All Activity
This stream auto-updates
  1. Past hour
  2. I have a couple of dual range MTs from '88 DL and '83 DL.
  3. Hello people. Long time, no problems with the old GL. Can I take the play out of front wheel bearings on my '88 GL by tightening the axle nut? Is that what that sleeve inside the hub is for? For the bearing to tighten against? Bearings were replaced ten years ago..
  4. Yesterday
  5. Thanks. Looks like a pushbutton 5 speed will have to do for now. This morning we towed home an '87 GL turbo parts car and that is what it has. Hopefully with the parts car the turbo swap will just be a lot of "doing" and not so much figuring out what to do and how.
  6. Last week
  7. Have driven the Impreza a bit more and the bottom radiator temp sensor continues to be at ambient temperature the majority of the time. One time after I was only stopped for ten or fifteen minutes it and the intake air temp had soaked up to about 50F and stayed there for the short drive home. It seems that the ultimate temperature it reaches is in the 190sF at the top of the radiator and 220sF at the top of the engine. That sensor on the engine is probably less accurately calibrated and generally just reads 10F or so higher than the ones in the radiator even when the car's been parked overnight. I bumped up the temps the fans are coming on at so they're not running all the time once the car warms up. 220F on the engine temp sensor is basically when the temp gauge just starts to creep up above the middle. Have now seen a temperature drop of 180F across the radiator (it's been cold here lately), so I think the radiator is doing its job. I rebuilt the rear struts in B's Forester. No major issues, mainly changed the dirty shock oil, replaced a couple little things. B replaced the rear suspension bushing that was shot and went over a few other things on his car.
  8. Another issue I have noticed is that the radiator fans come on when you turn on the ignition. I believe the fans should not come on if the engine is cold. So I thought maybe a bad coolant temperature sensor. I swapped it out but no change. Maybe this is related to the starter problem?
  9. All these 3 must be satisfied, to energize the starter solenoid: - Ignition switch to 'Start'; - Starter-relay energized; - If MT: clutch-pedal depressed to close clutch safety-switch; or if AT: in park (or neutral) to close start-inhibitor safety-switch. These 3 are all in a 'series' circuit/logic; this requires that all 3 work, before the starter is energized. On my 2002, these devices are all in challenging locations to reach. May be easier on your 2009.
  10. Can’t tell you where the relay is that you’re chasing - I wanted to share with you a common mod on the Gen1s in the early 90’s. Often with an issue like this ppl would add a horn relay to the system. This would hive direct power from the battery to the starter solenoid by using the start wire as the rely trigger reference. Worked a treat and might be something that will work for you. Just ensure there’s no rodent damage to the start wire to the starter solenoid.
  11. At first the starter would engage and turn the engine over a couple times and then quit. After trying a few times it was only silent, not even a click. I replaced the starter motor but the solenoid does not appear to be receiving power from the signal wire. I looked at the owner's manual list of fuses and for the fuse and relays in the engine compartment and it says something like "except starter motor.". The passenger compartment fuse list in the owner's manual says fuse 21 is the starter relay but the fuse is still good. Somewhere I think I read that the blue boxes to the right of the small fuses are relays and one of them might be for the starter. Can someone tell me where to look? My battery is good and the voltage at the positive connection on the starter motor is the same voltage as the battery.
  12. Thanks. We are thankful. Tuition, dorms, meals, all covered. It was multiple round of interviews over the phone and in person. Quite a bit more effort (and driving) compared to all the others submitted online or write an essay, etc.
  13. Whoah an educational "free ride" and a Subaru rust free ride! Graduating debt free is liberating. Congrats to your daughter.
  14. Most of it is for the Sedan but I'd love some scans of the Leone Estate/ GL Wagon. Here are some of the highest I could find myself. Also have some scans of EA82 manuals and some cute paper craft of the Justy I found.
  15. Resolved, replaced both converters. Thanks Brusbrother. Got this car from Georgia for my daughter, so it's rust free, I'm sure you can appreciate that. Concern is what caused this and hoping it doesn't destroy the new ones - oil level was increasing and bad mileage, pretty sure running rich. Found and replaced one cracked injector while chasing the clogged converter issue. Time will tell. Runs great, looks great, ready for college next year, she got a free ride at her top private school pre-med and was the first player in school history to be named first team all state twice as a junior and senior. Not bad from a rural public school with very poor academic options. /end proud dad brag
  16. We finally got the secondary fuel tank project finished. Added one fitting to each cover plate of the stock fuel tank. Ran a fuel resistant hose down the side with the main pickup. Mounted, plumbed, and wired the fuel pumps in the spare tire well. It will probably take about ten minutes to fill or empty the tank. Seems to work in both directions by watching the clear fuel filters, listening, and watching the fuel gauge. Definitely looking forward to putting the extended range to use. I rewired the fans. Two small puller fans are on the main circuit. Two pusher fans are on the sub fan circuit on a larger fuse and relay. Main goal here is to push less debris into the condenser and radiator. Another potential benefit is not blowing the fan fuse when driving in deep water. I also wired in the temp sensors we added to the radiator earlier this year. Only drove it to the grocery store and back, which is maybe a ten minute drive, but I found the results interesting. The bottom radiator temperature is basically always around 20F higher than ambient, similar to the intake air temperature. It did read much lower when unplugged and does vary a bit so I'm pretty sure that sensor is working. The top radiator temperature kept slowly increasing but was generally 40F lower than the coolant temp sensor on the engine (by the top engine water neck maybe 6" from the radiator sensor). The ones on the radiator are probably a more accurate calibration. The top ones did get within about 20F by the end and after sitting for a bit. Also means the radiator is producing up to a 120F temperature drop even parked at idle with the fans off which I found impressive. Also we worked on B's Forester a bit. Narrowed down which rear bushing needs to be replaced, replaced a wheel stud, and adjusted the parking brake.
  17. Welcome! There's a guy 4 hours from me that has a 1990 4WD 3 door Justy listed for $2000. Body is gone but it would be a fantastic parts car. Sitting since 2013. PM me if you want the details. Cool ride, I've never put a wrench to one but it's honestly more practical than a modern Subaru for A-to-B driving. :]
  18. Howdy, folks! I just bought a '93 Justy up in Oregon. I needed an economical daily driver. What I DIDN'T need is another oddball car with an orphaned engine that takes WAY more work to find parts and support for. That's why I'm here. Oh, well, these kinds of vehicles are in my DNA since forever, and apparently, I can't resist. I think the Justy is going to be fun. Hoping to gain some knowledge here and also add some as I dive into it, which is already happening fast..
  19. None of that, hahaha. This thing stays in my shop so it's never really below 40* unless I have the heat on out there. Hope to find some time this weekend to take it up the road. We stay so busy with my son and basketball and work BS, Plus, I have 3 other cars of my own, not including the wife's.
  20. Yeah fair enough! You didn’t do the “mandatory” double pump if the throttle before turning the ignition on? Or the other way to do it is ignition on to prime the fuel bowl, ignition off, double pump, ignition on and start. I do this one when I haven’t driven my brumby in a while, especially in summer when it seems the bowl evaporates and needs filling again.
  21. Earlier
  22. There's a front right Sachs 4WD strut on Parts Geek right now. There's only one in stock so if you need one, now's your chance! :]
  23. Sorry, been off-line due to a cold. I am working on another door that is a little closer to where we live. If it is rust free we are going to go with it. I should know by Wednesday afternoon (hopefully sooner).
  24. You should always hit the gas pedal at least once before cranking, to close the automatic choke.
  1. Load more activity
