Everything posted by subiemech85
car died in Illinois! HELP!
I'll call you later today
About those seats...
'79 toyota corolla liftback deluxe seats come close
'tis so sad if only it were closer, I would change the dist. for you! just got done changing one myself add it to the list of spare parts
1985 Subaru GL Photo Shoot
and to think: I just put an ea81 rad in the gen3 wagon had to read a book waiting for the pics to load
Hair-brained ideas from a guy who cant sleep
1. rx had CENTER diff lock, to lock power split, giving it "real" 4wd 2. make it SUPER low, you can walk faster than it can creep 3. 3600 rpm: 22" cut toro "personal pace" is a good foundation, but the frame is a bit weak, ariens 911 series walk behind self propelled and push came with subaru engines, snapper 21" self propelled has the best drive system 4. first thought: simplicity 5216 "hydrostatic tiller" or similar is a good solid foundation with a real "frame" second thought: toro groundsmaster why are we still awake when we should zzzzzz
My BRAT is stuck in a 5 foot drift
"speculation" that's what happens when you drive in 4x4 low with the parking brake on
I need a car
me thinks we ran him off into the woods never to return
87' GL with a bunch of problems
BOTH depends if you watch jerry springer, or if you are his guest
Ea81 for EA82 parts car?
engine trans rear end drive shaft radiator wiper motor fuses misc. bulbs there's more, but this is a quick list
'86 GL-10 Left for Dead - Help Identify Donor Transmission (pg4)
ford screwed ferguson, ford sucks ferguson to-20 is much better http://www.ytmag.com/profiles/to20prof.htm agco is the way to go
timing belts most likely = ea82, especially with a carb and dist in the us time to strip the covers off, no singles needed go watch jerry springer!!!!!
Subaru!! why not?
what's a gen3 hatch
there are 2 roll pins that hold on the shifter, they are small, same size as the standard pb 4wd shifter
bugger...lost #1 cylinder=EJ22 time/pic link added
well, you could get lucky and find out a valve does not move like it should ea81 bent intake pushtube
sometimes we even call each other
please pull from the XT shift handle with push button, and as much of the wiring harness with it as possible, and the two roll pins the 4spd 3rd gear issue is that the sychros go bad and one day you can no longer shift if you are still confused about the axles, let me know and I can scan in the application table that lists the various combinations Thanks!
windshield wiper motor
you may be able to remove motor without removing cowl plate! let us know how it turns out
re-read ^ which seals are leaking?
huge increase in performance it quit working on the way to work at work pulled it in shop and cleaned, lubed, and adjusted after all done, it worked great!! especially for a 29 year old motor!!
Push button 5-speed
-1! 11/79 ea71 gen 2 body wagon with 4x4 single range and slippy clutch due to rear seal leak is a very capable machine with 15" pugs and winterforce tires when in deep snow, if got stuck going forward, reverse always took care of the issue muddy dirt road was also not an issue, just let it rev around 4k+, that's where the power is anyways no logging roads around here only times when it was nice to have low range 1. 4spd d/r locked up in 3rd, start in low then drive in high 2. driving on snowy roads with slow traffic, stay in gear and change ranges as needed 3. turbo d/r full time 4wd use it as a 10 spd, always start in low, also great for while stuck in stop and go traffic, DC area rush hour sucks!
or do what I did remove motor remove flat cover over gearbox remove round cover over motor clean and lube motor and gearbox reassemble reinstall ADD ground wire from gearbox cover screw to strut tower or other suitable ground point
re-read ^
? clutch clamp force / upgrade ?
looking for options to upgrade clutch and clutch clamp force, ccf standard ccf is 350 kg. turbo ccf is 400 kg. what is the ccf of xt6 ?? I will be contacting various clutch companies and seeing what they offer Daikin exedy Part Number: 15008 Valeo Standard Clutch Kit 52254801 Sachs clutch kit KF680-02 will new gen parts work?
Subaru!! why not?
ea82 3 door, also came in ea71 flavor ea71 and ea81 hatch can have ea82 added this is just another example of why it's bad to designate a body by the engine it has for example: my '86 gl-10 turbo wagon has a happy ea81 3 door and hatch are two different critters it is also not proper to refer to 3 door as rx, as the rx was also a sedan \ end rant please show the back side
painting block
they were grey when new!!
