CEL Code P1401
1 Lucky Texan replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere are vents in the top of the tank itself - do you have problems filling this car? premature shut-off or having to dribble gas in slowly? (dang - I kinda sound like a urologist!) also, there is a Purge valve that is sopposed to clear-out vapors in the chacoal canister . basically, the fill and evap and pressure equalization gear may be buggered-up somehow. And it seems more like you have a bad valve or a blockage somewhere. There have been a few cases of insects/spiders blocking evap hoses. (mazda has had multiple problems with Yellow Sac Spiders, seriously) and I suppose it's possible mud/snow could block the Drain hose. I am no expert, but there is likely one or 2 with 2 valves, or possibly a single hose and one valve (that allows 2-way air movement - on some cars called a Drain hose even though it's 2-way)) into and out of the charcoal canister. If that hose is clogged or the valve bad, the tank cannot allow pressure out, or air in thru the charcoal.If you have a habit of 'topping-off' when fueling, that can clog the charc. can. with gas - possibly acting like a blockage. I hope you can get some info specific to the 96's evap and tank fill system. you might dig around at www.opposedforces.com for a diagram.
CEL Code P1401
1 Lucky Texan replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey move some of the evap control stuff around from model to model - sometimes it's on or near the charcoal canister - sometimes under the hood... hopefully an experienced person will be able to guide you better.
things don't work
1 Lucky Texan replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's an 06, if the CEL is on, cruise is disabled. All recent models will turn off cruise and traction control ,etc. when the CEL is illuminated. CC may work after you clear the CEL code.
things don't work
1 Lucky Texan replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you have a smart-phone or a laptop, there are ways to use elm327 BT devices or cables to read the OBDII info.
things don't work
1 Lucky Texan replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, well, I found it but - might not work in an Impreza ?; from; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/19053-06-09-how-read-diagnostic-trouble-codes-dtcs.html
things don't work
1 Lucky Texan replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you can make the 06 display codes 'natively'. wait....
CEL Code P1401
1 Lucky Texan replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXeh - I'd be tempted to clear the code and see if it comes back immediately. I'd also consider running some Techron in a tank or 2 of fuel. do you ever have any other problems? fuel smells or a 'woosh' when you take the gas cap off? gas cap seal not cracked? Filler tube not rusted thru? No known rodent chewed wires?
Oil Consumption
^^^ thanx emily makes me even more glad I run synth in my 06 WRX. hey, what kinds of oils do folks there at your shop run? and what weights do you suggest for your customers?
Oil Consumption
middle-aged to older and/or neglected Soob turbo engines do develop problems with turbo oil seal leakage. partly due to a propensity for clogging an oil screen which became part of a TSB campaign. other new-ish FB engine models had piston rings with a 'new' coating and maybe reduced tension/altered design. people are fighting oil consumption issues but, there may have been a good change to that system around late 2013 ? others may have details. (FWIW - by brother in law just had his Toyota Camry Hybrid catastrophically fail DURING an oil consumption test) Just try to be vigilant about your oil level - may investigate the various TSBs. IF you become involved in a consumption test - INSIST on being present when the oil level is checked ,and the system sealed, at the beginning - and again when the system is unsealed and the level examined.
Blue Devil product technical "help"
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXleak down test might find the bad cylinder - then, "MAYBE" using their suggestion to pull the bad cyl's plug to use the substance, has a THEORETICAL chance to push the goop in the right direction. I'd say there's less than a 10% chance of immediate success - but not zero. And if it does work - probably less than 10% chance of lasting 6 months. there are so many Subarus with bad HGs, that youtube and the various forums would have multiple postings of success with using Blue Devil. at Amazon, there are five 1 star reviews and two 5 star reviews that mention Subaru. Both of the 5 star reviews seem to have had coolant going out the exhaust. Just like the Ford story - I could see BD (and maybe other products) being effective to some degree with that type of leakage. But with bubbles in the rad or overflow - physics is fighting you. Physics will win.
abs light came on
1 Lucky Texan replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwas some work done? what? could be a sensor at a wheel (bad, loose wire, or covered in debris, or cheap/wrong new wheel bearing etc.) - weak charging might also set ABS. a/c is sometimes just 2 o-rings and schrader valves plus a new charge of refrig. is the CEL on? that will kill cruise on all newer model cars. good luck
Hey Guys! New to Subaru, but not new to cars. Impreza questions...
car likely needs struts - consider new rears at least since you are changing a wheel bearing. KYB is preferred but, you may want some special set-up or new springs or w'ever if you are planning to rally.
Which Subaru Do I Want?
1 Lucky Texan replied to extria's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy extria no CrossTrek ?
Best analysis on additives; scams vs. good ones?
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno additive can 'repair' something broken, but there are a few I have or would use under certain circumstances; Subaru Coolant Conditioner Trans-X Techron SeaFoam HEET Stabil
Road grit won't come off
investigate using a 'clay bar' . Detailers will sometimes put a section of nylon stocking on their hand and sweep an area of the car. anything that snags is a surface imperfection and they will clay bar it out before proceeding with the polish or wax. i have no experience with it but, I suspect you can find instructions and youtube videos demonstrating its use.
Rislone Compression Repair
scan anyway - might find a pending code.
vacuum gauge testing might detect a sticking valve.
what engine is this? swap the coil pack (they are all interchangeable) with another - see if the code changes to the new cylinder with #3's coil.
plug wires changed?
did the cyl 3 sparkplug look different than the others? Any oil on the wire's boot?
there are a few, very few, additive products that seem to help with certain problems - but I have never read of either of those products suggested for use and i read a LOT on 3 Forums. i guess the main question is, will it hurt anything and just waste your money? seems to me, the car has not been properly diagnosed. what city are you near? maybe someone can recommend a mechanic to take another look. If you need your car to be reliable, you must spend some money on it occasionally - that's life. ALL of us car owners do that. $300 now could save you $3000-OR MORE, if you delay 3-6 months.
does the CEL flash or is it on steady and you get that code? If steady, you 'could' drive the car - not advisable, but folks do what they must do. FLASHING CEL means active/regular misfiring and expensive parts could be destroyed. I have doubts that rislone would help with the various problems that could create low compression in a single cylinder. how much is that stuff and what does it claim to do? are you near RetroRoo ? you should take your car there. http://retroroo.com/
P0301/0303/0171 2003 Forester
1 Lucky Texan replied to brighton98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvacuum gauge might confirm exhaust blockage. you can search for a chart of stuff it can help with. could be a weak fuel pump or something with fuel? how many miles since the timing belt system was serviced?
'06 Baja - Uphill Battle with no light at the end of the tunnel....
if the car has an uneven idle, you can spray carb cleaner around the vacuum lines and the intake manifold while it's running. listen for the engine to perhaps smooth-out or otherwise change it's sound/speed. Some people have even used propane but I'd think the fans and other air movement would make that trickier than directing a stream or spray of a flammable liquid. you buy/rent a vacuum gauge too - if it shows low, go around the engine compartment wiggle the vacuum lines while watching for a change in the gauges reading.
Low Brake Pedal 99 Legacy SUS
is this car new to you or did this problem develop recently? maybe have a helper really mash on the pedal while you watch at each wheel - maybe a brake caliper is cracked and flexing? sometimes brake hoses can 'balloon' - some people install master cylinder braces because of firewall flexing. what kind of tires? what brand/type of pads? I once bought some Wagner pads on clearance that were horrible.
