Turbone
Administrator
    30
Everything posted by Turbone
  1. Dont know if this had trailer brakes or not, I never talked to the guy About 4-5yrs ago I used my 86 T-Wagon to move. I hauled all kinds of stuff in a 4x8 trailer, plus the back of the wagon. Only went about 4mi each way, but never had a problem (no pics).
  2. A tune-up would help rule out some of your problems. I would also change the fuel filter, this should be done at least once a year. The condition of the sparkplugs will show if you are running lean also. If the electrodes look like they are cooked, its been running lean. http://www.sparkplugs.com/sparkplug411.asp?kw=Detonation&mfid=0 Make sure you time it when the tune-up is done.
  3. Do yourself a BIG favor and replace the alternator with a NEW one, not refurbished. I say this because of the digidash in your car. Any spike or bad fluctuation in voltage will fry the regulator in the dash and render it useless. Finding another one that works is impossible and even repairing the original is extremely difficult. Your car is worth what the market will bear. If its sold on the east coast, it will go for more as there arent to many in that good of shape there.
  4. Check out Richie and his Dads shop, they can help you out and will do you right. http://www.superiorimportrepair.com/ And I always thought the worst enemy of any car was the driver
  5. I'ma no show. Got things going on at home I need to take care of :-\
  6. I swapped a EJ22T into my RX. The original trans had over 200K on it and was abused by the previous owner (me). It lasted 3 weeks after the swap. I had another RX trans that had lower miles and put it in. So far I've had no problems, but I dont do any hard launches either. I'm running a TD04 turbo with the boost at 10lbs, sometimes more. Look for my EJ swap in this forum.
  7. http://www.ultimatesubaru.org/forum/showthread.php?t=88249&highlight=TD04 Listen, if you want to keep it original, dont mod it. If you have any questions you cant find the answers too searching, send me a PM. WJM is also a good source of info for the EA82T, GD is not and is extremely biased, just to name a few things
  8. Awesome, nice to see another RX getting "The Upgrade".
  9. Their boxes arent deep enough for me. Ever look at the boxes from Costco? http://www.costco.com/Browse/Product.aspx?Prodid=11485563&whse=BC&Ne=4000000&eCat=BC|114|860|28175&N=4010045&Mo=12&No=0&Nr=P_CatalogName:BC&cat=28175&Ns=P_Price|1||P_SignDesc1&lang=en-US&Sp=C&hierPath=114*860*28175*&topnav= They have a SS model also thats a bit cheaper.
  10. If I get ambitious and replace a axle in my Hatch, I might come up.
  11. After replacing the disty cap and rotor, timing it might help.
  12. I was up there, sick and all I'm paying for it now tho
  13. If Bill is 6'6, then I'm 6'5 Anyone get stuck on the way down waiting for the tree cutters? It looked like a group of local(?) snowmobilers took it upon themselves to take down trees along the road if they looked like they were going to fall. I was behind our Ms Congeniality Forest Ranger and she was out helping move branches. So I guess it was approved, just rotten timing
  14. Got a few pics uploaded, I know theres more out there, so post em up.
  15. I've driven my Hatch over 1000mi on the hiway without a problem. Of course the short wheelbase has helped, but I try and drive it so my turns arent too sharp.
  16. We could use some firewood up there, bring some if you have it.
  17. Dang Bill, thought you fell off the face of the earth It will be good to see you again, hope you can make it. I did make it up there today and Jesse was correct. The road is closed at the top of the Snow Park. I did not care for the snow conditions at all today. The snow was only 3-4in deep, but it was slush on top of ice because it rained last night. It was slick as toad snot and I was sliding all over :-\ BUT, I talked to a Ranger that was there and she said they planned on getting the road plowed up to the big gravel pit area. This isnt where we usually stage, its a bit further down. If we use this area, we will be sharing it with a lot of snowmobilers with their trucks/trailers. If the weather continues to be nice, the roads will improve and we might be able to make it up to the regular spot.
  18. What? You just posted about setting hydro lifters. EA81 and EA82 hydros are basically the same. http://www.ultimatesubaru.org/forum/showpost.php?p=975321&postcount=2 Dont you think he should have adjusted the one he replaced at least? And come on, the engine got hot enough to melt the timing belt covers. You dont think that warped the heads?
  19. Well, you did a number of things wrong. 1. You should have had the heads milled to return them back to a flat mating surface. If the engine had been overheated enough to melt the covers, it certainly warped the heads. 2. You should have used new t-belts. Did you know how many miles were on the ones you re-used? 3. You should have but new seals in the oil pump. Not doing that could be why it seized. 4. Did you readjust the lifters after you re-installed the heads? Now, go back and do it all over again. I bet you do it right this time
  20. Those crazy Russians will try anything
