EJ swap who's who
Did the swap in late 2005
Body: 1988 DL
Engine: 1991 2.2, replaced with unspecified 90-94 JDM low miler when the engine got fraked (turns out it was only an idler pully and it now resides in a friends sisters legacy with around 245k on it)
Tranny GL 1.59 low range, standard EA-82 fare.
Susp: Impreza/XT-6 under a PK-Ozified 3 inch lift
Wheels/Tires: 14 inch steelies from an Impreza W/27 inch SSR swampers.
As a heads up, the offset from the impreza tires with impreza struts is not so yummy with the bottom of the spring pearch. Its an interference fit, and even with it notched and rewelded it rubbed above 75mph on bald SSR's. (so if anyone has a set of impreza coilovers that they want to get rid of cheap, even ebay specials, i'm all ears)
  • 1 month later...
  • Replies 97
  • Views 92k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • kingbobdole
    kingbobdole
    Owner: Zem Body: 1984 GLF Coupe Hardtop Engine: 97 Impreza OBS EJ22 Transmission: 97 Impreza OBS AWD 3.9 with VLSD 3.9 rear OBD2 compliant, scannable, super clean emissions. Custom trans mount,
  • Body: 1986 Subaru BRAT   Engine: EJ25D block, EJ22 single port heads, Delta Cams (torque grind), Stainless steel UEL headers, Under drive pully, K&N drop in filter, JDM EJ25D injectors, Forester
  • My car: Engine: '92 Legacy OBD I EJ22e Chassis: '92 Loyale Wagons Tranny: EA82 D/R FT4WD 5spd Other: Mrose Adapter Plate, OBX header, 5-lug swap, RS front brakes, 200SX rear calipers   current p
My latest creation
Body: The Cheese wedge, '89 XT-6
Engine: '03 Legacy 3.0 H6
Trans: 2005 STi 6 speed manual 3.9 fd awd cable
Suspension: Lowered stock XT-6 on KYBs IIRC
Wheels: '05 Legacy GT 17"s
Other: I converted the FailWD to awd due to the number of transmission I broke. Seems the box didn't care for twice the power, kept breaking the diffs. Soon to be supercharged...
Edited by kingbobdole
  • 1 month later...
Body: '87 GL coupe
Engine: '92 Legacy EJ22T
Trans: '98 Impreza 3.9 5-speed NA
Interior: '05 STi seats
Exterior: RX bodykit, soon to be widebodied
Suspension: Combination of Impreza, XT6, RX and aftermarket
Wheels: Enkei RPF-1s in 17x8, 45mm offselt, 5x100
Tires: Toyo Proxes 4 215/45R17
Other: FWD auto -> 5-speed swap. Before EJ swap, had SPFI motor swap, RX gearbox, RX rear subframe with LSD
Body: '87 GL coupe
pics?
Body 92 Loyale sedan
Engine ej22
Transmission Dual range 5sp with Lincoln locked rear end
Suspension 2" SJR body lift
Wheels 14" Pugs with 27" Kuhmo tires
  • 4 weeks later...
I just got done with my EJ22 swap. I love it. I installed 27" tires after the swap. Sitll have plenty of power.
  • 2 weeks later...
Chassis: '85 GL, 5-speed, stock
Engine: stock '99 EJ22 OBD-2. Full custom exhaust: dual 1 7/8" to rear of car w/stock '99 legacy muffler, 2.25" out
Edited by 84GLbenhamj
pics?
As its sits right now, there's probably close to 2' of snow on it but here it is before I started tearing into it earlier in the year.
  • 1 month later...
Body MY86 GL wagon
Engine MY98 EJ22 longblock MY94 intake and wiring
Transmission Dual range 5sp with 3.90 fitted clutch LSD
Suspension 2" SJR body lift/1.5inch subframe spacers
Wheels 15inch pug flat spokes w/ 215/75 wildcat A/T's
Misc:
Yakima roof rack
Surco aluminum basket for flood lights, full size spare, and shovel.
Custom front brush gaurd with Hella 500 driving lights
Custom 2X4 square tube rear with D-Rings
MY98 Outback Heated/height adjustable front seats
Subyaddict
Chassis: 1983 GL wagon 4wd 307,000 miles
Transmission: 1992 loyale 5sp dual-range 4wd (JDM, >35k), with LSD rear diff 3.7 final (from 89 RX).
Flywheel from XT-6, clutch disc from EA82 (new), pressure plate from EA82(new), T.O. bearing from EA82. (had to grind a little on the inside of the bell housing for bigger flywheel)
Engine: JDM 1984 GL 1800 from automatic car
(latest and highest cam , and strongest valve springs made stock ever),
revs to 6500rpm smooth, still actually pulls at 5200rpm, intsead of the USDM 4200rpm. advances father than USDM, too. :)
Brakes: front from EA82 (vented), rear from turbo with calipers.
This car is my baby, it's an 1983 GL that will do 120 mph, NOT JOKING! Don't worry I have new suspension (all bushings), and new brakes.
The 3.7 final drive ratio, and the fast motor, were the keys.
Can you say "sleeper" ?
I've had alot people tell me I should get a new car. :lol:
What, so the cops will see me first? :lol:
Sounds like a neat car, but not an EJ-swap...so really doesn't belong here.
  • 1 month later...
Engine EJ22T
Body 91 loyal with cheese
suspension stock (rx front sway bar)
Wheels 1980 toyota truck wheels
Tires 215 60 15 ADVAN AO33's :D
Board Member: angusf
Engine: EJ20 from a '94 Legacy Turbo
Chassis: 1993 BRAT/MV
Tranny: Legacy Turbo five speed
Other: VOS Chip, high pressure inline pump, top mount intercooler
Member: Psychobaru
Engine: EJ22 Carburated
Chassis: 1985 Brat
Trans: 4sp H/L
Other: EJ18 Heads(polished)w/ turned cams
  • 1 month later...
  • 3 weeks later...
i have a dream of fitting an EJ20TT into my '83 brat...am i crazy?
In a word yes, the second turbo won't clear the master cylinder, so you'd have to switch to a single turbo, unless you find a right hand drive brat.
  • 1 month later...
Board Member: Capn_r
Engine: 91 EJ22
Chassis: 1988 GL-10 Wagon
Tranny: 5 speed FT4WD with diff lock
Other: Redrilled hubs, 4x100 with 14x6 VW "imola" alloy wheels and 185 /70/14's
95 Legacy exhaust y pipe with 2.25 tailpipe with a magnaflow muffler
the car has working A/C (Legacy condenser and radiator) and I'm in the process of getting all the car's other whistles and bells functioning. A fun car and having this board to refer to is an incredible asset!
Looks like I can finally add myself to the who's who of EJ swapping!
Board Member: gwilson87
Engine: 92 EJ22
Chassis: 1985 Brat
Tranny: 5 speed, D/r from loyale.
Other: Currently designing a simple 2" lift and ordering the 215/75R15 tires to go on my toyota 4runner wheels. Nothing more than the Y pipe on it right now. will have both cats from the Legacy donor and a straight through muffler for inspection purposes.
  • 3 weeks later...
Body: '79 GL wagon
Engine: '93 Legacy EJ22T
Trans: '88 loyal 3.9 5-speed D/r, p/t
Interior: Nothing but 2 seats and 2 15" Pyle Subs
Exterior: fender flares
Suspension: 4" lift, gl-10 discs all around
Wheels: custom 5x100 adapters to fit 15" Fiero spider wheels
Tires: General grabber A/T
Other: LSD rear, Custom crash bars front & rear, 3000lb winch
  • 2 weeks later...
Body: '79 GL wagon
Pics please :slobber:
  • 5 weeks later...
Here's mine: (FINALLY got a new camera)
Everything went pretty smoothly, I only had to extend the power steering lines a little to make it fit from the pump to the hard lines in the last pic. All the other PS lines were bent enough out of the way to make them not hit anything. I also had some port and polish work done to the heads.
  • 2 weeks later...
Body: 86 GL wagon
Engine: 97 EJ20R JDM twinturbo
Trans: 92 legacy 4.1 5spd
Other: 6" SJR lift, Megan racing coilovers for 05 forester, Link G4 standalone ecu, turbos running parallel, innovate LC1 wideband, autometer boost gauge,
stage 2 ACT clutch for legacy, wheel adapters 5x100-5x4.5.
Parts from 91 legacy ss:
radiator
front control arms-welded together w/stock GL inner portion
steering knuckles
15" wheel front brakes
Parts from 89 XT6:
rear brakes
hubs
sway bar
brake master cylinder
2 sets of wheels
stock 2000 ranger wheels 15x7 w/33x12.50r15 bridgestone dueler m/ts
JDM 17x7.5 aftermarket w/24565r17 cooper atrs
My '92 Loyale now has an EJ22 under the hood. Motor is out of a '92 Legacy wagon with 90K.
picture.php?albumid=41&pictureid=1814
More info with lots of pics of the process at this thread.
  • 2 months later...
Forum Name MUGS
92 NA EJ22 SOHC OBD1
Chasis 85 GL Wagon (Carbed EA82)
6in BOSS Lift
Trans 5MT D/R
Sachs XT6 Clutch Kit
Welded Rear Diff
235/75/15 Tires
90 Isuzu Tropper Rims Drilled out
EA82 PWR Sterring Rack
Rear Disc Conversion
Custom 2 in exhaust
Custom built this and custom built that...
Modified this and modified that...
To make it all work together...
To get a bad mamma jamma :banana:
Heres a thread of the build...and will be continued to be updeated as it progress is completed.
http://www.ultimatesubaru.org/forum/showthread.php?t=100861
Edited by Mugs
