Quidam
Everything posted by Quidam
Just some thoughts on JDM in general. It seems to be a crap shoot sometimes. If you can't put your hands and eyes on the ACTUAL engine and or tranny. Insist on pics of the actual part in question. Anecdotal JDM info. '89 carby Justy 1.2 L nine valve 3 cylinder: Ebay purchase, $390.00 shipped from California to a business address in Ohio. Would have been $50.00 more shipping to a residence. The ebay picture showed the engine with no accessories, no intake, carb, or exaust manifold. The engine arrived complete, air cleaner to oil pan and even had the flywheel with a powder clutch assy. for the ECVT transmission attatched. It also had the air conditioner compresser, alternator, and power steering pump. Now, to my knowledge, Justy's weren't sold in the U.S. with power steering. The Cat converter had two O2 sensors where the U.S. version has one. The engine is up and running like a champ, and was very clean inside. The oil pan was removed and the guts inspected, timing belt tightened up a bit, and the valves adjusted. The pick up coil assembly in the distributor was bad and it didn't fire up the first attempt. Swapped distributors and it fired right up. I'm speculating here: The reason the car may have been taken out of service in Japan in the first place "MAY" have just been the bad pick up coil. How does this pertain to a JDM transimission? Well, it seems you never know what you'll get. On this engine, I got lucky. It's been said that you don't need luck if you're good:). hummmm Doug
Hi, Enter "13" Justy wheels" in search, that should get you to a thread you may find useful. I've never seen a Gen 1 Justy in the flesh. The Gen 2 cars came with 12" and 13" tires and wheels. Best guess is that you could go as large as 165-70 without cutting anything in 13". And probably 145-45-15 with the right off-set wheel.
Hi, Athens, Ohio here. The bolt pattern is 4 X 100 and if you're not aware of it, Justy's came stock with 165-65-13 too. Aftermarket wheels in 12" and 13" are bolt on. Look at Konig Wheels for one manufacturer. First question is: How much are you willing to spend? Doug
Hey, Custom tubular headers have been made before for the Justy, I'm sure. Do you know anyone that actually makes or sells them? I don't. So, I've sourced all the parts to make them. If I do I'm making one for me, one for a friend, and one to put up for sale. The only part not off the shelf will be the header flange, where the tubing bolts to the cylinder head. Any thoughts, ideas, opinions that you may have on this I would appreciate. I really don't want to make them if someone allready does. Don't want to re-invent the wheel. Thanks, Doug
Hi Richard, The transmission left in neutral isn't going to be a problem. You just have to make sure it's not in gear while towing. So don't worry about that. The first click of the ignition will unlock your steering and nothing will be on to run down the battery. No worries here either. The tracking...well I would just keep in mind what could happen and keep an eye on it. Mabie install a camera. Forewarned is forearmed. State laws for braking on a toad varies. Check this out. You have lots of options if you need them. Some people would tow this without them. Your call. Doug
Baseplates are available to attatch to your Loyale. I remember reading people who have done it. One thing to watch is the front wheels getting cocked and not straightening out when they should. This is the area you want to find more info on and beware of. hth Doug Edit:Towing World (www.towingworld) says the following.. "SUBARU (85-90 2WD/4WD): This car will occasionally opposite lock when starting from a curb at low speed on a surface with poor traction. This has been verified by our own testing as well as discussions with SUBARU who has an extremely strong anti-towing posture. This is copy from an old Usenet post. Just something to keep in mind.
As GD stated: '85 and '86 are true "bolt on" for your application. Aftermarket sheetmetal for your year will be bolt on as well. Later years, the headlight buckets are different. The bumper and cover too. The hood, later models had windshield washer nozzles in them. The fender trim for yours is glue on and smaller than the later models that have holes in the fenders to mount the side trim. The marker/parking lights are different, but fit the same... Pay your money and take your choice. It will all fit the car, just depends on what you want and what combination of parts you use. The grille and mounting are different too..
HTH. I have that black in a '86 wagon, so I wouldn't think it's RX specific. At this point you can just remove the upper shift boot and console so it won't be flopping around crazy like. It is annoying when that happens. Why does that happen? When mine have done it, it means that the shifter bushings are worn out.
rebuilding the ditch witch :P
Quidam replied to heartless's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This rust around the windshield thing had me wondering what was going on there. On my cars, some have it and others have none. I'm out in the yard one day and an old friend stopped by and wanted to look at the cars. He's been a body/fender guy his whole life. I asked him about that issue. He said it's caused by cutting out a windshield and not primering/painting/prepping the area. Bare metal from the removal usually from a knife used to cut out the old glass. -
Ok, now i've got it. It was the water pump seal leaking, the seal where the shaft goes through the bearing right? It's been 20 years since I've bought a reman water pump and even back then I had the same problem with it that you had with yours. It has to do with pressing out the shaft, then pressing it all back together with a new seal and bearing. The used hub and shaft pressed back together is not as good as new. I'd like to know the failure rate with reman pumps, I'd bet it's high. The last NEW water pump I bought at NAPA came with the O ring, btw.
Hey Prospeeder, I've never seen a defective NEW waterpump, but that doesn't mean they don't exist. A remanufactured pump is the only bad "new" pump i've ever had. That was on a small block Chevy tho, and i've never bought another reman. That gasket sealer you described sounds iffy, what i use is good old Permatex #2 and glue the gasket to the pump. I put a very small amount on the other side of the gasket facing the engine and I've never had one leak on me. That O ring sounds like it "may" be the problem. When I've had a corroded pipe and no replacement on hand, I've put a little silicone around that O ring and it held fine. Yep, the O ring. Mabie. HTH
About a year back i ran across a blue one in Ky. They wanted $1500.00 and I didn't have the cash. It drove to Colorado the next day, damn. Nice car too.
Hey Prospeeder, Good looking RX you have there. I read the "Weird smell" thread today and you obviously now have first hand experience in what 260,000 miles really means. Want to sell it? I could be "some sucker to buy it" that you were referring to. lol Sincerely Doug
Anyway - I wouldn't let it stop me from driving what the h3!! i wanted. Carl I hear you Carl, me either, but people do the strangest things sometimes. It's 1969 and a man I know bought a NEW Chevelle SS. Yellow with a black vinyl top. Well, some people in that community ragged on him about the yellow paint, over, and over, and over. They thought it was weird, sissy...gay? even...whatever. Two weeks later he had it painted blue, no where near as good a paint job as the factory paint either.
Why subaru's are retired...
Quidam replied to zyewdall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Group Buy: Carbon Fiber or Fiberglass Hoods
Quidam replied to Marck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Take a look at any MFG site on fiberglass hoods for reference. At U.S. body for instance: "Heavy Duty" meaning bolt on, about $500.00. "Race weight" pin on about $300.00. This for an, I would assume for these purposes, low production, slow seller, plain hood. I picked a Dodge Valiant. So who here would pay $500.00 plus freight for a hood? How about $300.00 plus freight? Scott, I have no doubt you could sell them here if you decided to make some. Give me a price, and I'll give you an answer. Doug -
sticking front brake calipers
If you find the calipers and all to be working as designed, high on the list is old/swollen internally, rubber brake lines. HTH Doug -
Well, mounting for me could be four aluminum hood pins. The hood would just need to stay in one piece. All the rest are details. The quality of the hood used for the mold a critical point. Build them inexpensivly but structually sound. A basic fiberglass hood, a blank, no holes, no scoops, no fussing with inserts for hinges and hood catch, additional structure and weight for all of the above. Any color you want as long as it's black, that sort of thing. A -
getting the moisture out of headlights
Quidam replied to SoobGoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yea, a good one. I have a box of these lights that are leakers slated for repair at a future date. Good glass deserves saving around here. On a side note, of all the ones I have, out of six or eight drivers side headlights, ONE doesn't leak. The passenger side is less likely to be that way. What's this mean? I don't know, it's just what I'm seeing. -
Crankshaft groove, rear main seal, etc.
Quidam replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey All, Just anecdotal stuff here...I once bought a Ford pickup from a guy on the side of the road, I pulled him to safety with my Subaru. The transmission lost fluid because of a loose fitting. Anyway, I worked on the thing, got it going and all but it would occaisionaly go into fits. The engine would run rough, spit sputter, then straighten out. This would come and go. The guy I sold it to wanted the parts on it. He pulled the engine down and the thrust bearing was severely worn causing all the comotion. The crank would visibly move if you wedged and pushed, pulled on it. New bearings and crank took care of that. Doug -
Head Gaskets - anything else I should do?
Quidam replied to RMVR53's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey There, Don't assume it's head gaskets. Check the radiator, the lower center area is prone to rot and not easily seen. Check the whole cooling system over. If I'm not sure, I do a leak down...you'll find out if you have a motor. Doug -
Hi BlindSight, Keep in mind there are at least two sizes of batteries for these cars. A Car with AC takes a physically bigger and heavier battery. If you don't need the big one pass on it. Less weight and expense is a good thing. HTH Doug
[quote name=Syonyk I put it in using a screwdriver/hammer to tap it into place - it may not have been perfectly even side to side. Would this be enough to make it leak? Yes. Any damage at all, any distortion, it can and will leak. -=Russ=-[/quote] Doug
