Tire Suggestions?
Toyo Proxes have a good reputation going way back - usually used on cars for 'spirited' driving. My bet is any other offering from them will be at least OK.
09 Forester, tire pressure monitor
1 Lucky Texan replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe drive to a Discount Tire, they may be able touse a gadget and 'interrogate' the system, diagnose the issue and/or re-marry transponders, etc.
99 Legacy 2.2 dies at times, no Codes set?
1 Lucky Texan replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXaround that time, aren't there some MAFs that get intermittent due to cracked solder joints or ????
1997 2.5 Power Steering fails, belt loose not broken
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think there are some old shop manuals from Chilton or ? that have an incorrectly low torque value in them. Maybe he doesn't have AllData or other info to use.
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have 1/2" square drive breaker bar (or ratchet) get 1/2" drive 22mm socket (I would get a 6-point socket) and use that for this job. I think the main mstake people make with the belts is forgetting to slightly loosen the bolt on the pulley befor turning the adjuster. Make sure to tighten the pulley when done. I admit I have only read about the older cars so, Ido or others may have better insight on the belts.
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThosL - 150 ft lbs is about twice/a little more than twice, that used on a wheel lug nut. It's a LOT.
Tire Suggestions?
Good point, I 'usually' buy my tires before the rainy season here.
Tire Suggestions?
I will say, I just don't think super-long tread life tires are a great idea. If you end up with irreparable damage to one tire and can't find a partially used replacement, you will lose a lot of value replacing pricey tires. I also lean toward a little stickier tires and those usually don't have super long life. I would rather give-up lifespan to get better traction. Everything your car does while moving depends on 4 small patches of rubber. I have used Kumho on both cars (though radically different models) and thought they were decent value. The tires on the Outback at present are a little better, Pirelli Cinturatos, that so far are great. You might call-up a couple of Discount Tire stores and ask what other customers have been putting on their Subarus. Local info/reviews are more pertinent than the choice of some guy in Texas. Keep location in mind also if reading reviews at TireRack or other places online. Tires are still 'mostly' hand-made (or 'semi automated) so, make sure your retailer has a good reputation. Not everyone needs all seasons either. Touring tires could be better for some folks, especially in the north where many switch to true snow tires.
Tactrix and Romraider to disable codes on 2005+ non turbo Subaru ECU's?
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have original and modded files in3 locations . I think 2 locations would be fine, a thumb drive that you could hand-off to the next owner and a cloud server(I'd email the files to a new owner also).
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, BRICK, is the word that made me anxious about the process. In fact, I had my laptop plugged in to it's charger and ext. cord when I flashed my ECU.
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXshould fine for, what?, pre 2005 or so?, pretty sure some post 05 cars actually use rear O2 sensor data to adjust a:f, I THINK I have read that some earlier H6es do as well? but yeah, on my WRX, I just had 2 actual DTCs I think. But pulling the rlay and actually disabling the air cut valves would have set a dozen more. That will of course mask any new code set so, kinda annoying unless you regularly check for new codes with a reader. The system is still in place. I figure it will someday get removed and block-off plates installed, maybe at clutch replacement time..... To be clear, Ido is in a position to make much better use of the cable and it has more than served it's purpose for me. If I get 10-15 bucks for the shipping, that's fine I guess, but really, he does so much for others, I hope it will be put to good use instead of collecting dust around here.
Rear Brake Caliper Rebuild Kit
can he upgrade to the style that IS available? Or maybe a brake set from a different model?
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKlaatu barada nicto!
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOH, I'm sending 2 sheets I printed from that thread and one of them is the instructions I used. Doing some more reading/familiarization would be a good idea though. start a thread and report what you find/work on. Could be interesting to others.
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, found the cable, will box and ship sometime soon-ish. the thread I learned/participated in is; https://forums.nasioc.com/forums/showthread.php?t=1209260&page=3 Post 104 is the one I got my codes from, there was another, but I can't seem to find it, it had a decent set of instructions. It would have been around the same time frame, 2009-20011 I think. please keep in mind I may not be able to answer any questions.RomRaider is pretty cool, I think FreeSSM may be even better, those guys at subaruoutback could help you with all this I think. The ability to select parameters to record and then drive the car and look at the data is awesome.
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it's called ECUFlash to actually overwrite the Rom so, may need both. It's been maybe 10-11 years???? Everything I learned came from a thread about air cut valves at NASIOC. Briefly, the valves kick in xtra air to 'light-off' the cat conv. quickly (for emission reasons only) for maybe less than a minute (IIRC) on a cold start. My valves corroded/stuck shut (thankfully,.... I think a few people had them stuck open) and I had several codes. Repair at the time was maybe $700 with no indication Subaru had upgraded the valves - so, it could happen again in 4 more years. Buying the cable and learning how to do the procedure basically saved me $500 immediately, maybe more in the long run. I know the cable got packed and it at this house, 90% cjhance in 1 or 2 spots. I promise I will work on this. Probably come in a padded pouch or small box.
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile I have used RR and ECU Flash with a Tactrix cable and laptop, it was not 'easy'. Not hard, just kinda anxious. As for the range of models my cable works with, after you get it, you could email Tactrix or maybe the RR group to figure out what it will/won't work with. After downloading the software, you have to do an update for the 'definitions' for each car model/year. I used it to kill 14 codes on my WRX. DO NOT try to use ECU Flash from any laptop that is not fully charged! Also, I recommend getting a cheap flash drive for any car you mod, throw the original rom data and the new data in files on it to pass along to the owner. You might consider putting those files on a cloud server somewhere too, associate it to the VIN? - just in case you need to revert to original. I see no reason I couldn't mail the cable to you to play around with. JUst keep it on 'permanent loan'. It's unlikely , but, you could just mail it back if I ever needed it. PM me a mailing addy and I will work on getting it to you - could be a week or 2 as we are very busy catching-up on things since my MIL moved out. as you know, over at subaruoutback.org, PlainOM and others have a thread. You could PM those guys for info too.
2000 Legacy Difficulty Starting - Fuel Pump?
1 Lucky Texan replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot sure I can help much but, to be clear, it now cranks but won't start? fuel pump is odd in that, it runs only for a very short time immediately after key on, to fully pressurize the rails. You should be able to hear it. If you don't, there could be a bad relay somewhere.....then I guess it starts-up again sometime after starting. tank has gas in it right? no problems with fuel gauge reporting accurately?
1 Lucky Texan replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoverfilled refrigerant can cause a hooting noise. This time of year, a/c is still used for defrost. Was it serviced recently? you could try turning the comp. off next time you hear the noise. If the intake filter 'box' is not seated at the bottom where the tabs fit into slots, it can make a whooshing sound. any codes stored?
Stuck rear axle.
nvermd
1995 Legacy wagon -- name that part...?
1 Lucky Texan replied to bendecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suppose the UP arrow could be just for factory installation? Otherwise, I thought it was for star adjuster direction for brake adjustment. But seems too large and why the whole plate??? light socket access??? what does the back look like? just flat?
1 Lucky Texan replied to bendecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid older Subarus have a rear brake adjsuter cover plate like that by any chance? kinda reminds me of the direction guide embossed in the rear brake shield for ebrake adjustment.
outback 2005 , 3.0 VDC 180kw project
scanned it. Like so many of these type videos, the use of different tires for the 'test' almost alone should invalidate it. If they were all BRAND NEW cars, I could see bringing up complaints about the tires delivered with the cars being part of the 'complaint', but, really, this should use the same tire across each brand. (and probably, if you know you're going to be on sand, wouldn't dropping the tire pressure a little be advisable? did they?) I do think, in addition to having a great AWD system, the Audi driver may have had the best approach to driving that section. So, could be driver-influenced. Not sure it's quite as damning for Subaru as it looks, but I have no real experience driving in those conditions.
CV joint play?
someone else with more knowledge may have a quantitative answer but, rear axles seem to be extremely robust and long-lasting. May have read of a failure once in over a decade of reading about Subarus across 2-3 Forums.
Fuel still getting in oil...ej swapped brat
does the fuel return line go to a jetpump like in newer models? maybe it is clogged? (I'm ignorant of older models, just asking)
