87
Everything posted by DaveT
Cooling fan not working
DaveT replied to StallonePanerai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmmm.... That doesn't make sense.. Use the voltmeter. If the threads are clean on the switch and the radiator, that's good connection. Oring has no effect. Solder is not going to stop current flow, it's a good conductor. Connect (-) lead to GND / battery (-). The other to the thermoswitch body. Get the switch to trip, or jumper the fan wire to the switch body to simulate the switch closing. If the voltmeter reads near zero, the GND side is not the problem. Also try the (-) lead to the radiator, same tests. Or simpler - disconnect the wire from the thermoswitch. Use a test wire to GND it - to the body, the battery (-) the radiator tank. Try each one. If the fan runs, the GND at that point is good, and the fan is good. What works and what doesn't? -
Sometimes it is a good idea to re check them after a few drives.
It is very common for corroded / bad / dirty connections to do weird intermittent stuff.
Terminal is one contact, the body / threads are the other. Polarity of the meter does not matter, it's a mechanical switch. It's open or closed. Only thing to be careful of with a torch is don't get it too much over boiling temp to avoid damaging it. Connect the ohm meter, it should read open. Heat the switch, the part that would be in contact with the radiator. I don;t recall the set point, but when it gets to that temperature, it should read close to 0 ohms on the meter. Be aware that ohm meters use very small currents, which can occasionally give misleading indications when testing circuits that are designed to carry many amps. A more certain test would be to ground the wire that connects to the sensor, and see the fan run. If it does, then use the fan as the test load- remove the switch, connect it and ground it, then heat it. see the fan run or not. -
1992 Subaru Loyale yay? Or nay?
DaveT replied to Winterpie0220's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, for some one with limit funds, and no time for hunting for and repairing or experience making parts, EA82 is a not great choice. Go with the earlier legacies. Check with guys that run them for which are the engines you want to avoide, parts availability, etc. I want nothing to do with all these newer cars with auto everything. That stuff might be fun, for the first decade of the car's life. But I don't buy cars that young. -
1984 Brat push button 4wd not working
DaveT replied to Subarute1984's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would take care of the switch first. Everything may be working normally - you just didn't have it in 4WD long enough to tell. If you hold the button, or tape / tie it down, you could verify if the 4WD engages. -
3AT is the number for 3 speed automatic transmission. If the button is like those on my newer ones, 86 and up- they are supposed to be alternate action switches. Press and stay down. Press again, stay up. 4WD active when down. -
What czny wrote. Mine have usually only lost the lowest 2 speeds. I just fix the resistor.
GL interior items swap to Loyale
DaveT replied to MWLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm not sure if the wire for the rear light is there, it might be. The voltmeter and oil pressure can be done. Think more like putting the GL meter assembly into the loyale. If you want to be fancy, swap the spedometer to keep the milage. Get the FSM schematics. the oil guage wire is the same wire as the switch, just move it to the new sensor. -
Where to buy EA81 front Struts???
DaveT replied to HeyZeus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There are better dealers that didn't throw away their old books. BUT the are likely NLA - but I am only guessing, from seeing a similar thread recently. Some of the guys with EA81s will add info. Used is more likely to be found. Or adapt something from a newer car. This is also discussed in that other thread. -
1st choice, replace. MAybe a piece of aluminum could be fabricated that would attach under the bolt to the left, and have a threaded hole. But that's a big maybe. Problem is, it's probably as much work to do that as replacing the carrier. What's left of the casting would have to be cut out so a decent piece of metal could be put there. I wouldn't want to try that with the engine in the car. No "glue" is going to stick to oiled metal. And endure the heat cycles. Welding cast anything is a complex process involving controlled heating of the entire piece, and controlled cooling. -
The NGK sets I have bought have always been correct. They last a LONG time also.
If you don't have pictures, which side, and which bolt tab is broken off? -
You are correct, no one took it to the point of sending me one. Someone with lights was closer to, but It's a whole extra level of complicated to do lights. I have clear plastic for the printer, but it's not going to make crystal clear p[prints. Not sure how well it will work. For a whole, it seemed like some could be found as new old stock, in colors needed by the seekers. Unless making these parts gets moderately profitable, I can't invest what it would taker to color match the OEM stuff. Experimentally making some black ones to prove out how satisfactory they are, I can do. They could probably be painted by the end user, using the modern paint systems used for repairing modern plastic exterior parts..
There is a thread I started about this sort of thing. It should not be too far down the list, as it had recent comments. I can make a model of an existing part. I can print one. Or some, depending on all the variables. I can't make a model of no part. Even if a part is broken, I could likely make a model, but enough of it has to be there to interpret what it would have been.
D'oh! yes, of course. -
Got any pictures of it? The broken part of the head. -
Is the thread just stripped, or part of the casting broken off? -
Yeah, I always mix up the letters!
NKG I mean NGK . I always mix up those letters!
EA82 distributor and timing
DaveT replied to Loyale_93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For an EA82 engine, if you follow the factory method of installing the timing belts, you DO turn the engine one full revolution between installing the first belt and the second.- 19 replies
- 1
- distributor
- timing
(and 1 more)
Tagged with:
Are the old axles original Subaru? Do they click, or do anything worse? If they are original, and not destroyed, Clean re-grease and reboot them. They'll go another 100K miles. Any cheap aftermarket ones, you are not doing anyone as favor - I would not sell them to a friend.
The pistons must be screwed in, NOT pressed. They may or may not have survived, depending on how much force was applied. Only way to find out is try screwing them in. It takes a good number of turns. What I have found effective for loosening the cone washer is a punch at least 1/4" round flat end. The bigger sized ball peen hammer, probably about the weight of a carpenter's hammer. or a little more. Trying to use a regular size ball peen, you end up pounding as lot, and deforming the washer more. The shock force is not high enough with the small hammer, at least for me. A screwdriver is not effective, because the handle absorbs the shock. If the washer is stuck to the axle, pulling on the hub will only clamp it tighter, don't do this. If the washer fell out, the nut was probably too loose. Use anti seize compound when you reassemble everything. If you resort to torch, seals and possibly bearings can be damaged. Seals are probably bad anyway. Unless it's extremely rusty, I don't think you need to torch it.
No longer available plastic parts
DaveT replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For the initial experiments, I just don't want to loose $. If it did turn out to be something, I'd want to make them affordable, but worth the time / work.
