Everything posted by subiemech85
it's very common for the connection to come loose, try bending the pins on the headlight for better connection, after you use a can of electrical contact cleaner to get rid of the evil greenies
bolt pattern of the flex plate or splines?
http://mthobby.pcperfect.com/ch601/chengine.htm many good pics
EA82 parts swap into a EA81?
subiemech85 replied to spideyz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
th egr valve also fits -
Brat 5sp swap almost done.
subiemech85 replied to Craven's topic in Old Gen.: 80's GL/DL/XT/Loyales...
chicag rawhide 1-0027 fits all subaru and many nissan, and is greasable, internal locking -
Help on exhaust parts
subiemech85 replied to subaru420's topic in Old Gen.: 80's GL/DL/XT/Loyales...
stay away from the "fart cans", that's just bling run 2" all the way, and a glasspack in the stock position no need to run a "cherry bomb", that's just brand name when the $14 auto parts store ones work just fine -
Snowplow wagon w/stacks!!
subiemech85 replied to Allouez's topic in Old Gen.: 80's GL/DL/XT/Loyales...
where have you guys been for the last 8 months? follow this link for more info http://www.cardomain.com/memberpage/471729/4 -
this is a good example of why they don't work: http://www.ultimatesubaru.org/forum/showthread.php?t=15813&highlight=intake+manifold+gasket more than likely the car over heated, and the head gaskets need replaced
no, there is a difference between spfi/carb and mpfi/turbo, and there are different "generations" search for "intake manifold gasket"
Please help EA82 Wont Idle!
subiemech85 replied to bigtrout's topic in Old Gen.: 80's GL/DL/XT/Loyales...
remove the egr valve, and put on a block off plate, use a new gasket as a pattern, sounds like how my car runs with the egr valve removed and nothing there check the 4x vac lines -
ea81 question: What is this? pic included
subiemech85 replied to EA82Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
replace your spark plugs, cap, rotor, and check the wires -
save your "pantograph jack" for precise adjustment of height, and jacking the front of a narrow front allis chalmers wd 45, or similar tractor, when any other jack won't fit, been there, done that it is also acceptable to use a 6x6 on the jack, if the jack can't jack it, as I do it every day jacking spreaders
Another Accell super coil Dead
subiemech85 replied to 78TurboBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this talk about the position of the coil killed it is total BS, as you can see in the pic, it is a coil that is pointed down in the origional location, and has survived harsh conditions -
Help with Fusible links
subiemech85 replied to 47Larry's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the jy is the best place to collect oem fuses and fusible links, and they may be considered "pocket parts" -
do I have to use the ea82 clutch disk? wantintg and needing to use as much ea81 as possible
85 wagon wiring short? possessed wipers FIXED
subiemech85 replied to gravelRX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pull the fuse panel, or check the engine harnesses -
I "could" stick in my 85 dr from the wagon, or the 82 dr from McBrat's red brat, if I really had to would an ea81 5spd fwd work?
STUCK IN 3RD, CAN'T SHIFT OUT, NO MATTER WHAT FORCE ON SHIFTER ea81 4spd dr plenty of oil, clutch works what do I do now? 4wd hi and low works
where can I have a key made by the code for 84 and older? dealer couldn't
you will not find it unless you tear apart the steering column, 85 fsm says so
what is it? 84 ea81 emissions control?
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what does it do? car runs too good to mess with it
