28
Everything posted by Turbone
Need some advice on identifying 3 problems
Turbone replied to SubaruGL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
#1 is part of the emissions system and comes from the header exhaust port. #2 looks like the breather hose, it shouldnt be connected to anything. #3 looks like grease splatter from when a CV boot broke. It usually makes a big mess all over the firewall and exhaust. It will burn off eventually. -
The MAF adapter I got from someone on the forums. It was a few years ago, so I dont remember the details. Some folks go to Home Depot and get a dryer vent line connector. Not sure if this will work in all applications. I made brackets to mount the IC to either side of the spare tire platform.
http://www.picknpull.com/locations.aspx?View=Detail&ID=138&ClusterID=5 Or post up what you need in the Wanted forum.
BRAT automatic to manual conversion
Turbone replied to TajMan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, for a while I didnt have it connected. I had a TD04 WRX turbo installed also and when I left off the throttle from a hard pull you could hear the air slamming against the throttle plate :-\ This is what it looks like now.
Its a little different with the spyder intake, but most of the plumbing is the same.
Right click on img code, left click and paste in a post here. Simple as that.
http://www.ultimatesubaru.org/forum/showthread.php?t=121130
The principal is simple, the application in old school Subaru's isnt. Go to the Retrofit forum and do some searches for top mount IC installs.
Depending on what IC you use (WRX) some will come with a recirc valve. You dont really want to use a BOV. One line goes to the intake manifold and the larger line goes to the intake prior to the turbo.
4X4 Swapmeet in Puyallup Sunday Mar. 13th
Turbone replied to markjw's topic in Meet n' Greet. Your USMB Welcome Center
Yeah, I got a flyer for that the other day. Lack of funds will keep me from going :-\ -
U Pull It around Bellingham
Turbone replied to bratlife's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well think about it. If you bought a door and swapped it out, would you want the beat up one laying around? -
Do you have A/C? This is usually the place for that relay.
2 different routes to go for upgrading a EJ22T. DOHC = Frame rail adjustment in EA81 SOHC = Your best mod for a EA81 The 2.0 heads and intake are a good option and are easy to find. Also upgrading the turbo to a TD04 is a good mod. Make sure your trans is low mileage or in good shape. It wont handle this kind of power for very long.
The Big Northwest Meet
Turbone replied to Turbone's topic in Meet n' Greet. Your USMB Welcome Center
Only downside is there will be a entry fee. But it looks like they will have a lot going on and I would love to put my RX on the track if possible. -
Update, they have a website up. http://www.bignorthwest.com/ -
Have you ever bought from a regular wrecking yard? I bet its still cheaper at a PAP. And a FYI.....everything is going up :-\ -
Try the Smokey Point PNP (Arlington). http://www.picknpull.com/locations.aspx?View=Detail&ID=136 -
We are supposed to be one big happy family......ALL Subaru's. I try and get along with all of them, but theres always bound to be some bad apples in both crowds
55 EGR Temperature Sensor or Circuit
Turbone replied to drdan52000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This might help. http://www.ultimatesubaru.org/forum/showthread.php?t=49918&highlight=codes -
Get a hold of Rallitec in PDX. I think they were thinking/talking about a project like this last year.
If thats the case, the OP needs to a search here for divorced transfercase mods. The Nissan 4wd t-case is a great mod for a Subaru, my 86 hatch has it.
