Everything posted by subiemech85
why am i not getting good gas milage?
bad fuel guage or stuck shut choke
Very Strange Ticky Rattle Front End
and while you're at it, with front left wheel jacked up, and fwd fuse in, have it "drive" so you can see what it is doing are your balls dry in the axle?
New here....... EA82 starting problems.
check timing belts
How'd I do?
ttowwoop! looks like wou paid $300 extra need details
How hard is it.....Really.
edited in quoted
if you want to switch intake manifolds, and put the weber on the ea82 manifold, you will be better off, as you use the same top rad hose water pump can be switched, then you should be able to use same lower rad hose, if you don't, then a piece of flex hose works good, same one as vw diesel rabbit pickup without AC dist wires need to be re-routed so they run behind the alt, and use a longer coil wire, to avoid moving coil or lengthening other wires lay the PS pump Assy. in the spare tire area leave the AC off, it's winter the rad fan will fit fine, unless the block heater is in the way make sure the clutch will fit
Deleting engine driven radiator fan
engine driven fan ONLY came on AC equipped ea82 I would leave it off until you have issues with it running warm that the electric cooling fan can't handle, which I have rarely discovered, such as high rpm, high load, low speed long duration making donuts in snow after a while I got dizzy and had to quit :-\ I found a front mount small fan I think was from a KIA, fits behind grill when air conditioner condenser is removed, can send pic if you like
is the odometer or hour meter "stuck"
EA81 Special Valve Adjustment Tool
yes, 5 and 12 after enough practice, it's easier without use torque wrench to tighten lock nuts!!
carfax request
thanks, will print later trying to figure why the '87 tin tags are on the '86 body
Rattle Can Paint Job
MilesFox Trashwagon repaint buy a good compressor once, or one compressor every 2 years or sooner ROL-AIR is nice also use an air filter / dryer DeVilbsss sprayguns are sweet!
carfax request
sorry about that, my inbox got flooded quiclky, but there is space again looking for detailed info something seems fishy
Bad Clutch
subiemech85 replied to saranham's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXclutch test: direct drive gear @ approx. 25 mph FLOOR IT!! assuming engine has enough power slip = bad 'tis even funner pulling trailer with ea71 powered gen 2 wagon with leaky rear main seal that lubricated clutch, careful throttle application required
help im new and i need little off road tires!
'tis just Wat it says it is '86 gl-10 t-wag ea81 transplanted ea81 engine, with ea82 carb and intake, swapped injection pump for carb pump, removed fuel sending unit and ran new hose for suction under the carpet, even made a plate from aluminum sheet, drilled a hole in the center, added grommet to run fuel pickup through, because fuel tank bottom is covered in sludge, and standard pickup is plugged, fuel pump controlled by standard system, no re-wiring required more details available upon request
I got lucky on E-Bay !!!
seller e-mailed me and offered 3 '85 service manuals -- no extra cost
I have a set of 185 65 15 and they are great, even better with LSD went out today after 6" of powdery snow, lots of fun, testing tires, learning how everything reacts, going up and down steep hills and slamming on the brakes -- it slides straight, just practicing lsd will be in soon day before, went on crappy rutted class b roads '86 gl-10 t-wag ea81
carfax request
VIN: JF2AN55B9GD442924 Vehicle: 1986 SUBARU GL10 AWD Records: 11 records found in the CARFAX Vehicle History database VIN: JF1AN43B9HB453467 Vehicle: 1987 SUBARU GL Records: 19 records found in the CARFAX Vehicle History database please check these, both are on same vehicle jkrhodes @ 37.com
EA82 Head Hoses interconection
coffee can with steel wool will work, vapor on top, oil in bottom be creative similar to vw 1.5 and 1.6 diesel blowby runaway
check it out!! more manuals, update info http://cgi.ebay.com/ebaymotors/SUBARU-SERVICE-MANUAL-AND-TRAINING-GUIDE_W0QQcmdZViewItemQQcategoryZ119140QQihZ002QQitemZ120279250105QQrdZ1QQsspagenameZWDVW
'86 Subaru Standard questions
this thread is worthless without pics ttiwwop ea71 is fun
historic plates on a 78???
the latest crutchfield cat. had a "vintage look" radio
Looking for EA81 engine rebuild kit.
did you try CCR?? see what they can do for you
ea71 into BUS
found while googling http://www.type2.com/library/enginem/subaeng.htm
ttiwwop too bad you caugha a SDT I thought people try to avoid them
Meet N Greet Photos
as I said earlier, sonw, that's what subarus are for made room in the garage, vw was hiding in there, used subaru in 4x4 to pull it around winterforce snows work good, ready for this year block heater still works winter gear in trunk: chain tow strap "snow" blower makita 4 cycle hand held -- SUBARU engine ice scraper snow brush gas coolant blanket tool set service manual fuel filters LSD will go in when fuel tank gets cleaned out just add snow
