Turbone
Administrator
    30
Everything posted by Turbone
  1. Your .02 adds up to about $20 each. Thats $40 a side. Not that cheap. You can get them alittle cheaper, but you might be sacrificing quality.
  2. Yes, the bolt pattern is the same. But the offset isnt, the brake caliper will not clear the inside of the wheel.
  3. Thats a yes on the 2nd question. No points to change or adjust. But with a electronic disty, you may need the ECU to go with it.
  4. Arrg, just for that (56K) you are going to have to bring the tape with you when you come over for that motor.
  5. I have never heard of a GL with a D/R (5spd? You didnt say) with LSD and the button you talk about is a diff lock. Its usually in a Turbo car. The LSD will most likely be a 3.7 ratio, so your tranny needs to match. Or you can convert the diff to a 3.9 too. If you want to offroad your car, you need the D/R. Its the best tranny for it. The one you saw with the button on top is a single range.
  6. Digidashes came in EA81's and EA82's. Which one are you talking about? Oh yeah, have fun making it a dual function
  7. I'm on alot, just invis. People are what make up the Board, its always best to meet the folks that you correspond with. And it helps put faces to names. And the suprises you get when you first meet Like "He's exactly like I thought he would be" or, "Damn, he's nothing like his board personality Some people are open and post alot on the Boad and when you see them at a show or meet, they end up being quiet introverts. Go figure And it goes both ways. Just dont take first impressions (on the Board) as what the person is really like.
  8. You most likely sucked water into the cylinders. Take out all the sparkplugs and crank the engine over(disc the coil). Dont stand beside the engine, you'll get a shower Would strongly suggest a oil change also.
  9. Turbone
    tracked subie
    Basically, they are only good for smooth terrain. I saw a episode of "Trucks" where they put a set on a 3/4T Chevy and put it thru alot of different terrain. It had problems in mud and on rocks, but did well on snow and smooth stuff. The rougher it got the more the suspension got hammered. It had problems with the track staying on and debris getting in the system.
  10. If you are going to have them blasted, then stripping them prior is unnecessary. Any blasting will remove any finish thats on there (duh)
  11. In the US, we had stickers on the Valve Covers that said "Do not adjust valve clearance". I take it yours did not?
  12. It "might" be part of the gasket, or the grommets that are on the valve covers
  13. The lower control arm has a bushing at the x-member, see if its loose. If you cant find the problem, bring it by my place this weekend.
  14. Eh, whats another year? Happy B-Day John.
  15. I would also check the bearing that houses the axle stub on that side. If you grab the end of the axle thats closest to the tranny and try and move it up and down, and it moves considerably, then the bearing is bad.
  16. XT6 wheels! Cool Again, I cant wait to compete with you Bro
  17. Yes, there is a little trick to the timing belts on a XT6. It has to do with the @(*$&% tensioner for the drivers side adj pulley. Sometimes it cooperates, most times it doesnt. But its nothing that cant be handled by the average Joe. I shudder if I even think of putting my car(s) into a shop.
  18. The oil return line is probably split, cracked ot loose. Its under the turbo and goes to the back of the head. And its a beotch to get to. Sometimes the best way to deal with it is to remove the turbo. Oil out the tail pipe could also mean that the oil seal in the turbo has blown. Lots of owners mistake this for a bad HG, and people like us get a free or cheap Soob
  19. Arrrrrrggg, I'm not ready Cant wait to compete against you Zap On another note, the engine is in the RX, just have to put the intake on and button things up (and clean it out).
  20. Valve cover gaskets are no problem. Believe it or not, the 2wd are supposed to be quicker. No extra running gear to slow it down. The car better be in excellent condition for that price tho, you can get a full time 4wd for that amount.
  21. I know someone local to me that has a XT6 with 17" wheels and low profile tires. It looks sweet and doesnt change the profile of the car at all. Just make sure all the tires match exactly when you get them.
  22. Ha, you havent been to Washington State yet. I'm going to take some pics tomorrow and show you the difference.
  23. Yup, thats what happens when you dont have the FSM in your lap Did you check the dip stick to see if theres any fluid in the trans?
  24. Brian, your sounding like a N00B I think theres something in the USRM and its been discussed enough in previous threads there should be several pages of info.
