8
This is for the 90 legacy, but should be the same as the 91 http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page3.jpg
Well...if you wanted to put an O2 sensor in there, you'd need to make sure the ECU could handle it. I don't quite understand how it can be a fuel injected car and not have an O2 sensor. Are you sure it doesn't have an O2 sensor? There are some components that swap over from the imprezas, but unless you're trying to replace a broken part, I wouldn't bother swapping stuff over to give you any more power.
EJ22 swap done........motor wont start........
Legacy777 replied to ballitch's topic in Subaru Retrofitting
Do you have the legacy radiator? If so, there should be a burp screw on the top pass. side. If not......elevate the front end and see if that get's all the air out. Tach output wire is B56 pin 16. That lead actually goes to the TCU normally. The tach signal is sent via another pinout to the combination unit. I'm not sure which pin it is. but the B56 pin 16 should work. -
I know the 90, and I'm pretty sure the 91 legacy ECU's have a little green LED inside the ECU that can be seen through a hole in the case that will blink intermittantly based on the O2 sensor signal. However if you hook up the diagnostic connectors, it will flash the codes displayed in memory, if there's any there. -
What model & year legacy do you have? You should be able to use the struts without altering ride height, however if you use the springs, you will probably alter the ride height. Also, you can not use the rear suspension setup from the WRX sedan, it has a different top mount configuration.
Then 92-94 autos were a little weird....they had the 3.90 final drive ratio for some reason, while the 90-91's had the 4.111. What year & model did the rear diff & transmission come out of? I have info on the 99, and it says that the autos in the 2.2 had 4.111, while autos in the 2.5 had 4.444. About the only way I know of to verify would be to drain the oil out of the front diff, shine a light in there, and count the teeth on the sun gear and pinion gear. Even then, I don't know if that's definitely because the fsm shows that the sun & pinion gear tooth # is the same on the 2.2 & 2.5. So I'm not really sure. If you can post what model & year car you got your parts from, that might be a start.
If you were to put slightly lower springs & stiffer struts, it would handle better. A lot has to do with the suspension in the baja. The newer chassis are pretty rigid, it's just a matter of how the suspension is setup. I have a buddy with a forestor that has been lowered. It handles pretty good for a forestor. Still not going to handle as well with the larger profile tires, but everything is a compromise.
MAF sensors could cause it....I know when I had mine going out. The engine would intermittantly cut out and lose power. It finally one day left a code for the MAF sensor. If you can find a MAF sensor cheap, it'd be worth trying to swap out the parts. You could try cleaning it with a light spray of brake cleaner. If you do this, you need to be very careful with it.
