105
fairtax, is that the same as an 'input shaft' bearing? seems like in the old days, noise clutch in vs noise out would help decide between throw-out and input shaft bearings but i can never remember which way. I don't have the experience you guys do.
- 10 replies
- Transmission
- bearing
- (and 8 more)
I dunno on an '11 , but a lot of soobs have shown the ABS system to be VERY sensitive to voltage and is often the first hint an alternator is going out.
- 9 replies
- ABS
- Hill assist
(and 2 more)
Tagged with:
well, I don't know what instrument you're using but, an ohmmeter supplies its own current and isn't used on a powered circuit. Sounds like the meter is just confused with the power in the line and the slight drop across the connection? kinda weird as there shouldn't be a lot of current with the ignition just at ON. I'd be tempted to do all my resistance testing with the neg batt connection removed. Also, try reversing the leads on your testing. Sometimes corrosion can act like a diode. not commonly, but possible.
carbon build-up in the cylinders could lead to knock - but if the sensor isn't pulling timing, it isn't knocking. one experiment to try, clear the computer with a battery disconnect after filling with high octane. maybe try a coupla tankfuls. If the problem seems better, may be a 'real' knock issue. but from what you say - ECU seems suspect doesn't it? Or the connector to it w'ever
seems dicey. Some soobs, older models mostly, do have a reputation for piston slap noise. But what you're describing seems worse. if the engine was ever overheated, you may be buying a ticking time bomb that will throw a rod. But, a loose TB tensioer will also sometimes let the belt flop around, that can sound like a knock. You could pull the timing covers and look for an abraded spot where the belt has been whacking the cover I guess.
? which one do you want? Is this truck going to be 4WD? if not, no contest off-road, Subaru wins. but, if the 'stuff' you carry is huge or dirty, the truck wins. If you really only haul dirt or giant stuff once or twice a year, the fuel savings will pay for a rental vehicle - or borrow a buddy' truck and buy him some beers w'ever.
got it. You might consider slotted only but, as fast as you will go thru brake components, you'd likely change rotors before any cracks showed up around drilled holes anyway. someone at NASIOC might have experience with the ebay parts. I'm not running a car like you are but I've had good advice from the guys at http://www.knsbrakes.com/c/home
clear the codes and see which come immediately back. Possible bad grounds connections or loose harness connector ? after cranking, pull the plugs and see if one is wet. Also, try cranking with the pedal on the floor. That is the 'clear flood' mode for a FI car. When you checked the timing, the arrow/triangle was about 3 o'clock position right?
