My '83 GL: The Ski Wagon
Lowes has bins of fasteners in the bolt/screw dept. You might also check in at Napa.
  • Replies 1.8k
  • Views 281.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • AdventureSubaru
    AdventureSubaru
    Part one of the journey was completed just over a week ago. My brother and I took the car to it's "drop point" where it will be picked up by the new owner soon enough.   I hadn't seen the car in jus
  • Mechanical_misfit
    Mechanical_misfit
    sorry for the delay!
  • I swapped the DS front fender last night. The original was totally rotted off on the bottom and something was misaligned. It caught on the door every time I tried to get in or out.     It's sti
Posted Images
So I ordered a clutch kit today. I will have it tomorrow, comes with everything so it looks. Clutch disc, pressure plate, throw-out bearing, alignment tool. It better be for the 4WD, O-rileys has a habit of giving me the wrong parts.
The Kit is Sachs. $100.
post a pic of the TOB would ya? one of my custys bought a "ea82" sachs from said store and im glad i checked w my alignment tool, it was not the right one by any means. nor was the TOB, didnt even look right. the clutch disc and pp bolted right up tho. Thanx, as always
The bucking problem youre having, is it all the time or only before it warms up?
It is all the time, cold or warm. Turns out the EGR was the main culprit of the bucking, now she runs smooth down the road!
Rob, I will take a picture of the TOB and all the goodies when I get it tomorrow.
For now, here is the kit I am getting, Has a picture.
http://www.rockauto.com/catalog/moreinfo.php?pk=1382797
I have done two Subaru clutches recently and both of them had cracks in the pivot area of the clutch fork. You could tell that the pivot area had been dry of any lube for years. One of the two was bad enough that the pivot ball was ready to punch right through the fork, the other had hairline cracks just starting.
Subaru could still get the forks, the retaining spring for the pivot, and the 2 clips for the throwout bearing - none of these parts were expensive. I would look closely at it when you have it opened up.
i second this, a recent addition to my ''cars that i fix'' fleet was bought for super filthy cheap......broke clutch fork (88 gl) runs like a whipped mini horse. that said, the only donor fork came off another recent addition and the cracks were evident, but not yet fatal. that cars getting a rebuilt motor then ill replace the fork. long story long.........lube that pivot with white lithium grease while you have the chance....but you prolly knew that. i digress....
White lithium or a high pressure EP moly base works well also.
Edited by Crazyeights
I have both, I will probably use Moly so its more robust.
Good call on this, I will check this out.
QUOTE]
Thats good you got her all fixed and running smooth. I'm having a similar problem but only when its cold. The CEL is on but i cant find a shop around here to read the codes.
These cars are OBD-I, the engine light will flash a series and repeat. You then count the flashes and look up the code in a repair manuel (Chilton, Hayens)
Motor is now out. Went to the dealer and ordered a rear main, $15! But mine is leaking so it looks. I will have some questions that I'll post up later, with pictures more or less.
Side note, Fork looks mint. No cracking, still has original blue/gray paint.
Moist.
This red rubber, isn't a seal is it?
Disc.
Pressure plate.
The fingers aren't broke, but the ends are worn and grooved.
Flywheel looks and feels ok. I don't think it needs to be resurfaced. Yes/No?
New Sachs kit.
Throw-out bearing, pilot bearing, what is the very small roller bearing for?
New pressure plate.
ummy nummy clutch and moist motoor there, son:Flame:
what are you doing with the flywheel? It looks more glazed than gouged. a rotary drill sander with 60 grit may do the job.
Yeah its not gouged, I feel a very slight groove, so I am wondering if I should get it turned? If I didn't have the groove I would go the sand paper route.
Don't want the disc to be slippin' as I ain't scratchin' phat tracks.
Your going all the way here I vote just surface the flywheel. It shouldn't add more than $30-$40 and then you know it's all perfect. The little red o-ring is also a seal but I have re-used them without any trouble. Remember to loctite the flywheel bolts to seal them as well.
Looks Great!
Yeah I'm thinking I may just get it done right. Gotta wait till I have $40-50 stashed.
I'm gonna drop the oil pan, de-rust it, paint it (Some color) reseal it with RTV. I'd like to get Stainless bolts for it too.
Your build - but just another opinion. I would personally skip the RTV and go to a Ford dealer and ask for the diesel oil pan sealer in the half size caulking tube, or a Toyota dealer and ask for their oil pan sealer (in a tube), failing availability of all of that I prefer 518 anaerobic or Ultra grey. Just some other options. Life expectancy of RTV around oil seems to be about 2 years max and then it turns to mush.
One further option is to use a gasket with a THIN coating of any of the above sealers on each side, and clean and loctite the bolts so they will hold tension on the gasket without needing to over-torque the bolts and squeeze it out.
thanx for the clutch picks......turns out AZ gave us the wrong kit. matches your ea81 kit perfectly (cept for the roller bearing?). this woulda worked for us.......if we had an 87 ea81 wagon (doesnt exhist). oh well, i shoulda gone not the new guy i guess. I digress.............
back to work Tom
... an 87 ea81 wagon (doesnt exhist) ...
... in USA.
The EA82 engine was "Optional" in Latin America and other markets. ;)
Your build - but just another opinion. I would personally skip the RTV ... I prefer 518 anaerobic or Ultra grey...
Yes, I Agree that Standard Silicones won't last there, but How about the Mega Cooper?
Kind Regards.
well, ya got me there Jezsek, i shoulda said "there is no 1987 MY gen 2 wagon"........in the usa
Glad the pix helped ya. yeah I dunno what that little bearing is for either, ANYONE KNOW?
Back to work....
Cleaned all the oooey gooey sludgy fudgy mess off the crossmemeber. Used Washing fluid to break down the oils, scrubbed with green pad then used Soapy water to clean it up. Gonna repaint the entire engine bay satin black (Engine Enamel)
Fork with new Throw-out bearing.
Inspection plate.
I Really Like how you are Doing the Restoration on that Beautiful Subie, Also I Agree that this is the right Moment to Paint the Whole Engine Bay, but maybe you can Choose Different Colours... in my Case, I Choosed Black for the Firewall and the Rest is painted Yellow like the Rest of my "BumbleBeast" but since it was Engine -ceramic- Enamel, it Looks "Darker" than the Rest of the Car.
Kind Regards.
