Everything posted by TomRhere
bad ball joints?
It's one of those, "might-as-well" things. You're there changing the axle, have a possible bad ball-joint, so might as well do it now. Would also check the tie-rod ends while you're at it. Cost of new parts isn't very much, and the piece of mind is priceless.
'82 BRAT + ER-27MPFI/DR-5spd
Those pics are exactly how the EA-82 fits in there now. Are those before, or after BFH? State Law here, limits the over-all height of lift one can do to a vehicle, so I have to work with that in mind. But, I should be good to go, even with a 6" lift combined with the tire size, and still be at or under the max allowed at the rocker panels. Have to check on what that limit is now, they've changed it a couple of times. When they set the first limit, you legally couldn't drive a new Ford 3/4T 4X4 off of the lot, it was to tall. The T-case mod is further down the road, as I won't have all the pieces for it until the end of May, or there abouts. I was wanting to wait on doing any kind of lift until that time. But if need be, I will do a bit of lift now, just to fit the engine in. I have ideas floating around in my head, for some suspension mods to go along with the T-case mod/lift. Those will take a bit of time to fully figure out, and test. But, if they prove-out, it will be good for all owners looking for improved front-end performance, and handling issues. I will try to keep in mind, fitment for a non-lifted rig as I plan this out, for those who don't have a lift under theirs.
Radiator??? More worried about keeping the Center Light than I am worried about the radiator.
Scott did a 8" lift to his, and says that it needs to be done to fit engine properly. Adam says a BFH with proper application will work to fit engine properly. Question here, Ifin I do a subtle 4" lift, will that be enough, (for the time being), to fit engine in? Have the scrap stock steel at the shop to do that, ifin it be nessecary. The EA-82 and EA-27 are supposed to be the same width, from what I understand anyways. I have the EA-82 in there now, and yes, it's tight. But, no real fitment issues, as far as frame is concerned, just the HH and Master cylinder. But that is an easy work around. I have weak motor mounts on the EA-82, so the engine does rub the frame on hard pulls. I can go the 6" or 8" lift if needed, but don't have rims/tires to make it look right, at this time. 8" of body lift, with the stock 13" tires would look way re-diculous. No want to go that route right now.
Well, the garage has been cleaned out. I now have atleast 75% of floor space back in a 2-car garage. So............. It is time to pull the BRAT in and get busy with the engine/tranny swap. I'll be pulling her into the garage after work today, and will start the dismantling. I plan on dropping the entire engine/tranny unit with crossmembers attached out from under the vehicle. I'll get the ER-27 bolted to the tranny, and get the nessecary crossmembers attached. Do some measuring for a few ideas, then stuff the unit back up where it belongs. I do plan on taking care of a few details while the engine bay is empty also. Like repositioning the hill holder, or just get rid of it alltogether. Seeing what if anything can be done with the master clylinder, as in moving it closer to the firewall for more clearence at the engine. Maybe a bit of clean up and repaint in there too. I will also be doing some R&D type stuff for a planned lift and suspension mods to the BRAT. Lift will be needed for the planned T-case mod. It's in the works now, just waiting on parts to be aquired. Trogdor is working on those for me. Thank you kindly. Lots of ideas floating around in my brain here, will try to fish afew out and see how they work. Over-all goal right now, is to get engine/tranny in. Get it fired up and debugged, and driveable. Not sure yet if I'll use the stock XT-6 exhaust for now, or fab in my 2" dual set-up. We'll see when I get to that point. Was going to do some body work, but that will have to wait for another time slot. Notes will be taken, and pics as I can get them. I don't have a working camera here, really need to get one though. I'll keep you all informed as to progress and anything I find out in the R&D section.
Pics of BRAT painted UPDATE New tire Pic added
:burnout: Looking Good!!!
Ea81T to carbed conv. How do i get the fuel pump...
Seeing as there is a great difference in years here, I can't give you the exact wire colors to use, as they no doubt be different. The FP on my '82 wouldn't run at all on it's stock wiring, and PO had it hot wired to a switch off the battery. I didn't like that idea, so.... I found a "key-on" hot wire under the hood, used that to power a relay. Ran hot wire from battery, thru a fuse, to the relay and then out to the FP hot feed. Works like a charm. Didn't do it at first, but I did install a pressure switch on the oil pump. This switch closes it's contacts when it sees pressure. I then ran the ground wire for the FP relay thru this switch. No oil pressure = no FP running. I can't find the receit for the switch, so I can't give you the number of it. I just told the counter guy what I was wanting to do, and he hooked me up with a switch. By the way, my FP is way noisy too. Rattles something fierce. Don't know if it the original pump, or if it was swapped in when the EA-82 was swapped in. But it does it's job, so I can live with a bit of noise.
T-topping a DL brat vs. windshield -- Chef Tim?
Been talking to friend (Lynn) that does body work. He says it will be nessecary to have WS and Slider out to do the graft. Mainly 'cause you have to weld in the top. After a whole lot of fitment trials and subsequent grinding of parts to get it to fit properly. Shouldn't have any leaks, if it's done right. Lynn and his F-i-L, know body work. Wonder how Tim had his Hatch done? Guess we won't know that answer now.
I recently noticed this, 82's and ER27's
Maybe it's because the '82 is a unique vehicle itself. Basically, different than the rest of the BRATs, while still being of the same group. So we just make it more unique, by swapping in a different drivetrain set-up. Haven't actually started on the swap yet. Was/am still amassing needed things for it. Plus, I had to get the '84 more reliable, as it will be my daily driver for the duration of the swap. Part suppliers held me up there. "It'll ship out today", so I waits and I waits, but no parts. Then get email saying that they just shipped the order, a week and a half later. Now, it's time to do a quick purge of the garage so I have a bit more room to work in. Then it's on to the "82 and it's transplant(s). Main goal right now, is to get engine/tranny in and drivable. Then, I'll be doing some R&D on some suspension ideas I've been contemplating also. This will be for the planned T-case mod and it's needed lifting of the BRAT. Let y'all know what I find there. Maybe nothing. Maybe something good.
Ac compressor for onboard air ( Attn:rooinater)
Spelling is probally all wrong here, but I tried anyways. DoMo Arigato, Nei !!!!!!
seeing as how the ER-27 has one on it. What about those types of AC compressors? Just add in an in-line oiler on the intake side, and I'll be good to go? I know about the control side of operation, just not sure on the mechanical side of these units.
Swap is done but it wont start!
Sounds like ignition timing to m, too.
lift confusion!
Yep..... Get a "GOOD" Plasma Cutter, and you will, almost, want to toss the cutting torch! We used to have one at the Plant. But someone decided they needed it better than we did. Really sucks, that does!!!!
Anyone out there with FSM for '82 BRAT ?
Scott, I have copies of most of the XT-6 wiring diagrams, got them from Dima over on the XT site. I have enough of it that I'm comfortable with it, other than that Damned Diode in the Fuel pump/Ignition relay's circuit. But you, Adam, and Arch seem to have gotten by with out it. So, I'll give it a go, myself. Qman, You're getting some mail. Would like some of the wiring diagrams anyways. Just makes trouble shooting circuitry that much easier. Thanks guys!!!!!!!!
bump
ea81 Brakes and Tranny.
clutch?, and maybe rear seal on engine. There's a fix for the sloppy shifter on here somewhere, but can't remember who did it. They have a pic of it. Basically, you saw-cut the part of the linkage, (the piece that goes over the shaft coming out of the tranny). Make the cut, 90* to the pin hole, and a bit past the pin hole. Then drill the pin hole out to fit a bolt, in both the shaft and the shifter linkage. Install with bolt/nut and tighten. No more sloppy shifter.
Got an Accell
Just bought the Accel coil/wires for the Wife's ride. I'll be installing them a bit later today. Along with new NGK plugs, and the rest of the normal tune-up/maintenance items.
deep pan for the summer
More oil is always better. Oil aslo helps cool the engine, so more oil means it stays in the pan longer to disapate more heat. Also, more oil means longer oil life between changes, (helps lessen the thermal breakdown of the oil). Bigger oil pan + oil cooler = even better set-up!
u-joint
After removing the axle nut, tire/rim, I drive the pin out, then remove the pinch-bolt from the knuckle where the lower ball-joint is. Now, using hammer of choice, and a block of wood, (I use a block of aluminum), drive axle towards the center of car, it won't go in far, but willl release some of the hold that the bearings have on it. Now, turn the steering wheel towards the side that you are working on. This will give you more room to swing the knuckle out. Now, wedge a screw driver into the slot to help release the ball-joint, using a pry bar of choice, (mines a broken shovel handle), lay prybar across the reaction rod that is bolted to the control arm, and put the end of it under the engine support right about where the E-brake cable is attached to it. Press down on pry bar, freeing knuckle from ball-joint, swing knuckle out to remove axle from tranny stub. You can now drive the axle out of the knuckle the rest of the way, straighten wheel out if you need to. You will probally need a long prift punch to drive it all the way out. Only one bolt to remove this way, and less chance of damaging the tie-rod end. No offense to anyone that removes tie-rod end. I put the new axle on tranny stub first, (pay attention to the proper alignment of the pin hole here), then swing knuckle out to install axle into knuckle. Will work either way, you can put axle into knuckle first ifin you want to. Axle will probally not come thru knuckle far enough to get the washers and nut on at this time. So just use the nut itself to draw it in far enough to get the washers on it. May even have to give the knuckle a few mule kicks to start nut onto axle. Axle nut torque is 145 ftlb's, but really way tight is what you want. Last axle I changed stated 170 ftlb's for the nut. Would suggest rechecking the torque after driving around for a few days. I talk more than the rest of them.
Old School Representation *Warning NC-17*
Send me more pics, PLEASE! Trogdor sent me the link to that last night, and was wondering ifin it was your ride. NOW, WE KNOW THE REST OF THE STORY! Wasn't sure myself ifin it was your ride, mainly 'cause the front-end of the wagon looks different. Maybe I was distracted, don't know on that for sure. But yes, please send me more of those awful degrading pics.
Mine's a California model, atleast I'm thinking that due to the sticker on the winshield stating that it conforms to Ca. emission regs, as of DOM. Plus, there's an ECU under the dash. I need some wiring diagrams to ponder over, for when I get busy doing the ER-27 MPFI/DR 5spd swap. Which, hopefully, I'll get started on this coming week. Last of the needed parts for the '84 showed up here yesterday. So it's time to get it tuned-up, filter changes, belt, hoses, PS axle, whatnots. Then it's on to the '82. Any and all help well be greatly appreciated.
mpfi conversion, what not to do
1. What was the answer to this post, http://www.ultimatesubaru.org/usmb/forum/showthread.php?s=&threadid=12332 2. Been discussed on here before, about using carb fuel pump to supply MP/SP-FI pump mounted under hood. Not sure of the out-come of that discusion though.
I need some advice
If I read this right, you have removed the cat from the exhaust, (it was in the Y-pipe). If that is true, you will need to plug the hoses to the AIS/ASV systems, (at the air filter can), or just plain remove those systems outright. Those systems pump extra air into the exhaust to aid the cat in doing it's job, hence your unwanted noises. I did this to mine when I installed the 2" exhaust system, and had the same burbling and kapows from the exhaust on decelleration. Tended to PO the nieghbors at 5:AM. I removed all of the AIS/ASV crapola, and plugged the steel lines where they come off from the exhaust ports. As far as pipe size goes, I'm running full 2" duals, no cross connection, turbo mufflers, and the Weberized EA-82 seems to like it. (Nice ear candy too) Others are running 1-7/8" from the engine to cat, (if needed), then 2" on back, thru muffler of choice. Been lots of debates on here over pipe size for the Soob engines. I went with 2", because it matched the port size in the head. Just seemed to be the right thing to do.
New lift idea
That mod would give you the capability to adjust for camber and castor (albeit limited) of the front wheels. That would be a great benefit on a lifted rig. Think it would be of greater benefit to have the shaft of the lower arm, threaded at both ends though, with left hand and right hand thread. That would make the adjustment of camber part a bit easier. Having adjustment on the other rod, would allow for some castor adjustment, but not much. That is usually done at the upper end of the knuckle. But, it may help get the wheel more centered in the fender opening. Which could be of some benefit. One drawback I can invision with having a more or less solid mount on the rear rod, would be transfer of road noise and bump shock to the body. Could be a bit annoying. Have to ponder that idea, and see if I can improve on it some.
where to get bushings
http://www.alloemautoparts.com/
