105
electric impact would be a great addition to your 'kit' even if you only used it for buzzing off wheels. I regret waiting 30 years to own an impact. That said, it's no good for assembling anything - use a torque wrench when appropriate. Best approach for struts, gather your new parts, take the assemblies and new parts to a shop, pay them them do the swap. If you want to do the whole process, the impact will help a LOT with the spring compressors. Doing struts is what prompted me to buy mine. Yes, doable with hand tools, especially so if you aren't fighting rust. It just takes more effort and patience. I had to kinda 'rig' a 6mm wrench to fit through a socket held by vice grips to torque the top of the strut. Also, consider new strut mounts - at least remove them and spin on your finger - the bearings in the mounts on my WRX were bad at only 65K miles or so - but 10 years old. Be careful with the little studs on the mounts, very low torque.
have you scanned for pending codes? it may be necessary to get live data - ELM327 BT adapters are cheap, and a smartphone with the Torque free app can go a long way towards getting sensor data that 'might' point to a problem. check your brake lights in case there's something weird with the bulbs or corrosion in the sockets - the lights put a drain on the alternator when you hit the brake pedal.....? there a lot of possibles sources for intermittent problems. You might examine ground connections, battery terminals, monitor voltage from the alt. and compare when it's running good vs bad.... youm ight try a battery disconnect reset - if the car has the same symptoms after that, I doubt a:f -related sensors are bad. The ECU is forced to start and run the car using the factory initial settings until data is gathered from the sensors. Could be something more physical; dropped valve, vacuum leak, ...?.
There are used Subarus that are as reliable as other used cars - ANY used car can have major problems. Maybe if you mention your budget, and ask about a Subaru-friendly repair shop near West Hamlin , in a new thread, someone could point you to a good mechanic. Then, go have a coupla conversations; 1. How much and what is the procedure for a pre-purchase inspection if I find an OB for sale? and 2. Do you have any customers that might be looking to sell their OB soon? The older a car is, the less important that brand's reputation is, and the more important the car's prior care and present condition become.
TB in car would be a 'holding back' or bucking/jerking feeling in the 'seat-of-the-pants'. if that Cardan/w'ever joint between the rack and the steering wheel is rusty, it can make 1 or 2 tight spots in the same place in the steering arc in both directions. I do also think many folks have had CV axles present similar issues. maybe especially if the problem seems to be side dependent? (the inside of a turn always stresses CV joints more due to ackerman angle geometry in the linkage)
well, that quote is 2 things I guess. Inner front CV joint (DOJ or tripod joint) boots often split open and the joint can lose it's lubrication. Known for clunking or popping or other issues on it's way to failure. The front differential has it's own dipstick on the other side from the auto trans' stick. It also needs to be properly filled of course, but, it's drain plug is equipped with a magnet. If there is a reasonable fear the front diff is failing, that magnet may have excessively large particles or an excessive amount of metallic 'sludge' on it.
a steady stream of bubbles might indicate a leaky o-ring on the hose adapter atop the pump or a leak past a suction hose clamp. maybe observe as a helper turns the steering wheel. Very common failure, sometimes causes a whining noise and/or a 'notchy' or 'vibrating' feeling in the steering wheel. A rare bubble or 2 from the splash of the return line is OK. A different type of problem can be caused by a corroded Cardan/u-joint on the steering shaft. It connects the rack to the wheel's part of the column. IT can cause a 'hard' or 'stiff' position when turning the wheel - almost always at the same 'clock' positions in the wheel's perimeter.
- 4 replies
- subaru
- power light
(and 5 more)
Tagged with:
It does seem like you could have 2-3 different problems. clunking could be bushings, definitely check the rear bushings on the front lower control arms. steering could be air in the power steering fluid, or maybe slipping belt or even separated craank pulley slipping? I don't think we have that power light but I'm not sure. You are checking trans fluid while idling right? some folks forget as it's the only fluid check like that.
- 4 replies
- subaru
- power light
(and 5 more)
Tagged with:
