Everything posted by TomRhere
trying to figure out the brat
Do believe those plugs are for power window controls. The rather large relay is the Stop Lamp checker. Lites the "Stop Lamp" on the dash if one of the stop lamps goes out.
Ideas for an XT6-
To bad I'm not closer to you. I have 2 - ER-27's sitting out in the garage.
Jump Seat Mounting
http://www.ultimatesubaru.org/photos/data/500/bracket1.jpg There's a rough sketch of the bracket. It's made from a 1" wide strip of sheetmetal. Would've posted pic, but camers is MIA thanks to Son.. edit; There is supposed to be 2, 5/8" long feet on the bracket. Don't understand why it shows only 1, I drew 2......
got prob with 4wd on my brumby
Different size tires can cause binding issues, along with tires of different manufacturers. Tire size may read the same, but overall diameter can be different.
look what followed me home....
Nice looking BRAT!!!!!
Jump Seat Mounting
There should be brackets on the front wall of the bed for the lower end of the headrest track. Sounds as if someone cut those off for what ever reason. Sorry, no pics of them. I can get pics latter today, or tomorrow.
good idea? mod out 85 brat?
The EA-82 engine will fit between the frame rails of a 2nd Gen BRAT, Hatch, Wagon, Sedan with no re-work. Tight,,, yes,,,, only 1/4"-3/8" clearence each side between cam covers and frame. But it does fit.... Can't really say that all of the lift will fit, but do know that the bolt pattern for the engine crossmember, and the mount plates for the radius rods are the same between EA-81 and EA-82, it's just that the EA-82s are wider. So if the lift isn't tied together at those points, it should bolt up. Then you have the strut top difference, 2 bolt vs 3 bolt. Scot, (SJR) made sko a set of strut lift mounts, EA-81 top and EA-82 strut end for his BRAT, so it's doable. The rear is a whole different story....
opinion 91 fwd ,a/t sedan,
That,, sounds scary to me!!!!
timing alignment help?
http://www.economysuperstar.com/milesfox/subaru/service/timingbelt.htm
Happy B day Mick!!!!
Happy B-Day!!!!!!!
Weber Secondary Sticking Open
Two things I can think of that might cause the problem. To much travel of the linkage when you floor the pedal to set the choke. Try adjusting the cable for a bit less movement by turning the adjusting nuts more towards the housing of the cable. A binding of the linkage for the choke and the bellcrank of the throttle cable. Mine did that when I first put the Weber on. Did you put any spacers on the throttle shaft between the Webers linkage and the bellcrank for the cable? That's where mine was binding. I put a couple of flat washers between the pieces there, no more binding.
EA81 to EA82 intake manafold ??
Here's a shot of the difference in size of the carb ports of the manifolds. http://i29.photobucket.com/albums/c264/TomRhere/Weber%20swap%20on%20EA-81%20engine/EA-81EA-82Manifold2.jpg
what would fit?
Front seats will bolt in. Makes for a nice upgrade if you're needing new seats. I believe there's a how-to in the USRM on installing the EA-82 dome light into the EA-81 body.
EA81 and EA82 Trans Swap
It's cheaper to get the 2-piece from a yard than it is to have a longer 1-piece shaft made is what he's saying, I believe..
EA82 Emergency Brake Handle
I don't know how easy it would be to do so without tearing this one apart, and I don't plan on doing that. You'd have to either tear into yours, or get one from a parts car to tear apart and go from there. As far as a cup holder goes, my travel mug sits nicely between the e-brake handle and PS seat, but that's in my BRATs. Been to long since I drove the XT6 to remember if it fit there or not. But the need for one in your ride is different than mine. It'd be your call....
Here's a couple pics of the assembly showing both sides. Pics are located in my photos..
I was just out in the shed digging around and ran across an EA-82 E-brake control. You won't have to mess with the cables themselves, other than to disconnect them to remove the handle from vehicle for planned mods. You will however need to mess with the release button mechanism so it will still operate after you mod the handle. And it will take slightly more effort to operate E-brake with a shorter handle, as you loose some of the advantage of the fulcrum effect of the lever action.
One could shorten the handle so that it was no longer than the hand is wide. However, that would require more effort to operate the E-brakes.
starter problem not covered yet
I can't say anything about the wiring issue you have, but the starter itself is dying. The whine you hear is the starter motor free-spinning at high RPMs because the solenoid isn't pulling the drive gear out to mesh with the flywheel. I've had a few starters of various makes do that and found it's usually caused by wear of the pivot point of the lever that moves the drive gear.
my Aussie Brumby
Man, that is one nice looking Brumby!!!
Stock Radiator Dimensions Needed
Here's the tell of the tape on the radiators I have here...... XT6 Dual Core; Total side to side width is 29-3/4" Total top to bottom height is 15-1/4" including locating pins Locating pin center to center is 20-3/16", length is 3/4" Both hose fittings measure 1-1/2" and slant upwards slightly Thickness is roughly 1-9/16" at core and 2" at seams. EA-82 Single and Dual core; Total width is 29-3/4" Total height is 15-3/4" including pins Locating pins center to center is 21-1/4", length is 7/8" Both hose fittings are 1-1/8" Upper hose fitting is straight out, lower is angled up almost 90* and out to the side of tank. Total thickness is same as the XT6 radiator for both the Dual and Single core.
ZRC Galvalite spray-on zinc (galvanize in a can)
Interesting reading. Sounds like some good stuff, I'll have to try some myself.
my front end...
Yeah, bent rims suck... And they're not the best thing to have on the front of a vehicle. Really rough on steering components. Good you found it. Thinking I bent my right front the other day. Was going around a lefthand curve and found a pothole the hard way. Now I have a bad shimmy at anything over 60 MPH.
What is this?
The FPCU is mounted on the DS kickpanel behind the fuse block, and is about the size of a deck of cards. So that's not it. Don't recall seeing anything like that item when I gutted my '82 BRATs interior. I'd have to go out and look at things to be sure though. The BRAT is a California model, had feed-back carb with the ECU under the steering column.
How to replace clutch?? (**With Pics of Install**)
With the engine slid forward from the tranny, there is enough wiggle-room in the tranny mounts to allow you to drop one axle off the tranny at a time.
