8
That's pretty damn cool!!
It's really not that hard to change out the diff if you have the right tools and know how. If you have limited mechanical knowledge, I don't know if I'd recommend doing it yourself since some parts can be a little tricky. I believe there are newer AT's with a 4.111 final drive ratio. However if you go too new, then you run into wiring differences. I'd say if you can't a 4.111 trans, but you can find a 3.90 one, just swap the rear diff. I don't think labor costs would sky rocket.
What year legacy? Here's factory scans for the SOHC 2.2 http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg Also, here's pics from my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt
I probably posted various pics before, but I made a page that I'll be updating as I go along. http://www.main.experiencetherave.com:8080/subaru/images/ej22t/ I split the block today, and cleaned the crank up. The rod bearings definitely need to be replaced. The crank bearings are ok, but I'm going to replace them anyway. I need to get the cylinders honed, and I'll be set to put her back together
