Everything posted by subiemech85
loyale lacks power
check your choke or cold enrich system
So many fuel lines. Why?
you are referring to the vapor separator under the hood wix 33201 the wix is crystal clear http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33201 top line from carb vapor return one line from "tank" supply in one line to "carb" out the fuel pump mounted by the rear crossmember is not an issue, fairly protected there should be a filter before the pump I like to install a clear filter about 1' before the carb, current one happens to be mr. gasket 9747 http://www.mr-gasket.com/ProductDetails.aspx?MajID=220&MinID=2204&productID=327&txtSearch=9747 it has saved me atleast once, due to cruddy tank, remove and shake to clean
'86 GL-10 Left for Dead - Help Identify Donor Transmission (pg4)
they are nice when well cared for usually the ea82t goes bad due to operator error swap in a manual tras or 4eat if you go for the manual trans swap, you will also need the matching front drive shaft, as there is 120mm difference in length please post more pics of the digidash I have a nice '86 gl10 crust brown 5spd 4wd, with digidash I had to swap in a ea81 to replace the ea82t the previous owner left water in the block and froze
my wife drove my wagon and........ snap
there is NO FRAME, just BODY, unless you add subframe have a good look later when it's warmer and brighter, and take pictures
loyale lacks power
you could be starvig for fuel tank pickup and fuel pump inlet strainer could be plugged BTDT ATTN: DUDE my ea81 has more power than the clutch can handle
Has any one upgraded there alt on there 1400
found while SEARCHING http://www.ultimatesubaru.org/forum/showthread.php?t=18614&highlight=internal&page=2
Over-run backfiring, what makes Subaru's do it so much?
^ points luckily we upgrade to electronic
or do you mean the pop pop that happens when you let off the gas to shift I have noticed that if the throttle is not completely closed, it does not happen anti after burn something tells me this is a "feature" of the subaru boxer engines, as they tried to make it not happen with various "tricks"
Block heater/tank heater/radiator hose heater?
yes ok be sure to use a t-stat with a juggle pin STANT SUPERSTAT works great best way to drian block is to remove drain plug in head, 14mm socket
Cold snap = Massive amounts of water in the Oilpan!
does this mean you have LSD???
harbor freight has a metric set includes 14 and 17 http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98229 cornwell recommended as it was the shortest due to limited access Mac is a nice medium length bit
help me
bad alt can make tachometer go :banana:s
http://www.ultimatesubaru.org/forum/showthread.php?t=27068&highlight=block+heater or SEARCH for subiemech85 block heater
WTF " Gov regulates what we can make above Invoice"
subiemech85 replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXP T Barnum, perhaps http://en.wikipedia.org/wiki/There's_a_sucker_born_every_minute
Brat clutch Exedy
I'll check what is in stock, fairly sure it's luk, but not sure which one is which now have been out shopping all day :-\ you could call me AFTER 12pm, as I need to catch up on zzzzzz
GL=Truck :D
not suggesting you stole from it, but that it looks alot the same I am considering converting one to 4wd using toy rear axle and subaru ea81 engine with ea82 trans vwcaddy http://www.4crawler.com/VWpickup.shtml someone has swapped a subaru engine in already, which made me start to wonder
XT6 alt fits on ea71 gives you 90A
86 subaru wagon gone crazy
fuse link fuses alt.
removing slight surface rust from cylinder walls?
CRC 5-56 and a finger keep the jar of beans sealed to prevent sprouting
2 row radiator adventure
WRONG and WRONG!!!!! non-turbo MT and 4wd 5-speed 38.495 kw 131,341 BTU/h 590 x 322 x 16 23.23 x 12.68 x 0.63 AT and 4wd dual-range 45.822 kw 156,339 BTU/h 645 x 322 x 16 25.39 x 12.68 x 0.63 TURBO 47.683 KW 162,688 BTU/h 645 x 322 x 16 25.39 x 12.68 x 0.63 according to '85 FSM 2-5 p. 5 pub. G130BEA
Coil? Ignitor in Distributor? NO fire from Disty, EA81 HELP!!!
SO, how's it going? and what story did you tell advance??
EA82 Cam Case Idea - maybe crazy **UPDATED**
please update!!!!!
it's not a freeze plug!!!!! for ea71 and ea81 the plug is on the front of the block to the left of the crankshaft for ea82 the plug is on the bottom of the block below the oil fill tube use a 14mm bit to remove the plug is 36mm thread BTDT on ea71 ea81 ea82
My BRAT is stuck in a 5 foot drift
10 or 12 for locknut 12 or 14 for adjuster visegrips and pliers to avoid twisting cable I have several clutch kits collecting dust
the one in the link is OVERKILL and has NO PUMP I have yet to find one with a pump 400W block heater works great
