8
The 5 wire MAF sensors are only needed on the first gen legacy, 90-94. This is because they used two different types of MAF sensors. The extra two pins were a reference voltage from the ECU and a ground. This extra pin being grounded was like a switch. If the incorrect MAF sensor was used the ECU would know and illuminate a CEL. This diagram may help show this http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/MAF_testing1.jpg All you really need is three wires, power, signal, and ground
Thanks for the feedback! I definitely agree with you on learning how to set things up but didn't know if the auto set was a gimmick or not.
Out of curiousity, anybody have any experience with the millermatic machines with "Auto-set"? How well does it work to have the machine pick the feed speed & voltage?
No, you will need an injector from a 1990-1990 AT model Legacy to use. I'd suggest checking out the http://www.bbs.legacycentral.org forum. Someone probably has one they could sell you. Have you done any diagnostic work to verify that the injector is bad? I'd suggest doing that first before replacing. While idling, try pulling the plug on the injector. If the engine doesn't run any differently, then I'd definitely say that injector is bad. If the engine does run worse, I'd suspect the injector may still be ok. If that does happen, I'd suggest replacing the canister purge solenoid and then clear the codes, drive the car and see if the injector code comes back. The #1 cylinder is the front passenger side of the motor. As for the purge valve, I believe that should work.
What is pin 4 supposed to be according to the manual? O2 sensors of that error are going to have three wires going to them. One is the sensor signal, one is 12v for the heater, and the other is ground for the heater. Typically, red & black are the heater power and ground. It should be easy to determine those wires. Once you determine that, you can then the voltage on the signal wire.
