Everything posted by bheinen74
grumble. BRAT oil leak got much worse. Still made it to KC and back. Either rear main, or oil pan are my first 2 thoughts after sticking my head under it. At least oil level did not get low. going to clean it up and see what i think and whether it is worth even fixing now or just wait it until spring. If oil pan, i will easily have that fixed this weekend. probably shouldn't have used the cork pan gasket last time. hopefully that is what it is, but i am iffy.
"Other than one rip in the driver's side door, the interior looks practically brand new. A/C blows cold, Cruise Control works, nice Sony stereo and CD unit, seems like overall mechanically the vehicle is in good shape." Well, the fact is, they made these 90-94 models to last. I have rarely seen interior wear on any of them even in the junkyards, they just are built really solid, which is why so many of us recommend that era. And, you can just run it til the Tbelt snaps, then do a new t belt kit and go another 200k on the engine, no hg's no tod, no rod knock, no piston slap etc...not on the first gen tanks.
A most excellent deckless head unit.
bheinen74 replied to cal_look_zero's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Has a tuner right? How is the AM and FM reception on pulling stations? clear, or static. bh -
1979 Motor Trend subaru v.s. jeep article
bheinen74 replied to Rust's topic in Historic Subaru Forum: 50's thru 70's
if they were worried about being cramped, they could have purchased two Subaru's at $5499 each, and still be cheaper than the $12,500 price of the Wagoneer, and had one person drive each Subaru, spreading the gear out over the 2, it sure wouldn't be cramped that way, and they could have bought 1000 worth of spirits, and still had 500 dollars left for a hooker, and lots more fun than what the Wagoneer provided...... -
horrable rattle coming from engine??
bheinen74 replied to danzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what transmission do you have, auto or 5spd? if auto, could be cracked flexplate. Could be heat shield rattle or and exhaust bracket. could be a timing bearing component going bad could be waterpump could be power steering pump. etc. -
why lasher adjuster so hard?
bheinen74 replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah good thing. as long as it not stuck. pin hole on end to press, in oil bath, to check and bleed air -
actually new belts are more prone to stretch after the first few months. they are kinda like blue jeans or new shoes, they stretch around to break in when you wear them the first few times, and new belts are the same, they stretch some to fit the pulleys etc. then they won't stretch again til they wear down. when you buy a new car, the first service checkup is for them to re-tighten the belts, etc, along with change fluids...And I do see that you have a newer belt on yours.
says pre tension, pre load on the bearing. you check it by first marking where the retainer is, i use a sharp chisel and chisel the mark, and also a white paint pen. the paint can rub off, so then you have the indention mark. then, snug up the retainer until it is firmly resiting. Count the cogs from where it was to where it is when snug. upon re assembly, you do the same. take it to the mark, then check to make sure it gets firm the same or about same number of cogs. On mine, i snugged up mine 2 notches due to the wear etc. Ideally you would snug both sides of the diff the same number and i tried to snug my driver side the 2 notches, but that retainer isnt budging, with the lack of correct tool for it. .It is the wear also that loosens these and caused the gear to wear more over the age as well as heat. So snugging a little more, keeps the speedo gears from moving around so much.
"With the axle out, Subaru recommends swapping the axle shaft seal" sounds like some dealer wanted to make sure you bought a new seal. The pic you show, there is no leaking from the old seal evident, so leave all alone would hae been the wise choice. now you dug out the old one and in for a pricey repair if you are paying a shop to do this, otherwise if you are doing it yourself, only the cost of the seal, which is cheap. those seals have lefts and rights, according to the way the axle rotate most. Doubt any of the cars newer than 1990 will need those seals, even most of the 1980's cars only weap some oil but not enough to mess with them.
wanted to add, this is the job one cannot afford to pay a shop to do, it would be cheaper to swap in a different trans than paying a shop to do this job.... And most people cannot figure this one out. lots to factor, and you have to know how to check preload on the bearing etc..and have tools, which i don't even have the correct bearing removal tool, or the side retainer tool. But for me, it is parts about 36 bucks, oil at 11.99 a qt, x 2, and my own time If i had the right tools, i could have this done in 3-4 hours.
wow where is that trail, the outside the car is a awesome trail...
clutch plate friction disks (there are like 9 of them) in the rear output shaft of the trans may be worn and not catching. so even though duty c works or is new, there is just no way for the car to know if the plates are worn and slipping or not.....it may be turning but not turning the rear driveshaft if the plates are trashed. Car being towed with rear wheel down could cause that, or mismatched tires, etc. please check under hood to make certain nobody put a fuse in the FWD holder.
My '92 Landcruiser: Safariwagon-II
bheinen74 replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
winter is here in a week. snow in North NE and Wyoming/MT, and CO tomorrow night. -
some issues with the subbie
bheinen74 replied to 1blwngtp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if it not smell at battery, and you eliminate a overcharge of say like 15.5v or higher to like 18v, then yeah cats, or cheap gas. -
The alternator you just put in there no good, take it out, get a good one in there, not from autozone, etc. did you smell the battery and touch it for hotness to verify my cause. could be cats too. -
your battery is bad. and maybe it is the alternator voltage regulator failed too which is cooking the battery to begin with. touch the battery after a drive, it is hot and smells like rotten eggs. -
This car only the small gear was damaged, but they need to be replaced in matched sets. (this is the 3rd Legacy I have had to do this on, usually the big gear is cracked due to heat, etc) Getting that darn C clip back on is not very easy when you are doing this when it is in the car. Speedo works and so does cruise now, and no CEL code for vss, also car knows when to shift now too. Before, the speedo worked like lets say 75 percent of the time or less. And according to the owner, it just started not working in the past 5k. I chose Mobil1 Synthetic 75w-90 gear oil, which is much better than the ATF, which I drained out of the front diff. I figure synthetic in the auto diff is better, cause it can take the heat better, and is much thinner in extreme cold, the thick oil in cold can strip the gears too. Anyway, the gears i put back in it are same part number to a 94 turbo wagon, which are what tires will be going on this anyhow, going from 14" to 15" This time around I just wrote the part numbers for the 2 gears and the o-ring seal on the page in my FSM so i dont have to dig thru boxes of old parts bags looking for numbers on the parts...... Did this job on: 94TW 93SS sedan and now this car, all jobs of this repair have been done when the trans and engine still in the car. enjoy. and to those who say cannot be done with trans in the car, lol, this is the 3rd one i have done. No it is not easy, especially instaliing the snap ring, but i love a challenge. I think this job takes about 5 hours hard at it, you know, gotta drop the exhaust out of the way, remove lower arm bolts to slip axle out of the way, check bearing retainer pre-tension, remove the cap, remove the bearing, remove the axle stub, remove the speedo big gear, pull off the snap ring, slide out the small gear, install new small gear, install c-clip, install the axle stub, install new big gear put on the bearing, put new o-ring on the side retainer cap, install side reatainer, check preload vs the start step, install exhaust header, install axle, install control arm, fill gear oil, etc, etc et, etc...... I could cut down the time considerably, if i had the actual tool that was designed to unthread the side bearing retainer cap.....
