105
the open end goes on the bottom so the spring end fits up against that 'pocket'. also, on my outback anyway, there is an orientation to the top hat. There should be an arrow or other marking that is supposed to point 'outside' after assembly. That is, it points toward the curbside of the fender - 90degrees from the fore-aft axis of the car. And the washer on top has an orientation. The domed or bevel side goes against the inner race of the mount's bearing. just pay close attention to how things come apart. and be careful.
whether it has ethanol in it or not, run the higher octane rating fuel in the H6. Lower octane will lead to a little knock, that will cause the ECU to retard the timing. Some say, the car also gets more/faster carbon buidlup in the cylinders with regular gas. You could try the mid-grade in winter and run the hi-octane in summer. I run high octane year round.
If they came on the car, don't have uneven pad deposits, aren't cracked from the drilled holes or at the minmum thickness - just run them. But, as said above, a daily driver does not get any benefit from them. In fact, modern pad materials even for racing do not outgas as badly as in the past so, even some track cars wouldn't need them. Of course, if you're gonna track the car regularly, you would need to use w'ever combo rotor and pad works best for you. If you plan to refresh all 4 corners, get Centric premium rotors and try Centric PosiQuiet Ceramic pads - good value. If you track occasionally - or zoom around in a spirited manner all the time, upgrade the pads to Stoptech Street Performance. On a car that old, you should consider all new rubber lines too. maybe 4 in the back (?) and 2 up front? not sure. That old rubber probably balloons a lot and fresh lines won't - more solid brake pedal feel. Fluid flush might be a good idea too.
csprings - you should not have added fluid if the stick indicated full. Also, make certain you are not using the front diff dipstick on the passenger side. (don't scoff, it's happened before) any part s store can read the CEL - post the code here. For <$20 , you can get an elm327 device to use with a smartphone and a free app like Torque and read your codes yourself.
with the engine idling, have you checked the level with the dipstick? usually, you have to pull the stick, wipe it, and wait 3-4 minutes before taking a reading, and do the same after adding fluid (add 1/2 pint ata a time near the full marks - unlike the engine dipstick, the low-hi marks are only about a pint apart on the tranny stick.)
If this car is new to you, perhaps a previous owner swapped in a transmission or rear diff with improper final drive ratio? But, definitely followthrough on the fluid change - perhaps try an additive to the trans fluid as well.
- 6 replies
- transmission
- transaxle
(and 5 more)
Tagged with:
