Everything posted by Skip
2002 H6 OB idler pulley blew up
Skip replied to byguessnbygolly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you have the time put the bearings in you freezer (or outside which ever is colder) and heat the housing to about 120 degrees in ?? Work fast and the bearing will go in much easier.
The Subarus of the 80's Site is back!
SUPER job Mick Thanks for all the time and effort!!!!
Skip replied to byguessnbygolly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGary, for the help of others helping the item in question is the support shaft for #5 in this picture My sugg. is go to a dealer and have them order it Take the picture if you have to.
'87 Turbo Wagon - 3AT problem!
You are correct sir, my mistake the cable if for the 4EAT The only solenoid is for the 4wd engagement (the 4EAT has some internal not the 3AT) and the only modulator is the vacuum one I mentioned. I got out my FSM (Factory Service Manual) and the internal shifting is controled by the lever you see operated by the shift rod. Like you said, something internal appears to have come loose. and is allowing the hydraulic fluid to be moved where it should not. If you would like I will examine this in the FSM to a more exact degree.
loyale 3at transmission woes
did you have it torn down to this level? If not that is what is needed to correct your problem Good luck, I tried.
The rubber line you see is probably just a vent tube for the front diff The vacuum Bratman mentions on a 3AT is just for the vacuum modulator (down shifting on hills ect) Your problem sounds like the shift linkage is knackered somehow. Jack it up crawl under and examine the linkage connecting the shifter to the tranny. Something slipped or is not moving what it's suppose to where the cable from the shifter connects to the tranny linkage.
What years 5MT came with rear LSD?
Skip replied to rpiereck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a 2000 Forester S Premium it came with LSD but it was an auto, I don't know the ratio of the rear diff.
Stupidy Check
Skip replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have an Advance Auto they carry a full line of these also.
85 psi then 0
Here it is, located down by the oil filter My knife is for size reference Ground the wire to it and see if the gauge pegs.
cruise control question
first place I would start is the switch gear assoiated with the brake/clutch pedal(s) either one if closed will cause the system to not "cruise". you do not mention a tranny so if it is an auto ignore the clutch pedal reference.
the operation involves removing the shuttle It is the spool valve mechanism. Clean varnish off of it and more importantly deburr the ends of the shuttle. These burrs can cause it to hang up in the cylinder it travels in. If it hangs so does the gear shift.
91Loyale, laid the straight skinny on the line, Mr Wongie. I wrote the forementioned article on correcting a knackered Gov It's in the old repair manual which has not been tranfered to this server yet. I still have a copy with pictures I could email you (it's in a .doc format)
Skip replied to byguessnbygolly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB Mr. Golly Please read through this post, it might yieild some interesting info http://www.ultimatesubaru.org/forum/showthread.php?t=93945
What is the best year outback? 97???
Skip replied to brokensub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwe got so mired in the HG problem the fact that the 96 2.2 is NON interference was over looked Yes TBs are a maintainace item but if an idler or tensioner goes poof it's just some front engine work on the 96 2.2 It could mean pulling the engine to do a valve job on the 2.5 or worse.
Vacuum Help and Diagram
look under the hood meaning the surface of the hood on the underside. Vacuum diagram may be there. The picture may be part of a criuse control system little hard to see in your picture. Maybe the idle up for an AC system. Does it in any way have linkage going to the throttle control?
Pictures of Exhaust manifold
Joakim, there is no "exhaust manifold" per say, the exhaust pipes come right off the heads. There is a "cross over pipe" that connects to both heads, then feeds the exhaust to the turbo Next there is a down pipe from the turbo that contains the cat. I do not have a cross over pipe picture but hear is what a a custom down pipe looks like without the cat. I'll look around for a cross over pipe shot
Trouble shooting window washer pump
Skip replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect JoAnne I'm not sure of the year of the change but my 94 has a front and rear bottle/pump. My 97 and my 2003 have a single unit with two pumps mounted under the hood.
Big tranny problems
Skip replied to Twitch de la Brat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsorry mate, but it sounds like the pump is toast I'll take it the ATF does not smell like gear oil.
Burned Exhust Valve
Skip replied to natole's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the other hand, if you have the pistons in a position where you have open valves they will hit and you move the cam......
Big tranny problems
Skip replied to Twitch de la Brat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's the dipstick on the passenger side of the engine compartment, right? ?? I recently went through and changed the fluids Ah sir, I do not want to sound presumptuous but the only way I know to add fluid to the front diff is through the dip stick hole. Since you recently changed the fluid you should know where it is. The ATF in the tranny may smell of gear oil if this is happening. If you find the fluid level is good (very hard to get an accurate reading sometimes).... Some folks here say "Trans X" works wonders on low pressure from the hydraulic pump.
Lookie what followed me home! (pics)
here is a veru crude picture of how I mounted the center caps. A lot of body shops have "stud welders" The caps are SS so a 3" or so 10-24 stud welds in with no damage to the face of the cap
Burned Exhust Valve
Skip replied to natole's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou are sure they are "burned" not bent? If the belt breaks you know I'm sure it can bend valves Also if the a cam moves while replacing the belt it can bend valves
gotta dig deeper for the Pug wheel but the mount involved a SS stud welded on the rear of the cap and a wing nut affair made of 0.125" Al that threaded on the stud Here is another idea. I did these out of clear polycarb for the RS wheels on my SS. Using the CNC router I reverse cut the "SUBARU" Then beveled the outer edge to make them a snap fit. Little bead blasting on the back and bingo
Thanks Will, fitting them to the alloys was a bit more involved than just "bending the clips" The holes in the wheels were not even close. I have a Pug steel 14" here, I'll go look and see what size the center hole is.
Help...no oil pressure!
Here is what you are looking for I put my knife in as a size reference
