1 Lucky Texan
  1. seriously doubt a 'downgrade' is practical - wiring harness and computer issues would be horrendous to work around.
  2. driving on or offroad with a dicey engine is a worse plan, IMHO, than driving for a while on sloppy suspension with a decent engine - but yeah, you have to pick your battles with limited funds. If the car has components that make it unsafe to steer or brake - those must be addressed of course. LOTS of cars are on the road with bad shocks and springs and 'iffy' bushings, etc. The cars with bad engines are in the junkyard. It may depend also on what tolerance you have for risk, if you offroad with buddies that could rescue you vs alone ,how far and how crazy the offroad adventures are, you have other transportation, what time-frame you have to get the car up and going, etc. many folks here have plenty of experience to help you with specific questions, and much more experience than I do. good news on the underbody rust issue, still, you will want to spray PB Blaster on a few spots for a few days before tackling some of those suspension and brake and steering connections.
  3. how much rust under the car will you be dealing with? that could get frustrating quickly. engine is critical so, I'd approach it from getting it road-worthy/reliable first.
  4. wow, well, good catch on that cam pulley. um, I guess start checking oil, trans, and cylinders and ? for the coolant....not sure what to say on that.
  5. GD - does the swaybar endlink come off too? axle; new or re-booting a used OEM axle is best new aftermarket is a coin toss (FEQ, EMPI, etc.) typical rebuilts from a parts store is a roullette wheel spin! - don't get suckered by the lifetime warranty.
  6. DOH, beat out while typing you can sometimes find FSMs on line - do a search and include ' .pdf ' in the string.
  7. I'd think you'd return to the dealership and have them fix the car - if they balk - contact SOA and meet with a regional rep at the dealership.
  8. yeah, live data or freezeframe data might be good here - fuel trims may be 'off' , or temp sensor bad, ,,,knock sensors can be cracked and will kill power , good suggestions above.
  9. rear O2 could be bad, exhaust leaks will cause that code - just be SURE before spending $$$ for a cat.
  10. I'll suggest Valvoline MaxLife (Dex III/VI w'ever) for the 4EAT. a lot of the fluid stays in the torque conv. 3 drain and fills with a little driving between gets you over 80% new fluid - there are ways to do a complete swap of course, search for those ideas. If you are having any delayed engagement, a bottle of Trans-X on the last fill really does refresh seals. Sneak up on the hot (operating temp) full line - the marks are only a few ounces apart. Run thru each gear and check while idling of course. The Subaru new OEM ATF-HP may be a little better for you with extreme cold..... not sure. It is a thinner viscosity and a 'must' for the 5EAT in 05s - up. consider using a turkey baster with a short hose and refresh power steering fluid with some new ATF too. name brand GL-5 should be fine for the diffs, synthetic might be best in your harsh climate. You might look for the synthetic 'blend' at WalMart - inexpensive and some folks seem to like it. take the FILL plug out first on the rear diff, that way, you know you can get fluid into it. If you drain, then can't bust the fill loose, can't drive the car! I used my floor jack on the handle of my breaker bar. Those things were TIGHT. I used these items to help with the rear diff and the trans/front diff;
  11. find an independent shop to diagnose the car. P0420 is rarely a bad cat. conv. Some scary sounds are a weak timing belt tensioner and not rod knock or piston slap, etc. check you local Yelp and Angie's List, check your 'region' at www.NASIOC.com
  12. some folks have had a weak timing belt tensioner mimic rod knock. there's a youtube video or 2 about it.
  13. how many miles on the trans? you might find a much lower miles entire trans from car-part.com or ???? to swap in. I THINK there is a certain year where some internal part was changed to a better alloy too???
  14. Im with nipper, I doubt it can truly be 'rejuvenated'. some folks like Aerospace 303 protectant - but probably short term too
  15. some cars with bad plug wires or coil, or, maybe with oil leaking onto the plug boots, will drive-off moisture when temps increase, reducing misfires. Some folks have even used plant mister bottles undehood at night on their idling car - the mist will show arcing and maybe cause engine stumbling. The other issue could be as I oultined above about the engine temp sensor - if the ECU thinks the car is always at a higher temp, it won't 'choke' by sending more fuel to the injectors when cold. plenty of other things other things; like a gummy deposit in the throttle body or gummy buildup in the IACV or ???? might be different viscosities at higher temps. Metal parts change shape with temp, wires/connectors/ground connections could change a little with temp. I have read of older crank position sensors that failed at high temp......who knows?
  16. re-read the post, the backfiring kinda points to some timing or maybe valve issue - I suppose over-fueling might be an issue too but???? find the tooth count for the engine on-line. Bring the marks on the pulleys around to the timing points and do a tooth count. here's some wild ideas; one thing that will kill power often with no code is a bad knock sensor, easy cheap to replace too. although it seems to be a rare failure, the car has 2 temp sensors, the gauge part can be good, but the ECU uses a different sensor (in a single unit on some cars) to determine if a 'choke' condition is required and if bad, might not be supplying enough fuel when cold? or too much when warm? another easy thing that will mess with idling - the IACV tube under the intake tubing could be cracked/loose. dirty throttle body might cause idling problems.
  17. interesting - I wonder if a garden-type pump sprayer can survive any useful solvents? also, I found these vids;
  18. there's at least 1 video showing dropped guides. I think a car has to have been quite neglected to have that happen though.
  19. yep - def check timing. I wouldn't rule-out a 'dropped' valve guide or burned valve.
  20. smell it - diff lube is distinctly foul compared to engine oil - you can confirm that by smelling the 2 dipsticks.
  21. Subaru Coolant Conditioner has helped folks with coolant drips/seeping. Install ONLY one bottle and ONLY as directed.
  22. every time or first start of the day? CEL on? scan for pending code anyway. fuel pump? Try cycling the key to ON, but without turning-thru to start - still have noise?
