8
Welcome. I'm pretty sure the airbag light should go off if the airbag computer does a diagnostic and everything is ok. As for the various sensors. Without knowing the type of impact sensor, it'd be hard to say for sure whether you need to replace them. This page has some good info on the various type of sensors. http://www.aa1car.com/library/airbag01.htm You may want to call a local subaru dealership and see if they may be able to tell you the type of sensor and/or whether the sensors should be replaced.
I have both SAE & Metric. The SAE doesn't get used much, but when I need an SAE tool, I need it.
What modifications do you have? That will most likely be too large of a turbo for you to effectively use unless you have a decent amount of supporting modifications. Plus turbo lag will be much more pronounced compared to stock. BTW, do you have the 2.0 or 2.5 WRX? You may want to also check out http://www.forums.nasioc.com/forums for more info.
I guess my one suggestion is get something big enough for future expansion. I've got two craftsman boxes (more or less one setup), and could use some extra room. It's not critcally needed at this time, but I could use it. http://main.experiencetherave.com/images/newplace/DCP_2260.JPG http://main.experiencetherave.com/images/newplace/DCP_2262.JPG I've since added a little hanging section on the right side for some extra drawer space for screwdrivers, and other misc stuff. I did end up buying a large storage cabinet, so that will help with keeping some of the larger tools. However it's not rollable. For what I do, it's not that big a deal though.
As mentioned the OEM rebuild kits are pretty good and come with all the gaskets. In addition to the gaskets, I also replaced the bearing. It was relatively easy, just press it off and press the new one on. You just need to keep track of all the parts. Only thing I forgot was the spring behind the regulator/bypass valve on the discharge. Here's some pics http://main.experiencetherave.com/subaru/images/psteeringpump/
That's an interesting read on Ed's red.
Two things I would suspect. First, are you sure you got the correct clutch/pressure plate for your vehicle? Did you resurface or do anything with the flywheel? Second thing, would be that it didn't get installed correctly. The chances are pretty slim that the hydraulics are bad since they worked before you swapped in the new clutch. Are you sure you have the clutch fork installed correctly?
We don't have too many snakes, however we do have frogs & lizards
