about an 1" square and about 2" long. There is a electrical connector and 2 screws that you will see on the air ducting under the glove box. Remove the connector and the screws pull it out. Put the new one in. The link shows a nice picture on amazon. https://www.amazon.com/Wells-JA1230-Blower-Motor-Resistor/dp/B000EQO07O/ref=sr_1_3?ie=UTF8&qid=1532083883&sr=8-3&keywords=Subaru+Impreza+fan+resistor
lmdew replied to drumkendrum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a resistor pack in the air box ducting below the passenger glove box. It's most likely going open, no voltage to the fan. Then the circuit closes providing power again. Easy change 2 screws and a plug.
exhaust donut issues
lmdew replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have to get all of the old stuff out. I use my 5 & 1 Paint tool and then a rasp to clean out the old stuff. It's a bit of a pain on your back but that's what it takes. The shoulder bolt will pull tight against the front flange. Spring is on the back side of the rear flange.
Dealer Service Recommendation
lmdew replied to cplourde's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, find a good Independent Subaru shop (like GD's) and establish a relationship with them. You and your Subaru will be happy.
In search of single port Y pipe
lmdew replied to Toadspit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNormal to have a little valve ticking as the lifters pump back up if it has the hyd lifters. It can last a week or two. I love the 2.2 engines so easy to work on and very few issues if taken care of.
lmdew replied to lichen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know a fellow on near Honolulu that has a great 2.2 for you to do the Swap with. Much less than doing all of the engine work to fix the HG on the DOHC engine.
