1 Lucky Texan
  1. if it's a concern on these 'hulks' - flatbed towing will protect the center diffs
  2. does your model have the trailer light harness? maybe there's a way to use that?
  3. coupla ideas; can you borrow an impact wrench? the hammer effect might help. try TIGHTENING first. sometimes that can break things loose. as for heat, I guess you tried when the car has just been stopped and is at operating temp?
  4. well.... come back when you have a Subaru lol
  5. dunno about 'stacking' antenna boost - maybe contact user botenredwolf at subaruoutback.org , he's a car audio guru. http://opposedforces.com/parts/legacy/ http://opposedforces.com/parts/legacy/
  6. there should be an amplifier back there but, Subaru has moved it around across the years and models. maybe search the diagrams at www.opposedforces.com ?
  7. ^^^^ if the strut was replaced/rebuilt - the conical spacer at the top may be flipped. narrow side must go up. or maybe some odd brake dust shield issue?
  8. ^^^ yep, have had 2 bad bearings. Front right on my WRX, hellish grinding noise - probably could be heard from 100 yards away by the time I got it to the shop. left rear on same car, silent, found it with an up-down rocking test, moved about 2mm, other side solid.
  9. check sway bar endlinks, they can rattle.Check rear bushings on lower control arms. second advice above, KYB struts, other stuff if inspection warrants. best DIY, remove strut assemblies, take them and new parts to a shop and pay them to move everything over.
  10. cool that GD (assuming that's who you spoke with) did that for you, he has helped tons of folks.
  11. tapping toes........ ......waiting for that referral check in the mail.... .......
  12. less likely to be solenoid failure I think because the 'default' before 2005 is AWD. seems like a mechanical/physical issue.
  13. Jo - you could also ask for a shop recommendation in a new thread - someone may know a soob-friendly mechanic near Westerly good luck
  14. no experience with models this new, but both my soobs began sucking air into the fluid - visible bubbles/foaming in the reservoir. They both whined, the WRX had 'pulsing' vibration in steering wheel.
  15. check the fuel pressure regulator's vacuum line for wet with fuel. check fuel pump for cap/o-ring problem?
  16. yeah, call 3-4 highly rated shops for estimates. get name-brand ceramic pads.
  17. On floating caliper systems, I think they should go on the inside? maybe check drawings at www.opposedforces.com?
  18. check crutchfield.com , you may discover that upgrading both units, perhaps even leaving a spot for a 'cubby' is quite affordable. Of course, your actual purchase could be from amazon or ??? the flickering lights seem like a ground issue, though, it's hard to say for certain.
  19. or rebuild the solenoid, contact and plunger kits are available.
  20. ido - what is the difference in auto vs 5spd starters?
  21. doh, beat while typing
