Everything posted by Turbone
All hail the Subaru!!! Best snow vehicle EVER!!!
Your mistake was going to work!
RX died.. wont start
Its happened to me a couple times :-\ Not anymore tho!
If you are heading out to play in the SNOW...
Tempted to run up there in the Brat. This was from a couple years ago in my RX with the Hankook iPikes.
It wasnt the snow that messed everything up, it was the ice underneath it. I drove Mykeys wife home from my place last night. She didnt want to chance the hill down to South Prairie in her Neon. And it was very icy. Then my SO needed help getting home from Olympia. She has a Mitsubishi Galant with summer tires. She made it to PIA and I picked her up there. I drove my Brat with Hankook iPikes mounted (FTW!) and I had to stomp the go pedal to try and break the tires loose. It took me 45min to get down the hill to Sumner :-\ Elhi Hill was locked up with spinouts and I had to detour back to South Prairie and then thru Orting and finally to hiway 410. Thats when the fun started, (for me, but not so for others). Cars were stuck every where, in the median and on the shoulder. The ones that were doing 10mph I just buzzed past, the others (trucks, SUV's) that were doing 30+ I followed at a safe distance. Hiway 512 in South Hill Puyallup was a real mess, cars all over the place. It was like running a Snow Slalom. I arrived at PIA right after my SO did, awesome timing Had to make some detours getting back home, the hill up into Bonny Lk was still a parking lot. I actually took the worse hill you could pick to get to my place. I didnt want to at first, but I had no choice, they had all the others shut down or blocked and I wasnt about to go back thru Orting (1hr drive). Unfortunately I had 3 cars in front of me and once we hit the bad part, the fool in front lost traction (FWD) because he had no momentum. Luckily, there was a side road that I was able to shoot around and get past. I was very impressed with the Brat and the Hankooks on it.
Placing a bolt through the floor - where's the gas tank?
Turbone replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat wasnt boredom Ed. That had to be done (Didnt want to drop the rear susp in order to drop tank) because the PO had used long screws to install cable to run his under glow kit. I had to patch 4 holes in the tank.........what a moron
Turbone replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I recall, theres not much room between the tank and sheet metal. Theres about 1.5in, making it difficult even going thru the access plates. Heres a scary pic.....
Turbone replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its anything like my 93 Imp, the gas tank is under the back seat and partially past the upper shelf into the trunk. No access underneath.
EA82T + Digidash questions
Replies in bold.
He should re-check the spark on all cylinders again then.
Reocurring film on my interior windows
If you have a rotten muffler, it could be sending condensation up into the trunk/cab area. I've seen more than one old GL rotted out in the back due to this.
Remove the disty cap and crank it over. If the rotor doesnt move, your belt is borked.
T'sunami Wagon
You still need the parts I have? If not, they go into my black hole shed.
1985 Soob GL Turbo 4wd Sedan
Not worth the price or the hassle of going thr the whole system to get it working again. Heres your air strut cost.
I believe the struts are still available, but they cost around $300ea (last time I checked). Also, dont drive on dry pavement with the 4wd engaged.
what do ya think
Considering how rusted out it is, I would check before installing any lift hardware. If you plan on just lifting with tires, go for it.
2003 Legacy Voltage Regulator
Turbone replied to Timberwolf530's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts built into the alternator, you need a new one or a rebuilt (alternator).
subie resto
Might consider a hi-po coil, 8mm plug wires and NGK Iridium plugs. If your replacing all the bearings, seals, etc I would use a good synthetic oil.
Fiberglass EA81 Guards
Mud? Royal? Right/left? Prison?
somebody got lucky with a 555
Turbone replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Fuel pump relay location
Thats why I said its weird. The problem showed up all of a sudden, out of the blue. It acts like its running out of gas, not flooding. Hmmm, just had a thought. Wonder if my choke is closing?- Fuel pump relay location
Thanks guys, I did a search and found the info on the fpcu right after my post. I hot wired the pump to make sure it works, it does. I started the car and it ran for a min, then died. The carb (Weber) is getting fuel, I can see it squirting into the intake. I might have to go back to my original assumption, that I have bad gas. Who knows where the pickup is in the tank? Front or back? Heres my symptoms, they are quite strange... Runs ok, until you stop or turn right. Then it dies I already took the top off the carb to see if theres junk in it, its clean. And I installed a new filter up front (no filter in the back).- Fuel pump relay location
Trying to find out why my fp isnt working and I'm having difficulty locating the fp relay on my 85 Brat (no power to fp with key all the way on, no ecu). Is it under the dash, or under the passenger seat?- 84 ea81t upgrade
The bolt pattern on the up-pipe is different for the TD04. You need to cut the flange off the up-pipe and replace it withe one from a WRX up-pipe. Any EA82T up-pipes/down-pipes will work on a EA81T also and are easier to find for modding.- Wrecked Chuck....
Turbone replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh, ok. In your original post you said you had no insurance, so I was wondering what was up.- Wrecked Chuck....
Turbone replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIsnt insurance required in WV? - Fuel pump relay location
